1. Offline
    amm0bob Permanently Junior...
    Start a Conversation
    May 29, 2008
    5,235
    1,556
    Your Vehicle Year:
    I am getting real close to installing an air horn.
    Before I do... is it going to void my warrentee???
  2. Offline
    xs650 Senior Member
    Jul 2, 2010
    4,420
    1,306
    Northern California
    Your Vehicle Year:
    You came with a warranty?:D It must be expired by now.
    2 people like this.
  3. Offline
    xpcman Active Member
    Jun 11, 2009
    682
    110
    California - SF Bay area
    Your Vehicle Year:
    If you fry the horn's electrical system yes you might have warranty problems. For the hybrid components, Toyota would need to "prove" that your changes caused a problem with the factory parts.
    Good Luck
    1 people like this.
  4. Offline
    May 29, 2008
    5,235
    1,556
    Your Vehicle Year:
    Re: Air horn installation... and the factory warrant... and yes, Im expired according to the label
    Actually... according to the VA... I was supposed ta be a goner 25 years ago... :D
    Ima speckin bout what I be rollin in Bra... :D
    I like my little hybrid... I don't want to prematurely void the warranty, and all the extra coins I paid for getting it at the top of the hype, just because I want to alert a-holes on teh highway...
  5. Offline
    s3nfo Member
    Sep 3, 2005
    132
    16
    San Diego, Ca
    Yes, it will void the warranty.......on your OEM horn. Toyota must prove that any other damage was caused by the horn change to void your warranty on any other systems.
    1 people like this.
  6. Offline
    seilerts Battery Curmudgeon
    Mar 7, 2010
    3,296
    1,414
    Santa Fe, NM
    Your Vehicle Year:
    Relax. The horn system is very simple. There are two horns, a high pitch and a low pitch. Each has a single wire that carries +12V when the horn switch is closed at the steering wheel. There is no ground return wire, the ground is the physical mount to the radiator support. Using that circuit to power your air horn carries the least risk.
    I put Sequoia horns in mine. They are also single terminal and bolt right in. I have no problem at all getting someone else's attention!
    1 people like this.
  7. Offline
    David Beale Senior Member
    Jul 24, 2006
    3,769
    455
    Edmonton Alberta
    Your Vehicle Year:
    The safest and easiest way to install after-market horns is to put in a relay. The small black 1" cube type draw less than the stock horns. You run the contacts directly from the battery power through a fuse (say 10A) to the new horn and the other side of the horn grounds on the body. The relay coil runs to the stock horn wire and the other side to chassis. You can even put in a SPDT switch, so in one direction the car uses the stock horn (excuse please), and in the other direction your new horn (get the *#&%$ out of the way!!!). ;)
    1 people like this.
  8. Offline
    KK6PD _ . _ . / _ _ . _
    Mar 24, 2008
    3,580
    618
    Los Angeles
    Your Vehicle Year:
    I vote for Mr. Beales method. It's also uninstallable!, Just unplug stock horns, plug into existing horn wire to drive the relay. If ever a problem, simply plug OEM horns back in, pull new horn out, what problem?????
  9. Offline
    xs650 Senior Member
    Jul 2, 2010
    4,420
    1,306
    Northern California
    Your Vehicle Year:
    That also has the advantage of getting nearly full battery voltage to the horns. Factory wiring is sometimes a little skimpy.
    1 people like this.
  10. Offline
    DGH Thread Terminator
    Aug 13, 2006
    232
    Wales, WI
    Your Vehicle Year:
    There is not a lot of room to work with.
    What air horn are you going to use?
    I put in a Wolo Bad Boy, it's compact and much louder than stock.
    Without the overkill of a true trainhorn.
    1 people like this.
  11. Offline
    May 29, 2008
    5,235
    1,556
    Your Vehicle Year:
    I've seen those... even one in chrome... they are almost loud enough... maybe with a pair of em... hmmmmm...
Share This Page
