Actual MPGs - Anyone Filled Up, Calculated?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by cycledrum, Mar 9, 2012.
  1. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    Latest fillup: 488.5 miles, took 8.44 gallons after the third click. 57.8 MPG. Consumption screen said 61 MPG. If I had gone by the first click, it would've been 7.82 gallons and 62.4 MPG.
    EV ratio screen:
    105 miles EV, 382 miles HV, (21% / 79%)
    33Kwh used, 7 gallons used,
    2.8 gallons saved
    The rounding errors are really starting to annoy me...
  2. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Thanks.. but I think you broke fuelly..
    your update kicked off everyone
    2012 Toyota Prius Plug-in MPG Reports | Fuelly
    is just you (earlier there were 15 folks).
    Just kidding.. about the cause but seems odd.
  3. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    fuelly..
    v - 40 MPG
    '11 Pri ~ 48
    c - 51.x (2 cars)
    PiP - 56.x (1 car) ...
    DrI - 406 MPG :eek:
  4. HillCountryEVer
    HillCountryEVer New Member
    75
    Kerrville, Texas
    I'm not that familiar with the Fuelly site but if you hit the "Show All" link I believe they all come back...:(
  5. Piprius
    Piprius Member of the cult of Prius
    72
    MD
    This is so amazingly relevant I am stunned that this hasn't been stated before. Please sirrah, share more of your unassailable insight.:ban:
  6. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    First fill up: 20 days until I visited a gas pump!
    568 miles, 8.2 gallons (still one bar left), screen said 71 MPG, calculated 69.2 MPG.
    Drive on mostly electric to work but have to use gas on the way home-
    but just got the word they approved 3 EV chargers for work...YEAH! The 3 of us PIP owners would have been happy with just electrical outlets....(and yes all through Dianne! Thanks Dianne)
  7. drinnovation
    2,027
    586
    65
    CO
    Thanks, but I tried that. :cool:
    Others Pips are still in there somewhere as trackyside comes up if I go to
    PiP (Toyota Prius Plug-in) | Fuelly
    I did notice that prius plugin in now a browsable catagory so maybe when that change happened people were removed from the list (at least until their next fillup since trackyside is still in the system )
  8. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Yeah, that is odd. Is 3 some kind of magic fill-up number? Once Dev had 3, then everyone else was removed from the list? Weird..
  9. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    Dev,
    You've posted these fillups. Is the above your 3rd.
    03/15/12 devprius 481.0 8.52
    03/26/12 devprius 488.1 8.794
  10. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    inventor00,
    Do you have your EV Driving display info with kwh, EV%, HV% for this fillup?
  11. devprius
    devprius /dev/geek
    979
    291
    You have the wrong date for the 2nd fillup. It should be the 20th, not the 26th. And yes, that was my third fillup (488.5 & 8.44 gallons).
  12. stephens5.rich@gmail.com
    [email protected] New Member
    39
    Los Gatos, CA
    My commute is just over 31 miles each way of mostly only mild incline/decline. I did make one trip over the summit between Los Gatos and Santa Cruz which dropped my average quite a bit but even with that, I've traveled over 500 miles so far at 102 MPG and still showing 1/2 tank. I'm going for the 1000 mark! With my 2006, I averaged 58 and had one tank with well over 600 miles as high as 65. Stay tuned! I'll let you all know, once I need to fill up.
    2 people like this.
  13. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    That is outstanding. I assume you are driving at the speed limits ?
  14. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    That is an outstanding result given that you have 31 miles in between charging opportunities. This seems markedly better than what others have been reporting. What do you think you are doing differently?
  15. john1701a
    john1701a Prius Guru
    12,748
    5,243
    57
    First fillup was a bit uncertain, since I wasn't sure if those initial miles were without any EV. It certainly looked like it though. The odometer was at 685 miles. 8.504 gallons were pumped in. 60 kWh was indicated on the screen.
    79.0 MPG was shown.
    80.6 MPG was calculated.
  16. sjblee
    sjblee Junior Member
    San Jose, CA
    I filled up for the first time on 3/29:
    Total Miles: 600.4
    Pump Gallons: 8.248
    Cost: $34.47
    Calculated MPG: 72.51
    Displayed MPG: 75
    Ave Speed: 27
    EV Driving Display
    kWh: 50
    Gallons: 7
    Gallons Saved: 4.1
    EV%: 32%
    EV Miles: 193
    HV%: 68%
    HV Miles: 407
    Calculated:
    EV Miles/kWh: 3.86
    EV kWh/100m: 25.91
    HV Calculated MPG: 58.14
    I love my second Prius!:)
  17. stephens5.rich@gmail.com
    39
    Los Gatos, CA
    Most of the time I am doing the speed limit. Occasionally hitting 70 but trying not to. I figure that going 70 vs 65 over 31 miles only saves me 2-3 minutes but hits the milage pretty hard. I also don't have my stickers yet though so in the evening commute, I can be doing far less than the speed limit. I'm taking full advantage of EV during those times. I also don't drive it like a race car - The track is for doing that! On the street, I've become a fairly tame driver, again knowing that the speed difference realy isn't worth it unless you are traveling long distances.
  18. andyprius
    2,212
    188
    My philosophy exactly, it is good to know what sort of mileage I will be getting. :cheer2:
  19. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    John, Did you record your charged kWh and the EV Display Gallons and Saved Gallons?
    ALL PIP Owners,
    If you post your Date, Odometer, Actual Gallons, HSI Display and EV Display info for every Tank fillup, I'll add the info to a table and post it for comparison.
  20. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    Here are the Tank fillups I have so far. If you have info missing, send it to me and I'll add it. Thanks.
