Automatic car wash
Discussion in 'Prius c Main Forum' started by carolD, Sep 1, 2015.
  1. carolD
    carolD Junior Member
    82
    florida
    2015 Prius c
    will the Orius C do ok going through a automatic car wash.
  2. NuttyKat
    NuttyKat Member
    70
    49
    Eastern NC
    2014 Prius c
    I have taken mine through an automatic carwash. The only problem I had the last time I did it, they had installed blowers and it really does rock the car a bit. Not sure I would choose the option that had the blowers drying the car. Otherwise it did fine.
    48,862
    make sure you have at least 1/2 charge in the battery. what is an orius?
  4. fuzzy1
    10,013
    Some owners have problems with the traction battery getting too low while using AC in hot weather.
    For best results, either don't use AC very long, or make sure the traction battery is well charged before you must shift into Neutral. This is discussed in numerous threads in the regular GenIII forums.
    If you have a standard QWERTY keyboard, check which letters are adjacent to 'o'
  5. fuzzy1
    10,013
  6. bisco
    48,862
    irius?:cool: oh wait, not qwerty.
  7. AliIzad
    AliIzad Member
    170
    72
    Southern California
    Some have complained that the roof has partially collapsed/pushed in. Some have said it was a permanent dent, some said they heard the roof give and pop back out. But, these claims were in regards to the PriusC.
  8. bisco
    48,862
    as long as water doesn't come in, no prolemo.
  9. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  10. bisco
    48,862
  11. Motov8r
    Motov8r Member
    102
    My C has survived a few automatic car washes. Your wash may vary.
    iPhone ?
  12. carolD
    82
    florida
    2015 Prius c
    Sorry meant Prius
  13. apablo
    apablo Junior Member
    Ventura County
    2014 Prius c
    The automatic car washes with the automatic dryers always lift my windshield wipers up. I've only used them twice and have not returned since then.
  14. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    Just make sure your battery is pretty well charged since you put the car in Neutral when going through the wash and the battery does not charge in N.
  15. Xterra72
    Xterra72 Senior Member
    1,361
    1,635
  16. carolD
    82
    florida
    2015 Prius c
    Thank you.
