1. Offline
    FUUFNF Forum Lurker
    Start a Conversation
    May 1, 2007
    228
    29
    Long Beach, CA
    Your Vehicle Year:
    OK, so I need some advice on some Prius 17" OEM rims that I have lined up. The rims are pretty much new (they came off a new vehicle at port), so they have no cosmetic blemishes. And they come with tires (Toyo Proxe A20 215/45/17), which are the default tires that come with the car, so I'd assuming they're LRR. The price for all four rims, including tires, is $750. All that being said, do you guys think these rims will look good on a PiP? Will the tires sufficiently fill the wheelwell, or will the car need to be dropped to reduce the gap? Does anyone know if the tires are LRR? Is anyone currently driving on these rims & tires, and if so how is the ride and what kind of mileage are you getting? Lastly, do you guys think this is a good price for the rims & tires? Thanks in advice for your feedback.
  2. Offline
    exbauer Active Member
    Aug 16, 2006
    1,054
    62
    Your Vehicle Year:
    They are LRR tires. They are going to be stiffer than your 15s that you have on there currently. It will not fill in the wheel gap (you will need lowering springs), but it will look good on your plug-in. Expect a drop in mileage with the 17s, you will not be able to go as far with your EV miles.
  3. Offline
    Jonny Zero Giggidy
    Jun 22, 2012
    861
    166
    Austin, TX
    Your Vehicle Year:
    great price. I think they look much better than the PiP's wheels. You might lose a few MPGs but the wider tires will handle better.
  4. Online
    Aug 14, 2006
    18,157
    3,452
    Sacramento, CA.
    Your Vehicle Year:
    Go look at a regular Model Five in your color and that's about what it will look like.
  5. Offline
    FUUFNF Forum Lurker
    May 1, 2007
    228
    29
    Long Beach, CA
    Your Vehicle Year:
    Thanks. I'll do that.
    What do you think about the tire gap? I think you told me once of a tire size that would fill in the gap without having to lower the car. I really don't want to spend the extra money lowering the car (plus I'm super sketched about scraping and stuff). What tire size was that?
  6. Online
    Aug 14, 2006
    18,157
    3,452
    Sacramento, CA.
    Your Vehicle Year:
    If you are getting the wheels with tires on it then I would just run those till they are done. :)
    When you replace them you can run a 205/50/17 which is a bit taller and may appear to fill the wheel well gap better but honestly there is much gap the only thing that will fix it is a set of lowering springs. :)
    FUUFNF likes this.
  7. Offline
    FUUFNF Forum Lurker
    May 1, 2007
    228
    29
    Long Beach, CA
    Your Vehicle Year:
    Yeah, I was planning on running the tires as-is until they wear out.
    If I gotta go with the lowering springs, what would you recommend? Eibachs? How much do those run and how much lower will they lower the car?
  8. Offline
    sfv41901 Blizzard Brigade #164
    May 5, 2010
    2,280
    633
    Palmdale, Ca
    Your Vehicle Year:
    I would just use the tires that are on the rims now. You don't want to spend the $200 on springs but ud be willing to but 4 new tires??????? The Srings would be cheaper & would finish off the look.
  9. Offline
    May 5, 2010
    2,280
    633
    Palmdale, Ca
    Your Vehicle Year:
    Eibachs will lower it about 1.2in & can run u around $175-$250
  10. Offline
    2,725
    395
    Greater Vancouver, BC, Canada
    Your Vehicle Year:
    The 17" OEM's are slightly smaller outside diameter at the face of tread, very close though. Our Canadian Touring model has the 17", and it felt much more sure footed than our first test drive in a model with 15". Some of that could just be getting used to the car, the fact that it was daytime vs night, and so on. Also, when you get a model that comes with 17" stock, the steering setup is different (less turns of steering wheel lock-to-lock). The suspension might be slightly different as well, not sure. Here's a pic of ours on the show room floor:
    FUUFNF likes this.
  11. Offline
    ProximalSuns Senior Member
    Mar 24, 2012
    1,882
    PNW
    Your Vehicle Year:
    Hey. You want to sell your PIP alloy wheels?
  12. Online
    Aug 14, 2006
    18,157
    3,452
    Sacramento, CA.
    Your Vehicle Year:
    I prefer the Eibach springs. However, if The Critic is still selling his TRD springs you could get a killer deal including install. The car will look so much better lowered
  13. Offline
    FUUFNF Forum Lurker
    May 1, 2007
    228
    29
    Long Beach, CA
    Your Vehicle Year:
    Yes, I'm probably going to sell my PiP alloys once the 17s are installed. I'm assuming you're interested?
  14. Offline
    FUUFNF Forum Lurker
    May 1, 2007
    228
    29
    Long Beach, CA
    Your Vehicle Year:
    Any idea what he's asking for his TRD springs?
  15. Offline
    Mar 24, 2012
    1,882
    PNW
    Your Vehicle Year:
    Definitely interested.
  16. Online
    Aug 14, 2006
    18,157
    3,452
    Sacramento, CA.
    Your Vehicle Year:
  17. Offline
    FUUFNF Forum Lurker
    May 1, 2007
    228
    29
    Long Beach, CA
    Your Vehicle Year:
    Cool. I'll PM you when I get the 17s installed. I'm in Long Beach, CA. Are you in my area?
  18. Offline
    FUUFNF Forum Lurker
    May 1, 2007
    228
    29
    Long Beach, CA
    Your Vehicle Year:
  19. Offline
    May 5, 2010
    2,280
    633
    Palmdale, Ca
    Your Vehicle Year:
    Here is my 2012 sitting on H&R springs to give u an idea:
    [IMG]
  20. Offline
    FUUFNF Forum Lurker
    May 1, 2007
    228
    29
    Long Beach, CA
    Your Vehicle Year:
    Looks good.
    No issues with scraping or dragging when going up and down curb-cuts? How's the ride? Any different being lowered?
Share This Page
