1. Offline
    EricC New Member
    Jun 28, 2005
    Message Count:
    24
    Renton WA
    Your Vehicle Year:
    Has anyone else noticed a very loud hum when using your air conditioner? I am assuming it is the compressor running but it can easily be heard a good 5-10 feet from the car. It is coming from the far left side of the engine compartment when facing the car and even causes a slight but noticeable vibration in the car. It will start almost as soon as you turn on the A/C and then gets louder until it is just down right irritating. After 10-15 minutes of running then it will shut off, but starts right up again if you turn off the system.
    This is my first prius and I am not sure if this is normal or not. I took it in and a couple techs listened to it, but of course it was much better behaved around them. They set up an appointment for one of the prius techs to look it over but admitted they had yet to work on any 2010s. I'm just worried that they will come back and say it is nothing and then down the road I'll end up with a bigger problem.
    Thanks!
  2. Offline
    Jul 12, 2007
    Message Count:
    10,558
    430
    Adelaide South Australia
    Your Vehicle Year:
    Is it fan noise?
  3. Offline
    EricC New Member
    Jun 28, 2005
    Message Count:
    24
    Renton WA
    Your Vehicle Year:
    It could be, but when you open the hood I can't see anything that looks like a fan running in that section of the engine compartment. I did notice that it will start off high pitched and then after a few minutes will drop down a bit, but it seems to go up and down while running.
  4. Online
    HTMLSpinnr Gen III Forums Moderator
    Dec 8, 2003
    Message Count:
    4,977
    717
    Surprise, AZ (Phoenix)
    Your Vehicle Year:
    That would be your electric AC compressor. It is variable speed depending on AC load.
    I consider it (and the radiator fans) my "noise maker" in the hotter season in AZ.
  5. Offline
    Husker4theSpurs New Member
    Apr 11, 2007
    Message Count:
    518
    32
    Lincoln, Nebraska
    Your Vehicle Year:
    It's the ionizer or something like that ... coming from the driver's side vent, correct?
  6. Offline
    EricC New Member
    Jun 28, 2005
    Message Count:
    24
    Renton WA
    Your Vehicle Year:
    I know it's hard to say without hearing it, but is your compressor loud enough to be heard over the gas engine and 10 feet from the car? My salesman, who sells tons of prius, listened to it and said he had never heard one make that loud a noise. I just want to make sure I'm not making a big deal over something that is normal.
    Thanks!
  7. Online
    Dec 8, 2003
    Message Count:
    4,977
    717
    Your Vehicle Year:
    The Gen III compressor (when not in eco mode) spins faster than the Gen II. I can hear it over the engine, but it's not extraordinarily louder. See if you can start another car @ the dealer to compare the two.
  8. Offline
    DCRC New Member
    Jun 14, 2009
    Message Count:
    Manvel (Houston), TX
    Your Vehicle Year:
    Ours is real noisy as well. You can turn the A/C off and it goes away. Has kind of a metallic air plane sound.
  9. Offline
    12parsecs New Member
    Jun 12, 2009
    Message Count:
    MD
    Your Vehicle Year:
    Its definitely the compressor, mine makes the loud metallic buzzing noise too when the AC is on. Didn't realize how loud it was from the outside when its on full blast until earlier today.
    The fan makes more of a "whooshing" sound.
  10. Offline
    EricC New Member
    Jun 28, 2005
    Message Count:
    24
    Renton WA
    Your Vehicle Year:
    Just thought I would give an update. They looked it over and did confirm that the A/C compressor is bad. He said that it would probably have worked fine, but just been louder than normal. They had to order a new one and it should be all fixed by the middle of next week.
  11. Offline
    clintbhs02 New Member
    May 17, 2007
    Message Count:
    32
    My prius is making a noise (kinda like baseball cards in the spokes of a bicycle) over by the glove box... i am fearing the ac is going out and im out of warranty :( maybe its the filer?
  12. Offline
    rwdorn New Member
    Nov 4, 2009
    Message Count:
    Fort Worth, Texas
    Your Vehicle Year:
    Buzzing sound when the AC is ON.
    I hear a loud buzzing sound when the AC is on. I have 8000 miles on my 2010 Prius III and didn't notice this until just recently. The dealer told me this is normal for all Prius and mine was actully not as loud as most others! This really bugs me and I plan to go to a different dealer and test drive one of their Prius to hear for myself....Do any of you hear this also?
    1 people like this.
  13. Offline
    josh2008 Hyundai Tech
    Sep 2, 2008
    Message Count:
    321
    117
    Princeton, WV
    Your Vehicle Year:
    Re: Buzzing sound when the AC is ON.
    Yep, mine does it too.
    1 people like this.
  14. Offline
    Jolly Paul New Member
    Jan 13, 2010
    Message Count:
    163
    28
    Austin TX
    Your Vehicle Year:
    I've been using my AC heavily (this *is* Austin) and don't hear anything unusual. What do you mean by buzzing sound? Does it sound like something in the fan? I've had odd debris caught in the fan of many cars over the years. I doubt that is what you mean, but I'm having a hard time knowing exactly what you are referring to.
  15. Offline
    jdcollins5 New Member
    Aug 30, 2009
    Message Count:
    2,428
    429
    Wilmington, NC
    Your Vehicle Year:
    The AC compressor motor on the Prius runs on a variable speed inverter. The buzzing you hear is probably the inverter modulating frequencies. It is probably going to be loudest when the AC and the fan are running at full speed.
  16. Offline
    Philosophe 2010 Prius owner
    Jun 2, 2009
    Message Count:
    437
    67
    Montréal, Québec (Canada)
    Your Vehicle Year:
    The Prius A/C compressor is run with an electric motor, instead of being attached by a belt the gas engine, to allow it to run whether or not the gas engine is running.
    It does make a different noise than regular A/C compressors, and it is more noticeable when the gas engine is off.
    Usually, A/C compressors are either on or off. The Prius electric A/C compressor is of variable speed, to gain efficiency. The more cooling you require, the louder the sound will be.
    Conclusion: all is normal.
    1 people like this.
  17. Offline
    ozarkgolfer New Member
    Apr 22, 2010
    Message Count:
    76
    Rogers, AR
    Your Vehicle Year:
    Don't wish to be a naysayer by mine is almost silent - I get a buzzing noise at startup which I put down to hybrid startup - but in usual operation, no noises I can put down to the A/C.
  18. Offline
    silverfog New Member
    Sep 26, 2009
    Message Count:
    152
    23
    Raleigh,nc
    Your Vehicle Year:
    If you press the A/C remote (included on solar), you'll hear the buzzing. It's the A/C running without the ICE.
  19. Offline
    dandeman New Member
    Sep 29, 2005
    Message Count:
    39
    Chapel Hill, NC
    Your Vehicle Year:
    The Pruis AC compressor is a scroll compressor (reference page AC-12 in the factory service manual) which is the most efficient compressor technology currently available.
    Scroll compressors produce a characteristic buzzy noise at initial start up. They will quieten down after a bit of running...
    Scroll compressor concept [ame="http://en.wikipedia.org/wiki/Scroll_compressor"]Scroll compressor - Wikipedia, the free encyclopedia[/ame]
    So chalk it up as one of the technologies used to improve car's efficiency..
  20. Offline
    rwdorn New Member
    Nov 4, 2009
    Message Count:
    Fort Worth, Texas
    Your Vehicle Year:
    Thanks all for the insight into Prius opperation. I just never noticed this w/ AC on before... but then again this is my first summer driving it in a Texas Summer.
Share This Page
