Are my headlights adjusted correctly?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mediahound, May 4, 2014.
  1. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    Does it look like my headlights are the right height? I adjusted them so that they are generally about half way up trunk of the car in front of me.
    Video:
  2. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Looks Ok to me but your dealer can check.
  3. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    The only way you can tell is to follow the proper procedure which is pretty darn simple. You can't adjust them by eye.
  4. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    Here ya go...
  5. Razor68
    Razor68 Junior Member
    Philadelphia PA
    thanks for this - my Prius headlights are not lighting up the road and I suspect are set too high. I am confused by the H line. I that initially set from 1' away? and then checked at either 25' or 10' away ( your file states 4" above or below a line drawn 2" below the H line ). I'm not totally following this. in short, do I mark my H line from 1' away, then draw a line 2" below that, then attempt to adjust the beams accordingly ? ( eg: 4" above/below the line that is 2" below the H line if 25' away). sorry for being a bit thick but this is just not clear to me.
  6. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    Basically, you want to make sure that the beams are not rising as they project outward. So if you measure the height of the center of the headlight lens, the cut-off line should be a few inches below that height at 20 feet.
  7. Mendel Leisk
    38,247
    Do you recall: which direction did you adjust them?
  8. xliderider
    7,848
    3,102
    Honolulu, HI
    This thread is 3 yrs old. ;)
    You may not get a reply from the OP...
  9. Mendel Leisk
    38,247
    Good point lol.
    hdprius likes this.
