AC driver Side reading 8 to 10 degrees lower than passenger side
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Greg Kaiser, Aug 1, 2015.
  1. Greg Kaiser
    Greg Kaiser Junior Member
    33
    Santan Valley Arizona
    Well it's averaging 105 deg here in Arizona and my 2008 Prius seems to have an AC imbalance in the vent
    system.
    I measure 68 degrees out of the drivers vents and 58 degrees out of the passenger vents when 105 degrees outside. 58 degrees out of the drivers side and 48 degrees out of the passenger side when the outside temp
    is around 93 degrees in the am
    I checked the inverter coolant level and to see if the pump is circulating all is fine there. I had read that the heat
    coming from the inverter can cause issues.
    I will check AC pressures tomorrow.
    Does the Prius have a climate door. I remember hearing a plastic like clicking afew months back
    thinking maybe the door was getting stuck.
    Thanks Greg
    48,945
    yes, but that would only affect air volume. the blower is below the passenger vent, so maybe the air warms as it travels over to the driver side.
  3. Patrick Wong
    18,198
    6,464
    It sounds like your air conditioning system is not working very well and it is good that you are going to check the high and low system pressures. The air coming out of the vents should be much colder, more like high-30 degree F temperatures.
  4. Greg Kaiser
    33
    I measured the low side at 27lbs and added die and R-134 to get the low side to 37lbs
    Seems to work better. So far no leak is found with the UV light. I even checked the Condensor on the front side.
    I need to get under the car to get a better look. I wish my ramps worked on this car too low.
    Also need to check the rear side of the condenser and the compressor. From what i can see from the top
    of the car and using a mirror underneath no leaks found with UV light
    Hope it's not the Evaporator !!
    Thanks for all the comments.
    Greg
  5. Greg Kaiser
    33
    Forgot to mention High side was at around 177 not 210-220. Not sure what this means
  6. bisco
    48,945
    try putting some 2x's in front of the ramps.
  7. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Hope you used dye that is compatible with hybrid high voltage AC and R134 that is also compatible with hybrid high voltage AC (just pure R134) and equipment that isn’t contaminated with PAG oil. Other vise you need to flush the system well.
  8. Greg Kaiser
    33
    No conductive Oil just R 134 and Die (Combo no sealers Oil etc). Never thought of die being conductive?
  9. valde3
    2,002
    745
    Finland
    Probably it’s ok if it says that it doesn’t contain oil or solvent.
  10. Greg Kaiser
    33
    OOPS !!! I just looked and there is a warning on Autozones website!!
    Should I get it evacuated? Working great now but not sure later. Blows 45 degrees at 109 degrees ouutside
  11. Patrick Wong
    18,198
    6,464
    Since the low pressure side is on the high side of the spec while your high pressure is too low, this sounds like your compressor will need to be replaced as it is not producing sufficient pressure.
  12. Greg Kaiser
    33
    Was thinking the same thing. Thanks
