1. Offline
    ultralame Junior Member
    Start a Conversation
    Feb 17, 2010
    SF
    Your Vehicle Year:
    I just picked up my 2012 C III, and I am digging it.
    I haven't had a chance to drain my tank yet, but I was wondering how much fuel you can actually use...
    I had a 2007 Gen II, and although it was a 12 gallon tank, I ran out of fuel 2x with it- once when I had consumed 10.5 and once just below 11.
    I have since read about the issues with the bladder tank, and since I libe in San Francisco, shrinkage isn't a problem- I just assumed that it the system was designed to be very conservative about how much fuel was in the tank. But it looks like that may not have been the case.
    My ONLY major reservation with the C is the small tank (Why not have a 14 gallon tank and drive 700 miles between fill-ups?!!).
    If the car acts like my last one, I will need to fill up after 8 gallons or risk a shutdown (and in SF on the hills, EV doesn't get you far).
    So, has anyone run their tank down yet?
    And what would it take to replace it with a std Prius tank? ;)
    Thanks!
  2. Offline
    SquallLHeart The Techie Guy
    Mar 10, 2012
    747
    180
    San Jose, CA
    Your Vehicle Year:
    specifications state it's a 9.5 gal tank.. also noted in a very useful and resourceful book that you get with the vehicle.. (PSST... it's called the owner's manual)
    the car will start complaining and blinking that light at you when you have about 1.2 gallons left in the tank... which results in about an 8.3 gallon fill-up.
    it would take fabrication and a lot of work to replace the tank with a larger one.. it's just better to fill up the tank more often dude.. the additional weight of carrying that much more fuel isn't worth the added driving range... including the work you need to do such a mod.
    things were shrunk down in size for a reason. there just isn't much room for a larger tank to begin with... hell.. if you don't care about trunk space.. you can always hook up some aux fuel tanks and put them in there... or if you want.. carry some extra fuel cans to fill up from..
    i'm still not understanding the reasons why someone would want to carry around extra fuel.... is it because you don't live close to a gas station?
    it's not good for the car to run low on fuel... and someone would have to be stupid to run their tank down.. and even moreso to run out completely... say goodbye to your traction battery when that happens.
    Caber and dellrio like this.
  3. Offline
    kkim Active Member
    Jan 27, 2007
    381
    120
    kauai, hawaii
    Your Vehicle Year:
    lol... carry a 5 gallon can of gas in the trunk. :p
  4. Offline
    Feb 17, 2010
    SF
    Your Vehicle Year:
    Internet Forums. Ask a reasonable question, get berated by a jackass.
    Going back to my post, I told you that my 2007 Prius manual claimed 12 gallons in that thing you refer to as a manual. It ran out around 10.5, supposedly with 1 1/2 gallons in the tank and a range of 75 miles to go. That wasn't fun.
    I am concerned that I will have the same issue with the new car, and I will not be able to know the TRUE capacity until I actually run out, something I don't want to do.
    If the new car has the same issue as the old one, I will run out of gas after 8 gallons, which means that I will need to stop for gas around 7. This takes the trip capacity down from around 400-450 miles to 300-350, which is one-two days sooner with my commute.
    Also, what good is it for you to speculate as to whether it's better for me to increase the tank capacity? Do you have any idea what my motivation was for buying this car?
    • I will be driving 75-100 miles a day.
    • The closest station conveniently on my commute is 10 miles away.
    • Even on weekends, I don't typically drive past a gas station.
    • Most of the stations near my house and at the "home end" of my commute are significantly more expensive.
    Which means that I either have one expensive convenient place to fill my tank or I have to take a 15 minute detour to get reasonably priced gas. So the only significant choice I made when considering this version versus the std Prius was the tank capacity VS ease of parking. We went with ease of parking.
    But that doesn't mean I am not sincerely concerned about the tank capacity, and would like to know if anyone else has experienced this problem before I start commuting today. IT also doesn't prevent me from waxing philosophical about why Toyota doesn't realize that many of us would like to see a 600+ mile range on these cars, even at the expense of 1 mpg.
    As for swapping in a new tank- did you see that little "wink" emoticon? That means I am not serious about it. Welcome to the internets.
  5. Offline
    Tek55 Junior Member
    Mar 25, 2012
    96
    Houston
    Your Vehicle Year:
    I should turn this into a T-Shirt logo. I would make millions. :rockon:
  6. Offline
    Mar 10, 2012
    747
    180
    San Jose, CA
    Your Vehicle Year:
    The tank still holds 9.5 gallons of fuel.. instead of asking what the "true" capacity is.. which is that number.. perhaps you should've asked about how much gas is used before the annoying light turns on..
    since again, it's completely idiotic for someone to wait until their car dies from lack of fuel.. which was also a number I stated above.
    if you're driving conservatively and getting good mileage out of the tank, you can get over 500 miles before you should fill up.
    fyi, there's no "claim".. your 2007 did have a 12 gallon tank. no vehicle will run the tank until it's dry..
    but if you care, I've filled up twice now with 8.6 gallons.
  7. Offline
    rlalford New Member
    Mar 14, 2012
    31
    Durham, NC
    Your Vehicle Year:
    Thus far, I've driven my Prius c as far as 485 miles w/o any issues -- just filled up with 8.8 gal this afternoon ...
  8. Offline
    phenoyz Member
    Jan 31, 2012
    108
    nevada
    Your Vehicle Year:
    is this on 1 full tank fill-up?
  9. Offline
    Feb 17, 2010
    SF
    Your Vehicle Year:
    Yes, I suppose I could have used better language to ask my question. But I still think my meaning was clear from the rest of the post.
    This is not true. Toyota put a 12G bladder tank in the 2007 prius. The capacity of this tank ranged from 9-11.5 gallons depending on the climate in which you filled it. My car would beep at me around 9.5 gallons, and run out at 10.5; which is why I was so perplexed to run out of fuel when I thought I had an additional 75 miles of range (When this happened, I assumed that there was something wrong or just ultra-conservative about the warning beep. I was wrong.)
    Toyota can put whatever they want in the car to hold the fuel, but if the spec says 12G and the car runs out of gas at 10.5G, then their "claim" of a tank with 12G is false.
  10. Offline
    kkim Active Member
    Jan 27, 2007
    381
    120
    kauai, hawaii
    Your Vehicle Year:
    The Prius c does not come with a bladder tank.
  11. Offline
    Feb 17, 2010
    SF
    Your Vehicle Year:
    Thank you, I had checked into this before buying it. But I was still wary and did not see anyone specifically mention that there was no problem on the Gen III prius. (Back in 2008 I searched for help on this, and came up short).
    I really like this little guy, but I drive a lot, and would rather keep my gas stops to a minimum.
    On the other hand, I am able to park this thing almost anywhere in the city, so I am guessing I will still come out ahead.
  12. Offline
    Aug 14, 2006
    18,131
    3,443
    Sacramento, CA.
    Your Vehicle Year:
    The US standard is based on at least 300 mile range or more. The c will easily exceed 300 miles per tank. Packaging constraints limited the size of the fuel tank and weight is a major concern for stop and go driving. The c was designed for urban use so the 300+ mile range is more than adequate for this intended use. You really have no other choice because no other car will best the c in urban mpg and have a larger fuel capacity. If you drove mostly highway then a TDi would be a good choice for 700mile tanks.
  13. Offline
    Feb 17, 2010
    SF
    Your Vehicle Year:
    I thought about a Golf TDi. $5000+ more and the horror stories of several friends who had to deal with the cost of service on VWs (not saying they all have problems, just saying they are expensive to fix and maintain. The windshield on a Golf is $500 bucks from a third party!)
    But thank you for the info. It makes sense, and the Std Prius was appealing. I am unique in that I commute OUT of the city most days. :)
  14. Offline
    Aug 14, 2006
    18,131
    3,443
    Sacramento, CA.
    Your Vehicle Year:
    That is Rare. lol
    Yeah, I would never buy a VW for similar reasons but 700 mile tanks would be sweet.
  15. Offline
    kkim Active Member
    Jan 27, 2007
    381
    120
    kauai, hawaii
    Your Vehicle Year:
    If you are a Prius vet (unlike a Prius newbie, like myself), I'd venture to guess you should have no problem averaging 55-60 mpg (if not more), dependent on your travel terrain. That should give you a comfortable 400-500 mile range.
    I like this little car as well and am seriously considering buying a second one to replace my FIT.
    Ditto on VWs. I was a stalwart VW enthusiast back in the 70's and 80's, but got tired of the inherent design flaws they never seemed to be able to master as the Japanese cars have. To this day, as appealing as their cars look in their ads, I would never venture towards them again.
  16. Offline
    Feb 17, 2010
    SF
    Your Vehicle Year:
    I was never able to get much over 52 on the freeway in my old one (I know that there are people who can drive them up to 60mpg, but I never got close, even when I tried). My commute (I work for myself, so it's not always daily, but can be) runs 40-100 miles round trip. 90% of that is on a freeway, so I won't be doing much better than 50mpg on that (my 2007 got 48-50, today I got 49 after resetting the trip meter once I was up to speed; I will probably be able to improve that a bit after getting back into better Prius driving habits, but not by much- and this one is not as good on the freeway as the std model).
    Traffic MPG will be better, when and if I hit some.
    But ALL my city driving is on hills in San Francisco. The old Prius was 33-36 on these, and this one looks a little better, as it's 500lbs lighter, running about 38-40 as I run for groceries and drop the kids off. (My Rav4 is 17-18 in this city, 25-27 on the freeway, so i am not complaining- I was filling that thing up every 220-250 miles).
    I expect a grand total around 45mpg, so maybe I will hit 400 miles a tank when I have a lot of freeway driving.
  17. Offline
    Carrollights Junior Member
    Mar 24, 2012
    36
    WV
    Your Vehicle Year:
    I have drove my Prius C for 1,500 miles so far, filled the tank twice at the 1000 mile mark and I was able to get 10 gallons of gas in there, and that filled it to the top
    so I'm avg 500 miles per tankful
    1 people like this.
  18. Offline
    phenoyz Member
    Jan 31, 2012
    108
    nevada
    Your Vehicle Year:
    that's INCREDIBLE!!!:kiss:
    ...my sister used to live in wheeling yrs ago...Gabriels is the place to shop
  19. Offline
    Lenwood New Member
    Mar 22, 2012
    53
    san Mateo ca
    Your Vehicle Year:
    I just filled up today, my gas bar started blinking it took 8.2 gallons 439 mi on odo= almost 54 mpg! I'm happy I don't care how big the tank is. Btw that's city and why combined tooling around San francisco and the San Mateo area.plenty of hilly terrain
  20. Offline
    rlalford New Member
    Mar 14, 2012
    31
    Durham, NC
    Your Vehicle Year:
    No, the 485 mi was on a partial tank (8.34 gal) ...
Share This Page
