1. Offline
    PatrickN New Member
    Start a Conversation
    Apr 17, 2012
    MA
    Your Vehicle Year:
    I'm about to get my 25k mile service and I've been looking through some posts regarding what services I should request beyond the factory required maintenance. It appears that there are enough members here that have the opinion to change the transaxle fluid that I am going to do this, but I'm unclear as to the other fluids. I was hoping we could type up something that listed all of the fluids/other consumables and when to replace them.
    Also (dumb question) but I am assuming that the transmission is part of the transaxle and therefore changing the transaxle fluid is the same as changing the transmission fluid in a Prius. Is this true?
    Thank you very much and I think this would greatly help people who want their cars to last a very long time but honestly don't know what services to do.
  2. Offline
    LulzChicken Prius Enthusiast / Student
    Jul 19, 2009
    762
    98
    Huntsville, AL
    Your Vehicle Year:
    Honestly, at your mileage I'd just get a tire rotation and an oil change. Transmission/transaxle fluid replacement shouldn't be necessary at your mileage. Some people say to do it, some others say to leave it alone. If I were you, I'd wait and do some more research and think about the transmission. You're only at 25k. If anything, change it at 30-36k or something along those lines. Several people here haven't ever replaced it and their cars are running fine. There is proof that there is some nasty gunk in there though after 30k miles. I asked a familiar question a few days ago about if I should change my transmission/transaxle fluid or not at 25k/3yr. of ownership. Check the thread here. Your dealership should top off all other fluids when you go in for an oil change/tire rotation. As far as I know, they're basically the same thing term-wise. I'd stick with "transmission" fluid. This may not have answered everything you had to ask, but it's a start. I just got back from my 25k service today and did an oil change and tire rotation. You and I still have some time to think about the transmission fluid. Check your engine/cabin filter and if they seem dirty order them on the internet and replace them yourself. The dealer will definitely rob you on those. Other than oil change and tire rotation, check your filters and think about the transmission fluid.
    Cheers!
  3. Offline
    The Critic Resident Critic
    Oct 28, 2005
    1,930
    334
    Marina, CA
    Your Vehicle Year:
    At the 60k mark, I would also consider the following services:
    - drain and refill engine coolant
    - drain and refill inverter coolant
    - brake fluid flush
    - clean throttle body and replace PCV valve
    I had my engine coolant done at 30k, and plan to do the inverter coolant soon when I have time. I did my own brake flush at 30k for $14 in parts.
  4. Offline
    Apr 14, 2009
    5,824
    1,614
    Greenwood MS USA
    Your Vehicle Year:
    Some cars have a Transmission, and a Differential, as separate units. In the Prius (and many other cars) the Transaxle does both functions in one unit.
Share This Page
