Any Problems Using A PiP For A Mobile Amateur Radio Station?
Discussion in 'Fred's House of Pancakes' started by Susan4ET, Dec 18, 2014.
  1. Susan4ET
    Susan4ET Member
    429
    52
    Central Oregon
    I have a 2012 PiP and am considering using it with a ham radio mobile--currently a 5 W HT on 2 m and 70 cm bands. I won't be modifying the car in any way nor actually transmitting while moving--I am dead set against the potential distractions.
    I am concerned about how much the XCVR might cause RFI and EMI to the car's various electronics and likewise the interference the car might cause to the HT?
    Thanks.
    #1 Susan4ET, Dec 18, 2014
    WE0H likes this.
  2. GregP507
    GregP507 Senior Member
    3,002
    480
    I've dabbled in ham radio a bit, and I think the key to success is heavy shielding, filtering and a direct connection to a good battery. If you're going high-power, I'd recommend a larger aux battery, or at least an isolated secondary aux battery.
  3. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    RFI shouldn't be an issue. Consider that AM radios in the PiP receive virtually zero RFI. However, if you "stop somewhere" and shut down the car, tapping into the 12V battery for your rig, you'll likely kill the 12V battery pretty quickly. You'll need to stay in READY mode.
    If you remain in READY mode, the next question (I don't know the definitive answer) is whether your rig will interfere with the PiP's systems. Though I doubt that, it would depend on your transmit power, band, etc.
  4. mrbigh
    3,686
    699
    Long Island, NY
    Interesting questions.
    First of then all, you will have to upgrade the Auxiliary (rear) battery. You must utilize the vehicle as a power source in the READY mode, so the internal DC-DC converter will recharge the vehicle when in need.
    I used to use a CB band radio (Prius Gen II) with out any interference whatsoever a while back. Now I use a cell based phone.
  5. GregP507
    3,002
    480
    It would be nice to see a portable battery-pack that could be used as backup surge-capacity for accessories like that, tied into the rest of the system to stay charged, but detachable when you need portable power, either 12V or 120V.
  6. Susan4ET
    Susan4ET Member
    429
    52
    Central Oregon
    I don't like the way I presented this post here nor the way Prius Chat has treated it Off Topic so I have edit out most all of my responses. Best go to the ARRL website and search for 'auto manufacturers policies' and continue the discussion there if it interests you.
    #6 Susan4ET, Dec 18, 2014
  7. GregP507
    3,002
    480
    No worries. There's no conventional alternator as there is in a conventional car. The power is generated by a motor-generator (which technically IS an alternator) however, a DC-DC converter is used to feed power from the hybrid battery to the aux battery, which I believe can supply up to 100 amps (plenty). A battery in parallel shouldn't be needed unless you are drawing a lot of current when the car is off, but it should work fine with a battery isolator. I prefer to use it in ready-mode, because that way, there's always a steady supply of power to the 12V system, and the battery never goes dead.
    #7 GregP507, Dec 18, 2014
    WE0H likes this.
  8. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    I added a PowerPole connector to the 12V battery via fuses. That is all. Everything works perfectly with the car in 'ready' to keep things topped up, no QRM, no difficulties.
    Of course 70cm screws up the locking system royally, no locking or unlocking possible using the fob whilst transmitting. But that applies to all car wireless entry systems. UK frequency for wireless locks is 433.92MHz.
    WE0H likes this.
  9. GregP507
    3,002
    480
    I'm confused.
  10. IanIanIanIan
    IanIanIanIan Member
    152
    56
    2013 Prius Plug-in
    About what?
    WE0H likes this.
  11. GregP507
    3,002
    480
    I don't understand your post.
  12. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    I believe Ian is just noting that his 70cm gear uses the same band as the keyless entry / smart key system, and effectively jams it while in use. The US smart keys seem to use 312-316 MHz.
    As to EMI, I believe that it can be significant (primarily from the inverter) but I believe it is in the 5kHz range? Might be good to put a filter on that. I know early PHEV converters had challenges with their controller's digital com due to the amount of electrical noise, though this may be more of an issue when driving and the inverter is switching hard.
    Rob
  13. IanIanIanIan
    IanIanIanIan Member
    152
    56
    2013 Prius Plug-in
    Ah. Anderson 30A PowerPoles are a propitiatory connector becoming the standard for 12V supplies in the Ham world certainly in the UK. Powerpole® Stackable Connector, Anderson Power Products
    In the UK (and I suspect elsewhere) 433.92MHz is the frequency used for car wireless door locking with transmitted unique codes so a fob will only unlock one car although all use the same frequency to communicate but at extremely low power. 433.92MHz is in the band allocated in the UK for Ham radio use which is 430.00-440.00Mhz. This frequency has a wavelength of approximately 70cm long (0.7 of a metre, 27 inches) and thus the band is known colloquially as the 70cm band or just 70cm.
    Again in the UK someone holding a full licence may transmit on that band using 400Watts. Using that amount of power, or even a few tens of Watts close to the car and that close in frequency just overwhelms the car locking system and it can't read the weak transmission from the key fob so the car won't lock or unlock. I can stand in a large car park and whilst transmitting on ten Watts on a handheld radio disable (but not unlock, no codes) the whole car park's locks.
    We have had whole streets disabled for weeks by illegal transmitters until they are traced.
    Cumberland News | The streets where key fobs don’t work and TVs are on the blink
    I think this was eventually traced to a restaurant's waiter ordering/till system which had been illegally imported from the US.
  14. Susan4ET
    Susan4ET Member
    429
    52
    Central Oregon
    n/t
    #14 Susan4ET, Dec 18, 2014
  15. Susan4ET
    Susan4ET Member
    429
    52
    Central Oregon
    n/t
    #15 Susan4ET, Dec 18, 2014
  16. bisco
    48,945
    lawyers.
  17. rxlawdude
    701
    219
    So Calif
    2015 Tesla Model S
    Yes? ;)
  18. bisco
    48,945
    sorry, there's no more room at toyota.:cool:
  19. rxlawdude
    701
    219
    So Calif
    2015 Tesla Model S
    Somehow, I don't think my legal specialty would match Toyota's needs anyway. Unless they have an in-house pharmacy. :D
  20. hill
    8,064
    mmmmm usually. That'd still be about 300 watts below FCC's legal limit. Not that some folks don't illegally run 2kw - 2kw amplifiers .... yes ... even mobile. Youve seen them .... mobile antenna farms?
    The only thing this guy is missing is a discone - a log periodic, and a screwdriver antenna.
    :D
    But yea ... even on a prius - they're out there. WAY out there. As Forrest Gump used to say, "power is as power does". Most folks typically only have a 2 meter/440 transceiver though - and typically they'll only pull 4 or 5 amps. No big deal.
