1. Offline
    dsoprius New Member
    Nov 18, 2007
    Message Count:
    A headlight on my 2004 Prius goes on and off ---instead of replacing the HID bulbs (at $340 each plus labor) is there a less expensive alternative, ie. giving up on HID and converting the headlights to use less expensive bulbs? Many thanks.
  2. Offline
    mingoglia New Member
    Oct 25, 2007
    Message Count:
    841
    Gilbert, AZ
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(dsoprius @ Nov 21 2007, 04:25 PM) [snapback]542658[/snapback]</div>
    Is it just one bulb doing this? Are you positive it's the bulb and not a wiring/contact issue?
  3. Offline
    dsoprius New Member
    Nov 18, 2007
    Message Count:
    <div class='quotetop'>QUOTE(mingoglia @ Nov 21 2007, 06:30 PM) [snapback]542661[/snapback]</div>
    It is only the driver's side bulb, and I've been told by the dealer that it is not likely to be the plug on the back of the bulb. Do you think it could be a wiring/contact problem, and if so, where?
  4. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    just nitpicking but technically HIDs are capsules, not bulbs since they don't really have a filament.
    Anyway, hmm.. not that I know of. Also having one side halogen and one side HIDs doesn't quite work. You'll also have to get rid of the ballasts and such. HIDs shouldn't burn out this quickly unless you've been flicking them on and off (or left them in the ON position and started/stopped your car frequently on short 5ish min trips).
    If they fire on and off > 3 times within the hour (just a rule of thumb), their life can be shortened significantly)
  5. Offline
    dsoprius New Member
    Nov 18, 2007
    Message Count:
    <div class='quotetop'>QUOTE(Tideland Prius @ Nov 21 2007, 07:52 PM) [snapback]542710[/snapback]</div>
    I have used them as DRL's, which in Detroit traffic is necessary for safety. I'd use the fog lights if they would come on separately, but the process of converting them electrically to be independent of the headlights (as shown in detail by another member) is beyond me. Of course replacing the fogs is not a cheap job either. I had intended on replacing both sides with the HID's or an alternative. I appreciate knowing the guidelines for not wearing them out. So perhaps there really is no alternative to paying about a thousand dollars to have the HID's replaced?
  6. Offline
    galaxee mostly benevolent
    Mar 14, 2005
    Message Count:
    9,810
    334
    MD
    Your Vehicle Year:
    you can replace them yourself to save on labor costs if you're careful, but the bulbs are still pricey. using your HIDs as DRLs will also shorten their lives.
  7. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(dsoprius @ Nov 21 2007, 05:04 PM) [snapback]542718[/snapback]</div>
    Hmm.. really? I though the foglight mod was ok and I haven't taken a car apart until I got the Prius. Using the foglights as DRLs will definitely be cheaper.
    Or even better, use the indicators. They're large enough to be seen from afar. I think someone here (seasalsa?) has done it.
  8. Offline
    dsoprius New Member
    Nov 18, 2007
    Message Count:
    <div class='quotetop'>QUOTE(Tideland Prius @ Nov 21 2007, 09:38 PM) [snapback]542752[/snapback]</div>
    Thanks for the suggestions and for properly defining the HID "capsules". Looks like I have some modifying to do (for the foglights to work independently). Appreciate your help.
  9. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    heh.. np. Hope the mod goes well!
  10. Offline
    mlathem1 New Member
    Nov 18, 2007
    Message Count:
    Dallas
    Your Vehicle Year:
    I am currently researching on what type of HID light and temp the Prius uses, so if you know I would appreciate the info.
    I kind of find it hard to believe the bulbs can run over $100 for a single bulb if you know what you are looking for.
    I converted my motorcycle lights to HID and got 6000k temp bulbs and love them. I want to convert the prius to 6000k because they appear to be about 4000k, not a blue as I would like.
    I bought a COMPLETE conversion kit from www.xenonrider.com for a dual lamp setup for $199. Mine were H7 lamps, so if I knew what lamp the HID was in the prius this might be a much cheaper way to go and still retain the HID lamps.
    EDIT: I just found that the Prius uses the H4 lamps, and you can get those on the www.xenonrider.com website. The whole kit is $199, but you get two lamps, and ballasts. Sadly I did not see an alternative to just order lamps, but this is MUCH cheaper than anything else I found.
  11. Offline
    icarus New Member
    Apr 12, 2007
    Message Count:
    4,543
    839
    earth
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(dsoprius @ Nov 21 2007, 03:25 PM) [snapback]542658[/snapback]</div>
    Make sure that it is the bulb assy and not the controller. From what I have learned on this forum is that there is a very expensive controler for the lights. If you turn it off and back on, and it comes on it MAY be the controller. (Do a search here for more info)
    Icarus
  12. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    Stock HIDs are usually 4300K. Also aftermarket kits don't come with auto-levelling.
    A kit from Xenon Depot (a company that I trust) will run you about $400.
  13. Offline
    mldoc New Member
    Oct 29, 2007
    Message Count:
    28
    Riverdale, NY
    Your Vehicle Year:
    I hate to say it, but the cost of an HID Lamp is always going to give you some sticker shock. I work with HID lamps of various styles on a regular basis, and our cost as a retailer is typically over $100 (though these aren't automotive lamps). The most expensive ones I use are well over $500. The materials, manufacturing techniques, and precision involved are far more advanced than they need to be for an incandescent lamp.
  14. Offline
    stealth junkie JR member
    May 2, 2008
    Message Count:
    South central valley
    Your Vehicle Year:
    read the owners manual! They say your headlights will go out! When there's power,they'll fire back up!
    Imagine that!
  15. Offline
    sorka New Member
    May 9, 2008
    Message Count:
    647
    Your Vehicle Year:
    The stock temp is 4300K. Why? Because it's the brightest. Going a higher temp may look cool, but they'll be dimmer and they'll cause more glare.
  16. Offline
    a_gray_prius Rare Under-30 Priuschat Member
    Jun 13, 2008
    Message Count:
    2,193
    323
    Chicago, IL
    Your Vehicle Year:
    I was browsing around on LusciousGarage a while back and noticed this blog post.
    Luscious Garage | Hybrid Specialists
    Quote:
    "After ardent research we found a direct source for OEM bulbs (Philips Brand D4R 4300K) for $92 each. We also offer upgraded bulbs that are brighter (Onex Brand D4R 6000K) and whiter in color. The bulbs can be changed from above, without removing anything, in a half hour. Two bulbs installed: $260."
Share This Page
