1. Offline
    SLO Cat Wrangler Junior Member
    Start a Conversation
    Jan 30, 2008
    86
    San Luis Obispo, CA
    Your Vehicle Year:
    So I was changing my oil at the ~ 15K mark and I was getting to thinking, Why am I putting in 3qts and 3/10 of a quart. Well it dawned on me that this is what you do per the instructions.
    So I also noticed that most people here at prius chat recommend not overfilling which means that you add 3.3qt then adjust as needed.
    So, this is what I normally do, however I note that there is alot of room on the dipstick.
    So could you just add back (after you change the filter) a total of 3 quarts and be safe (Note that this 3 quarts includes any oil that you prime the filter with)?
    This would rid the little left over and make changing oil a little easier.
    Anyone doing this?
    Steve
  2. Online
    jdenenberg EE Professor
    Nov 21, 2005
    2,058
    508
    Trumbull, CT
    Your Vehicle Year:
    I find that 3.5 qts hits the right spot on the dipstick every time. I save the half qt for the next oil change.
    JeffD
  3. Offline
    firepa63 Former Prius Owner
    Jul 23, 2005
    1,761
    192
    SE Pennsylvania
    Your Vehicle Year:
    3.5 quarts is the right amount to use!
  4. Offline
    morpheusx Professor Chaos
    Mar 6, 2007
    1,540
    60
    Akron, OH
    Your Vehicle Year:
    You can get away with 3 just quarts. 3 quarts will put you exactly halfway between the "safety" marks on the dipstick. I usually stretch 2 (5 quart jugs) from wal-mart into 3 oil changes.
  5. Offline
    blazer_5154 Heh, you said "member"
    Dec 9, 2007
    106
    Maryland
    Your Vehicle Year:
    I've been doing this since the beginning with no ill effects that I have noticed. Granted, I have only done about 4 oil changes so far, but it seems to work well for me.
  6. Offline
    Mar 27, 2004
    7,634
    836
    United States
    Your Vehicle Year:
    55 months, 33,000 miles, exactly 3 quarts every six months. If the engine explodes someday I will certainly post about it :_>
  7. Offline
    Priusaurus110 New Member
    May 8, 2007
    30
    Lompoc, CA
    Your Vehicle Year:
    This is exactly what I do at each oil & filter change. 3 qts puts me halfway between the high and low marks which is safe and creates no problems.
  8. Offline
    skruse Senior Member
    Apr 6, 2004
    1,421
    Great Central Valley, Fresno, CA
    Your Vehicle Year:
    3.5 quarts + Mobil 1 ("double") oil filter filled with oil at every oil change (now at 35,000).
  9. Offline
    TucsonPrius New Member
    Mar 9, 2004
    160
    Tucson, AZ
    Your Vehicle Year:
    After my third or fourth oil change I realized that it was too much trouble to worry about the extra 0.3-0.5 quart. So from then on 3 qts; oil level ends up right where its supposed to be, not too much, not too little, exactly in the middle.
    Thanks,
    Shawn
  10. Offline
    narf Member
    Mar 15, 2005
    571
    Colorado
    Your Vehicle Year:
    yup, same here. 3 quarts gets me right in the middle of the high and low marks on the dipstick.
  11. Offline
    Apr 9, 2007
    1,531
    70
    Virginia
    Your Vehicle Year:
    Thats what I've started doing. No more trying to stop at exactly .5 of a quart. No more guess-n-check with the dipstick + pouring more.
    Saves oil. Less waste.
  12. Offline
    eagsc7 Geocacher
    Jul 23, 2008
    44
    Spokane, WA
    Your Vehicle Year:
    Its a GOOD thing that I read this board. Yesterday, I changed the oil, and knowing that it was a 1.5L engine(Much smaller than the V6 that our Grand Prix had), I only grabbed 2 qts of oil. Changed the oil, installed the EBH, and didn't even think about checking the dipstick. Come on I only put in 1.5 qts, and it should be good...
    Read the board, and started thinking... Hmm, I guess it dosen't hurt to check the dipstick. After a good long look in the mirror, I realized that 1.5 Qts does NOT equil 1.5L. Of course, I threw in the other 1.5 Qts of oil and then pulled the dipstick out and YEAH... Its Perfectly centered between the dots...
    Thanks for the Wake-up Call.
  13. Offline
    Apr 9, 2007
    1,531
    70
    Virginia
    Your Vehicle Year:
    1.5 L = engine displacement inside the cylinder. (oil does not go inside the cylinder).
    Good catch :p
  14. Online
    Mar 8, 2008
    10,458
    2,398
    Your Vehicle Year:
    Since the Prius engine normally does not use any appreciable amount of engine oil, this practice of using 3 quarts is OK. However as the car ages, if your engine develops a gasket leak or is burning oil, then you have less safety margin to work with.
  15. Offline
    Mar 27, 2004
    7,634
    836
    United States
    Your Vehicle Year:
    True, one should check the oil at least monthly in any case, to catch any increase in oil consumption.
Share This Page
