1. Offline
    josh2008 Hyundai Tech
    Start a Conversation
    Sep 2, 2008
    363
    132
    Princeton, WV
    Your Vehicle Year:
    Howdy all,
    Looking to reduce the 4x4 offroad ride height off my PiP. Was curious if anyone had messed with lowering yet. Had planned to go full coil overs but don't feel like dropping $800-$1k at the moment. I can still get my employee discount at the Toyota dealer I used to work for...think I will throw a set of plus springs on it and see what happens, curious to see what the added weight does.
    Also coming soon either bronze or gray wheels ;)
  2. Offline
    Tracksyde Member
    Sep 21, 2011
    1,062
    511
    So Cal
    Your Vehicle Year:
    No one that has publicly claimed to do so, not on PC anyway. But there does seem to be some interest. I have a set of Tein Super Streets waiting for me when I have the time. I was concerned with the added weight on lowering springs, since the extra 100 lbs is all in the back.
  3. Offline
    Jozo PIP PIP HOORAY!
    Mar 14, 2012
    145
    26
    Sacramento
    Your Vehicle Year:
    Hmmm...a lowrider PIP...I just finished 'pimping' my PIP with all my add-on stuff, but I think that's it for me.:cool:
  4. Offline
    Aug 14, 2006
    18,099
    3,426
    Sacramento, CA.
    Your Vehicle Year:
    Given the higher weight in the rear compared to a non-PiP I would not use the Plus springs. I would find a spring with a higher tension rate which is progressive like the Eibach ProKit. The Plus springs, IMO are too soft. This is VERY noticeable when going over speed bumps and the ass end bounces. I can only imagine it would be worse in a PIP. I would also try and find out if your OE PIP springs have a higher spring rate than the non-PIP.
  5. Offline
    Sep 2, 2008
    363
    132
    Princeton, WV
    Your Vehicle Year:
    Current plan is to use tein h techs. The plus springs tend to sag the rear already, not a hood place to start. I had tein springs on my 2010 and it sat higher in the rear then in the front, hope it will balance well with PiP. If not a will install rear spring spacers. Tein springs can be had for $136 so I'm not out a whole lot if this turns into a disaster.
  6. Offline
    Totmacher Honey Badger don't give a carp
    Oct 2, 2011
    269
    84
    Mission Viejo, CA
    Your Vehicle Year:
    I asked in a new thred if anyone could get the Toyota part numbers on Gen 3 springs vs Plug in Springs ( Gen III vs PiP Springs part # anyone? | PriusChat ). I have a feeling the springs are the same. If they are my plan was to order up the Prius Plus springs and toss them in over the weekend. I also saw the like Rav4 front swaybar was like 1mm larger and could be had for under 100$.
    I just sold my turbo from my race car so I got 780$ burning a hole in my paypal account that the wife does not know about!
  7. Offline
    Sep 2, 2008
    363
    132
    Princeton, WV
    Your Vehicle Year:
    The spring design is as far as I know the same, however spring rates are supposed to higher on pip vs regular 2012. I ordered tein springs today, will keep everyone posted. Compared ride height today with a 2011, pip sits 3/4" higher in front and 1" higher in rear then a non lowered 2011. Putting lowering springs on pip could get interesting, could see huge drop from just springs, which I am perfectly fine with.
    Tracksyde likes this.
  8. Offline
    Tracksyde Member
    Sep 21, 2011
    1,062
    511
    So Cal
    Your Vehicle Year:
    I didn't know the PiP was actually higher than a no-plug Prius. I've thought it to myself when I saw other Prius, but I thought it was just my imagination. Thanks for the confirmation.
  9. Offline
    Oct 2, 2011
    269
    84
    Mission Viejo, CA
    Your Vehicle Year:
    confirming the part numbers from the Plugin springs to the Gen III springs would answer the question. I called my dealership today and the parts guy was no help at all. He basically had the "if you are not going to order something don't call" attitude.
  10. Offline
    Oct 2, 2011
    269
    84
    Mission Viejo, CA
    Your Vehicle Year:
    Okay so Google wins yet again... My research gives me.....
    NON PLUG-IN
    SPRING, FRONT COIL, RH 48131-47120 2009.04- ZVW30
    SPRING, FRONT COIL, RH 48131-47130 2009.12- ZVW30.. S.. USA Manufacture notes: KOREA SPEC
    SPRING, FRONT COIL, RH 48131-47150 2009.04- ZVW30.. S.. USA Manufacture notes: MEXICO SPEC&TIRE & DISC WHEEL-195/65R15 6J GENERAL COUNTRIES
    SPRING, FRONT COIL, LH 48131-47120 2009.04- ZVW30
    SPRING, FRONT COIL, LH 48131-47130 2009.12- ZVW30.. S.. USA Manufacture notes: KOREA SPEC
    SPRING, FRONT COIL, LH 48131-47150 2009.04- ZVW30.. S.. USA Manufacture notes: MEXICO SPEC&TIRE & DISC WHEEL-195/65R15 6J GENERAL COUNTRIES
    SPRING, COIL, REAR RH 48231-47130 2009.10- ZVW30.. S.. USA Manufacture notes: KOREA SPEC
    SPRING, COIL, REAR RH 48231-47140 2009.04- ZVW30
    SPRING, COIL, REAR RH 48231-47190 2009.04- ZVW30.. S.. USA Manufacture notes: MEXICO SPEC&TIRE & DISC WHEEL-195/65R15 6J GENERAL COUNTRIES
    SPRING, COIL, REAR LH 48231-47130 2009.10- ZVW30.. S.. USA Manufacture notes: KOREA SPEC
    SPRING, COIL, REAR LH 48231-47140 2009.04- ZVW30
    SPRING, COIL, REAR LH 48231-47190 2009.04- ZVW30.. S.. USA Manufacture notes: MEXICO SPEC&TIRE & DISC WHEEL-195/65R15 6J GENERAL COUNTRIES
    PLUG-IN
    SPRING, FRONT COIL, RH 48131-47120 2009.12- ZVW35
    SPRING, FRONT COIL, LH 48131-47120 2009.12- ZVW35
    SPRING, COIL, REAR RH 48231-47240 2009.12- ZVW35
    SPRING, COIL, REAR LH 48231-47240 2009.12- ZVW35
  11. Offline
    Oct 2, 2011
    269
    84
    Mission Viejo, CA
    Your Vehicle Year:
    So my conclusion is the front is identical but the rear is a different part number. So that leads us to assume the spring rates are identical in the front but potentially different in the rear.
  12. Offline
    moviebizman Junior Member
    Aug 11, 2012
    52
    Newport Beach, CA
    Your Vehicle Year:
    Yes this is what I found out today also. :( I've had my PiP for only 3 weeks now, put a XPEL Ultimate clear bra in the front, next was tint, lowering, then wheels, and powder coat wheels, this was going to be my fixed up commuter car.
    Now I have to call and bug Tanabe or Eibach to come up with a kit for PiP. They are both local here but Tanabe's Japan reps only come out a few times a year. Like many others in Southern California I just bought it for continued single occupant carpool lane usage.
  13. Offline
    Oct 2, 2011
    269
    84
    Mission Viejo, CA
    Your Vehicle Year:
    It's only about 50lbs more per corner in the rear. I really don't see it making much of a difference at all. I actually have the TRD springs sitting in my garage with the rear sway bar but because of this heat we have had the past few weeks, I have been way to lazy to install them.
    Maybe I'll knock it out this weekend. The rear looks to be a joke to do and the front not bad at all. I have a local alignment shop I trust that can clean up the front end after they are in.
  14. Offline
    Aug 11, 2012
    52
    Newport Beach, CA
    Your Vehicle Year:
    Hi Totmacher,
    So you're going to do it yourself? And (what nobody, not even the R&D specialist at Eibach could tell me) is the rear fitment the same as a regular 2010 and up Prius? (Shocks and Springs) How much would you charge to install mine? If you can confirm the rears for the 2010 Prius kit will fit on our PiP then Iwill get the Tanabe coilover kit.
    (no kidding - heat wave making me do nothing but spend time in my pool.)
  15. Offline
    genetiix Junior Member
    Oct 20, 2011
    78
    24
    San Jose, CA
    Your Vehicle Year:
    Yeah. I was wondering if you had a chance to try this out as well this weekend? Curious to see if the extra battery weight would be supported.
  16. Offline
    Oct 2, 2011
    269
    84
    Mission Viejo, CA
    Your Vehicle Year:
    Well the Solar guys called me up Friday to install the Solar Power this coming Wednesday, so that threw a kink in my plans as I spent all weekend clearing out my garage. The springs should be relatively simple. I'll gladly help anyone else or do it for them.
    My wife has an 2011 and from what I could tell visuslly looking and paroosing the parts list the rear springs are all that was really different.
    I'll probably hook up the 3D GoPro and do a timelapse of the process.
  17. Offline
    Oct 20, 2011
    78
    24
    San Jose, CA
    Your Vehicle Year:
    Was wondering if you have a chance to install the springs... Also, am curious how big of a solar system you got for your roof?
  18. Offline
    Aug 11, 2012
    52
    Newport Beach, CA
    Your Vehicle Year:
    all done!
    Tein Street Advanced coilover kit / Enkei Raijin 18" / Continental DWS 215/40 / Formula One 15% Pinnacle Ceramic tint / Xpel Ultimate clear bra
  19. Offline
    Aug 11, 2012
    52
    Newport Beach, CA
    Your Vehicle Year:
  20. Offline
    Tracksyde Member
    Sep 21, 2011
    1,062
    511
    So Cal
    Your Vehicle Year:
    Looks good, Movie.. how is the ride (or range of ride adjustment, I guess)?
Share This Page
