1. Offline
    Start a Conversation
    Dec 29, 2007
    4,111
    264
    Your Vehicle Year:
    Got it to
    Nice instructions and nicely done
    -Htc Tapatalk ( sorry for auto spell correct )
  2. Offline
    Dec 29, 2007
    4,111
    264
    Your Vehicle Year:
    Almost done
    Using some of existing temp hack wires
  3. Offline
    Dec 29, 2007
    4,111
    264
    Your Vehicle Year:
  4. Offline
    ccdisce Active Member
    Oct 10, 2010
    175
    108
    Stone Mtn GA USA
    Your Vehicle Year:
    FWD , what does the last pic show?
  5. Online
    lopezjm2001 Test guinea pig #9
    Apr 14, 2009
    974
    338
    Sydney Australia
    Your Vehicle Year:
    It shows a Lillyput touch screen working with a Canview V4 from Norm at www.hybridinterfaces.ca. The screen shows the ICE temperature.
  6. Offline
    Oct 10, 2010
    175
    108
    Stone Mtn GA USA
    Your Vehicle Year:
    Thanks for posting your install pics.
  7. Offline
    Oct 10, 2010
    175
    108
    Stone Mtn GA USA
    Your Vehicle Year:
    IMHO the ECU seems to 'age-out' the earlier 'Idle-dance' after a preset time that we do not know.
  8. Offline
    Oct 10, 2010
    175
    108
    Stone Mtn GA USA
    Your Vehicle Year:
    IMHO the ECU seems to 'age-out' the earlier 'Idle-dance' after a pre-set time that we do not know even tho the Prius is Ready, this it indicates by dropping out of S4 and initiating another idle-dance at the next stop
    If the ICE temperature is >185F it will attempt one but I think that it gets aborted to <10 seconds as I do not see the idle RPM getting tweaked above and around 960RPM.
    Making the Gen2 'not ready' seems to reset to S1 as soon as the ECU is shuts down, Thermos pump stops.
    If you slow to a stop and the ICE is OFF this is nirvana
    If you slow to a stop and the ICE ON here comes the Idle-Dance which may or may not be truncated.
    I am not sure if this aging process happens without the ECT Spoofer connected and the ICE temperature <185F.
    I will have to run some tests without it as I have been running my 2008 with an ECT Spoofer connected for the past 20 months.
    dave77 likes this.
  9. Offline
    josh2008 Hyundai Tech
    Sep 2, 2008
    363
    132
    Princeton, WV
    Your Vehicle Year:
    Any chance one of these can still be purchased?
  10. Offline
    Oct 10, 2010
    175
    108
    Stone Mtn GA USA
    Your Vehicle Year:
    Yes they are available for the Gen2 and Gen3.
    What model Prius are you planning to use it on?
    dave77 likes this.
  11. Offline
    Sep 2, 2008
    363
    132
    Princeton, WV
    Your Vehicle Year:
    Main one I was asking about was for an 05. With this work on my PiP as well?
  12. Offline
    Oct 10, 2010
    175
    108
    Stone Mtn GA USA
    Your Vehicle Year:
    It will work with the 05 since that is a Gen2.
    I do not know what the PiP wiring looks like so I cannot say.
    I run a Prototype version on my 02 Mustang but it needs a part changed but I am very familiar with the wiring.
  13. Offline
    Sep 2, 2008
    363
    132
    Princeton, WV
    Your Vehicle Year:
    How much for one for the 05?
  14. Offline
    Oct 10, 2010
    175
    108
    Stone Mtn GA USA
    Your Vehicle Year:
    $34 + $4 shipping and handling for the 05 kit.
    dave77 likes this.
  15. Offline
    usnavystgc Die Hard DIYer
    Jul 29, 2011
    1,333
    368
    Bowling Green, KY
    Your Vehicle Year:
    Worth every penny!!!!!!!
  16. Offline
    Mister MMT Member
    Feb 9, 2012
    172
    53
    Germany
    Your Vehicle Year:
    I got mine. It took a month to arrive, but went through customs without me having to pay anything.
    I'll install ASAP.
    Jan
  17. Offline
    pjc Member
    Jan 25, 2012
    106
    30
    Bloomington, MN
    Your Vehicle Year:
    I have one of these spoofers and every once in awhile I get a P1116 code thrown. No warning icons or anything, the CEL just quietly comes on. This is the code for the "Coolant Temperature Sensor Circuit Stack for Coolant Heat Storage". Anyone else have this experience? I'm assuming it is from my ECT spoofer, since one of the potential causes of the code is (Note: CHS = thermos):
    A significant difference (over 25!C [45!F]) exists between the engine coolant temperature signal and the CHS tank outlet temperature sensor signal after a predetermined length of time has elapsed from the start of the coolant recovering.
    I just don't want to ignore a real problem with my actual temp sensor....
  18. Offline
    2009Prius A Wimpy DIYer
    Mar 25, 2009
    2,464
    378
    Your Vehicle Year:
    I also have the spoofer and one morning got P1116 after several very short trips. It went away after a few regular trips. This may indeed be caused by the "perceived" condition you quoted above.
    pjc likes this.
  19. Offline
    TheForce Ron Paul 2012
    May 30, 2005
    3,429
    438
    Wheelersburg, Ohio
    Your Vehicle Year:
    P1116 is normal as long as you dont get it every time you start your car. I see it a hand full of times per year. Seems like it happens more in the winter time.
    davidigrace@mail.com likes this.
  20. Offline
    seilerts Battery Curmudgeon
    Mar 7, 2010
    3,296
    1,414
    Santa Fe, NM
    Your Vehicle Year:
    I've seen it too. It does tend to happen on an errand run involving several stops.
Share This Page
