Allowing Access to Phone Contacts While Moving
Discussion in 'Gen 3 Prius Audio and Electronics' started by DanCole42, Mar 26, 2012.
  1. DanCole42
    DanCole42
    Expand Collapse
    New Member
    24
    Arlington, VA
    I've seen lots of threads to allow use of the navigation inputs while moving, however I have a 2012 Prius-2 and therefore no navigation. I just want to be able to access my phone contacts and/or use the dialpad while I'm driving.
    Does anyone have any suggestions?
    Thanks!
  2. cproaudio
    cproaudio
    Expand Collapse
    Speedlock Overrider
    2,172
    541
    CA
    Same speedlock override will work on the 2012 Prius two.
  3. Muzzman1
    Muzzman1
    Expand Collapse
    Member
    82
    40
    So Cal
  4. DanCole42
    DanCole42
    Expand Collapse
    New Member
    24
    Arlington, VA
    Does anyone know how to find an installer in the DC area?
  5. lumenrt7
    lumenrt7
    Expand Collapse
    New Member
    NY
  6. cproaudio
    cproaudio
    Expand Collapse
    Speedlock Overrider
    2,172
    541
    CA
    No, he and I installed it.
  7. Hank101
    Hank101
    Expand Collapse
    Member
    108
    SC
    Does anyone know what you loose when this is installed on a 2012 Prius II?
    Any other readout or function?
  8. cproaudio
    cproaudio
    Expand Collapse
    Speedlock Overrider
    2,172
    541
    CA
    No dealer will install this. Toyota will not disable seatbelt beep. What makes you think they will install this? That's like the last thing they would do.
    You don't loose anything when it's off. Everything is factory. Most touch screen buttons become grayed out once you pass 5MPH. You actually gain working touch screen buttons when it's on. All the grayed out buttons become active and usable. The only thing I'm not sure about is how it'll affect all the information in the "CAR" I think all the information in "CAR" are just the display. I don't think the headunit does any mileage calculations. Besides, I don't recommend leaving the override switch on when not using, not even in units without navigation.
  9. ProximalSuns
    ProximalSuns
    Expand Collapse
    Senior Member
    1,882
    16
    27
    PNW
    If you have voice recognition on the wheel, that works while the car is moving which is the idea, use voice while moving vs. looking down at the screen and running over a kid or...worse...rear ending me.
    Texting while driving (fooling with the screen with contacts is the same as texting) is proven to be dangerous thing to do.
