1. Offline
    phantom5251 New Member
    Start a Conversation
    Mar 14, 2010
    Ohio
    Your Vehicle Year:
    Hi all, I have the factory stereo, no navigation, etc. To my knowledge, it's bare bones. But like many, would like to get an AUX input unit, or somehow be able to control the iPod/iPhone through the car stereo. Since there's many products that have been out there, was just wanting to do my homework to see what people's best experiences have been? USA Spec? DICE? Trying to stay under $200 if at all possible. Thank you in advance!
  2. Offline
    Aug 14, 2006
    18,296
    3,520
    Sacramento, CA.
    Your Vehicle Year:
    The DICE unit from the Prius Chat Shop works well.
    Otherwise just install a new stereo! :D
  3. Offline
    Mar 14, 2010
    Ohio
    Your Vehicle Year:
    Is the DICE unit a pretty easy self install?
  4. Offline
    Aug 14, 2006
    18,296
    3,520
    Sacramento, CA.
    Your Vehicle Year:
  5. Offline
    Mar 14, 2010
    Ohio
    Your Vehicle Year:
    Hmmm, the reviews for it on the PriusChat site seem about so-so...anyone have any opinions on the USA Spec product? Is it even possible to get an actual new head unit that would fit with the dash? I.e. Sony, Pioneer, JBL, etc? I was into BestBuy and they were trying to plug the iSimple to me, I guess because installation was free with that?
  6. Offline
    Aug 14, 2006
    18,296
    3,520
    Sacramento, CA.
    Your Vehicle Year:
    USA Spec makes a decent product as well.
    Yes, the stereo would fit. ;)
    http://priuschat.com/forums/gen-ii-...alth-install-aftermarket-stereo-in-prius.html
  7. Offline
    Mar 14, 2010
    Ohio
    Your Vehicle Year:
    Nicely done! Would a place like BestBuy be able to do something like this as well, or would they probably jack up the cost?
  8. Offline
    Aug 14, 2006
    18,296
    3,520
    Sacramento, CA.
    Your Vehicle Year:
    It's a simple install for any decent stereo installer. They just might not know about it. You can go in and ask them and show them pictures. It is the same as any other install only you use 2 wiring harnesses.
    If you decide on a shop to do the install, I would be more than happy to talk to the installer to clarify how I did it if needed.
  9. Offline
    Mar 14, 2010
    Ohio
    Your Vehicle Year:
    Hmm...yeah, in looking at BestBuy's site, it almost looks like it's a cheaper install to just get a new stereo versus something like DICE etc. When you did your install, are you still able to use the steering wheel controls for volume, et al? Thanks for all your advice with this!
  10. Offline
    Aug 14, 2006
    18,296
    3,520
    Sacramento, CA.
    Your Vehicle Year:
    I chose not to use the steering wheel controls. I would have to uy another device to do so. Usbseawolf2000 did a write up on installing a double DIN unit in place of the factory stereo and he wired up the device to keep the steering wheel controls. You might check out his thread.
    http://priuschat.com/forums/gen-ii-...pgrade-head-unit-kenwood-excelon-dnx6960.html
  11. Offline
    Mar 14, 2010
    Ohio
    Your Vehicle Year:
    If I did do a device like the DICE, Vais, USA Spec, etc, is it pretty hard to get at the back of the factory radio? It looks like some have said it's just a matter of removing the glove box and another component? Similar to replacing the cabin filter?
  12. Offline
    Oneaxepony New Member
    Feb 20, 2009
    60
    Northeast Ohio
    Your Vehicle Year:
    Assuming the 2005 is similar to the 06-09 models, you can theorectically get to the CD changer plug on the back of the radio by removing the glove box and the trim panel to the right of the radio (it has a vent in it). But..there is a block with dozens if not hundreds of wires which you will have to loosen and push out of the way. Even then, it is very cramped spacing. Once I realized this I bit the bullet and learned how to remove the dash panels to get the radio out. There are instructions and even videos around which show you how to do this. If you are handy enough to remove the glove box and the trim piece you can almost certainly do this. By going this route you will have a lot more options about where to put the new device and where to bring out the wiring. Good luck.
  13. Offline
    Mar 14, 2010
    Ohio
    Your Vehicle Year:
    Has anyone with a 2005 Prius had much luck just putting a new unit in? I.e. Sony, JBL, Kenwood, Pioneer? Does it sound better?
  14. Offline
    Aug 14, 2006
    18,296
    3,520
    Sacramento, CA.
    Your Vehicle Year:
    I posted links on that type of upgrade on page 1.
  15. Offline
    sktn77a Member
    Apr 28, 2007
    270
    NC
    Your Vehicle Year:
  16. Offline
    theducks New Member
    May 22, 2010
    Vancouver
    Your Vehicle Year:
    I installed the DICE in a 2005 Prius. It's pretty easy, even to get to the back of the stereo, and I have big hands. Hardest part was moving the big white box under the airvent that all the wires plug into. Got it out and back in eventually though.
Share This Page
