Auto roll windows up when lock from remote...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by hcarddss, Nov 19, 2014.
  1. hcarddss
    hcarddss Junior Member
    Hello Guys.
    Is there a way to mod the automatic windows up and down. What I mean is that If i arm the alarm with remote, all four windows will automatic roll up. The honda accord has the function which will roll down the windows by the remote before you enter.
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    You use the phrase "is there a way" and the answer to that is always "yes, if you spend enough time and money" but it is not a stock feature. Why would you have the windows down? It is almost always better to use A/C.
    WilDavis likes this.
    48,945
    i think someone diagrammed it out here, pretty successfully. it's just a matter of finding the lock button wire in the door panel and crossing to with the window wire, iirc.
  4. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    May I ask why I should use the A/C when it's 74 degrees with 11% humidity out right now? Is this one of the "almost always" situations? I'm still confused on when it's considered okay NOT to use the A/C.
  5. bisco
    48,945
    under 40mph.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Many owners buy a Prius for Gas Mileage, above 35 MPH, wind resistance from windows down exceeds the A/C compressor power drain.
    Both the 12 volt and big batteries are cooled by the A/C, never 'tough it out' to save gas, use the A/C.
    James Powers likes this.
  7. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    After market alarms have had this feature for decades. It's a simple mod for a car stereo shop.
  8. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    Ok, I see your point now, I wasn't thinking in terms of mpg. Thanks.
  9. hcarddss
    Sometime, I have passengers who always roll down the window even the AC is on (why? no idea). As parking, I don't usually check for closing windows.
  10. hcarddss
  11. hcarddss
    Thank. I am looking for it now.
  12. bisco
    48,945
    good luck searching, i tried, but it's not the easiest thing to do here.
  13. hcarddss
    Did you find what you want?
  14. bisco
    48,945
    no, i'm almost positive i read about the window mod, but if it was done prior to the new priuschat software cutover, it may be lost.
  15. obanster
    obanster New Member
    Bay Area
    Now you can just purchase on OBD2 module that will allow for auto window roll up when it locks, and window roll down capability with 3 disarm clicks from the factory remote. Just look on eBay/Google. I think their around $70. Mine works awesome and took seconds to install in the OBD2 port.
    Burna J likes this.
  16. Jchoi808
    Jchoi808 Member
    30
    25
    Mililani, HI
    2018 Prius Prime
    I just recently bought the OBD2 module that allows you to open and close your windows from your remote. Was a simple install, just plug it in and leave it. Check out the hybridpit website. Sorry I'm too new, unable to leave links.
    James Powers and m3pare like this.
  17. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
  18. Dreamerzcc
    Dreamerzcc Member
    67
    82
    Hoover
