A Little Diesel in Gas Reduces Emissions by 51%
Discussion in 'Environmental Discussion' started by Rokeby, Jun 23, 2010.
  1. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    "John Mullinix of Ledford has acquired a provisional patent on a fuel
    mixture he says will dramatically reduce the amount of noxious
    emissions from automotive engines.
    "The mixture is simple: One ounce of diesel fuel per 10 gallons of
    gasoline.
    "Mullinix has reports from John A. Logan College and Southern Illinois
    University on vehicles tested using his formula that indicate significant
    declines in hydrocarbons, carbon monoxide and nitrous oxide.
    "The study at SIU involved a Ford F-150 pickup truck.
    "Hydrocarbon emissions -- unburned fuel in the form of carbon soot
    responsible for smog -- after flowing through a catalytic converter
    tested at 21.700 parts per million with gasoline. That same gasoline
    with the 1 oz. of diesel added tested at 10.005 parts per million --
    a 51 percent hydrocarbon emission reduction."
    A slight MPG increase is also noted.
    More here.
    Could it really be this simple to significantly reduce emissions of
    ALL the gas powered cars on the road?
    If this mixture really works, shouldn't the EPA require it's being
    put on the market immediately after further validation testing?
  2. MJFrog
    MJFrog Active Member
    780
    266
    NE Oklahoma
    2018 Nissan LEAF
    Try saying THAT three times fast. Where's the science???
  3. vegasjetskier
    vegasjetskier New Member
    269
    29
    East Coast of Florida, USA
    Let's just say that I'm sceptical. And what were the results for the other emissions?
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    And what happens to the Catalytic Converter?
  5. fuzzy1
    10,045
    Only one study vehicle?
    This isn't science yet, it is just a slow news day at the local newspaper.
  6. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    About all I would expect it to do is reduce the octane rating of the fuel a bit. That would probably speed up ignition a little but lead to knocking. Bear in mind that diesel and petrol are both mixtures of hydrocarbons of different weight, diesel just being way easier to self-ignite.
    It's highly unlikely to do anything to the catalytic converter as the HC is mostly burned by the time it gets to the converter anyway.
    I'd be skeptical about the testing too: you have to perform the proper EPA test cycle under the right conditions to be fully reproducible, and perform A-B-A testing (without, then with, then without, the added quantity of diesel). It's much more likely that the 'result' has come from testing at idle and that the truck was cold for the first test and warmed up for the second. Or some other change in conditions.
    You can do any other test cycle you like, such as New European Driving Cycle. If you do that, you can compare with the official values that the manufacturer submitted for that vehicle to see if there was an obvious fault with the vehicle being tested that might explain the results.
  7. hill
    8,070
    Hey ... who worries about the details
    :rolleyes:
    Funny, isn't it? 2 stroke gas engines (which require pouring in a bit of oil into their gas) being outlawed due to their increased smog ... but pouring oil into gas reduces emissions. ok, now why can't I follow this logic . . .
  8. bwilson4web
    15,400
    Gasoline and diesel come from the same refineries and are blends of hydrocarbons . . . more like groups that can't economically be separated. So I find this report stretches credibility ranking right up there with adding acetone to gas.
    You are right that a lot of testing is needed to validate this claim. But given how hard it is to separate the various hydrocarbons from crude oil and how long we've been doing it, skepticism is justified.
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    My BS indicator went off scale as soon as I read the title of this thread.
    Tom
  10. Jagaurjx2
    Jagaurjx2 New Member
    Chicago
    The testing was actually done on multiple vehicles, all under the same conditions. A calibrated Mustang Dyno with build in 5 gas was used and each vehicle was run multiple times through the IM240 with varying concentration of the additive to determine the optimum mixture. The results of each test were compared, and several runs were done on different days and compared to eliminate any variations.
  11. qbee42
    18,058
    3,073
    Northern Michigan
    And...?
  12. bisco
    48,984
    i was just about to type that...
  13. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    You wanted facts? From someone practicing homeopathy on gasoline? I was impressed he could form English sentences. I had no expectation he could link to double blind testing.
  14. frodoz737
    frodoz737 Top Wrench
    4,297
    2,347
    33
    Let's see...10 gals of gas, 1 oz of diesel and 2 tbs of acetone...clean air and better gas mileage :rofl:
  15. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    If you mix a cup of water in with your petrol you reduce emissions to 0 after a few minutes.
  16. frodoz737
    4,297
    2,347
    33
    Don't forget the sugar. Then it's 0 emissions and 0 energy consumption, life time :D.
  17. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    I just keep adding electrolyte, isn't that how these plugin things work......?
  18. icarus
    icarus Senior Member
    4,884
    976
    earth
    Not running an RBI or at all, will reduce the emissions to zero as well. Saves a lot of money too!
    Icarus
  19. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    you forgot Brawndo
  20. hill
    8,070
    If we can't let this year old Zombie thread die . . . . . .
    I say throw a bit of Marvel Mystery Oil into the formula too. After all, it has 30 years of scientific research behind it.
    :p
