A/C Recirculation: air flow?
Discussion in 'Gen 3 Prius Technical Discussion' started by pakitt, Oct 27, 2011.
  1. pakitt
    pakitt Senior Member
    2,173
    1,311
    Colorado
    Does anybody know where the cabin air is taken from to get recirculated?
    I thought it was taken from the foot well of the passenger, but based on the position of the air filter there (behind the glove compartment) and presence of dirt on the top (and not the bottom) of it, it seems that air is pushed out (downwards) and not taken from the foot well.
    So, where does the cabin air being pulled from to get recirculated?
  2. Bob K.
    Bob K. New Member
    23
    Baltimore, MD
    Found it! When you change the cabin air filter you can see an opening into the airbox with a rubber flap. When vents to the outside are closed, the fan pulls open the small rubber flap and cabin air is pulled in.
  3. Tideland Prius
    16,070
    so it pulls in air from behind the glovebox?
  4. Bob K.
    Bob K. New Member
    23
    Baltimore, MD
    Yes, pulls it up from the passenger floorboard area.
  5. gliderman
    gliderman Active Member
    751
    223
    So now I know where that stinky foot smell comes from when my son is in the front seat.
  6. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    This is from the 2010 New Car Features:
  7. Tideland Prius
    16,070
    I've heard about a bi-level climate control system and I thought our Prius was equipped with it (at least when the 2G was around). Can anyone confirm that feature (if it exists at all?).
    What it is, is that in recirculation mode, it recirculates the air around the foot to heat up the air faster but blows fresh air near the top to keep the windows clear.
    Looking at that diagram, it appears that there's only one blower fan so all air has to pass through that and then onto the air filter... so this bi-level filter that's somehow stuck in my memory vault seems implausible.
  8. macman408
    macman408 Electron Guidance Counselor
    1,179
    365
    The repair manual uses the term bi-level to refer to the face/foot setting of the vent.
