Ac, Evaporator leaking.
Discussion in 'Generation 1 Prius Discussion' started by jm101, Jun 21, 2013.
  1. jm101
    jm101 Junior Member
    17
    ozark al
    Hello every one, I have been reading this site for awhile. Just joined have a 01 classic for 1yr My 01 looks new at 154000 miles lots of parts replaced before purchased and after I replaced 12 volt and inverter pump. Looks like evaporator core leak any one ever did this repair ,how difficult and time wise Thanks to all who make this wonderful site so useful.
  2. usnavystgc
    3,159
    988
    Tucson, AZ
    I suggest you get ahold of this PC member (lech auto air conditionin | PriusChat) He is an awesome source of knowledge for us. Are you by chance in the bay area SF?
  3. jm101
    jm101 Junior Member
    17
    ozark al
    Thanks for reply I am in FL Ocala area .would like to due this job myself, was looking for difficulty level,ie pull dash or just go in thru glovebox.
  4. ChapmanF
    15,074
    I'm pretty sure the repair manual starts that procedure with "remove instrument panel." So far I've managed to avoid any repair on my car that begins with that step. It reminds me too much of the old elk stew recipe, where step 1 was "dice one elk."
    -Chap
    bwilson4web and usnavystgc like this.
  5. usnavystgc
    3,159
    988
    Tucson, AZ
    Lech should be able to let you know what's involved.
  6. jm101
    jm101 Junior Member
    17
    ozark al
    Oh boy was not wanting to remove instrument panel or top of dash. Any chance the repair manual covers this if I can get one . jim
  7. usnavystgc
    3,159
    988
    Tucson, AZ
    It's a very big job, no doubt about that.
  8. jm101
    jm101 Junior Member
    17
    ozark al
    Thanks I just sent lech a message will wait and see. thanks jim
  9. ChapmanF
    15,074
    The chance is 100% the repair manual covers it, and in perfectly usable detail. As long as you can follow steps down a page it won't be a challenging job, just a tedious one (IOW, the challenge will be to overcome boredom). You can get the manual on paper from helminc.com (volume 2 is where the R&R instructions are, volume 1 is diagnosis and specs) or you can go straight online at techinfo.toyota.com (I think $15 gets you two days of access).
    I guess one place you could run into trouble is brittleness of old plastics. A lot of people have reported busting the central cluster/switches finish panel taking it out for radio access. I'm one of them but I'm pretty sure it was because I had overlooked a couple of nuts (my fault, they were clearly shown in the repair manual in front of me) and not that I couldn't have gotten it out intact. My advice: really, really, gentle. The manual shows illustrations of prying up with taped screwdrivers, but my own experience was that the clips they use will respond perfectly well to gentle pressure with spread fingers, no prying tool needed.
    From experience, I can tell you the center finish panel is about $100 if you happen to bust it.
    Of course the larger instrument-panel molding is plastic also; I don't know whether it is the same formulation as the center panel, or whether it becomes equally brittle. Haven't seen any reports about it but of course it's less common for people to remove it. I'd go easy on that one too.
    -Chap
  10. viking31
    viking31 Member
    515
    West Central Florida
    Yes, same problem here on a 2006. Leak detector goes 'cuckoo for cocoa puffs' when the probe is at the vents. Mostly trouble free at 230,000 miles. I have recharged twice and it loses charge every two months. I'm concerned about recharging again as oil is probably being lost too. Came across this post on a Gen II and it was real ugly! I hope lech chimes in regarding the Gen II and verifies if it is really necessary to tear out the entire dashboard.
  11. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    954
    716
    Boulder Hybids, Boulder, CO
    center dash panel closer to $150 than $100
    Replacement Center Dash Panel | PriusChat
    Be very careful removing it!
