1. Offline
    captainron042 New Member
    Start a Conversation
    Dec 16, 2009
    corpus
    Your Vehicle Year:
    I recently purchased a 2006 prius, which is apparently the base model. It does not have satellite radio, GPS, or CD changer. I checked for the "hidden" AUX input I was told was in all 2006 models, but it is not there. There's an AUX power recepticle, but no audio jack.
    With the complexity of the prius (which I'm very new to), I am hessitant to just buy what I've done for so many other cars I've owned and expect it to work. I'm hoping somone else here has some input for me.
    Two products I've found say they are compatible for the 2006 prius, but say that there needs to be a SAT button. I have only the PWR button where the CD slot is, then the Vol and Tune knobs with Seek/track, AM, FM, Disc, and Scan buttons between. Does anyone have the experience to know if this still work, and be able to be controlled by the VOL buttons on the steering wheel?
    Products are "PIE TOY03-AUX/s Toyota Aux Adapter" and "Grom A-TOY-N Toyota Lexus Aux RCA Adapter" (won't let me post links yet)
    Also, I've noticed that the Vol and Tune knobs can be detracted into the dash so that they are flush with the surface. Usually, this would be to power on/off the radio, but pushing them in and out seems to have no effect on anything. What's the deal with this?
    Thanks for helping!
  2. Offline
    juzernev New Member
    Nov 27, 2009
    Hungary
    Your Vehicle Year:
    I got same head unit in my 06.
    I will try to install my dension icelink 300 if i found a right cable.
    I will check back with the result.
  3. Offline
    Boo Boola Boola Member
    Feb 13, 2007
    5,047
    442
    Flushing, NY
    Your Vehicle Year:
    Hi Ron,
    I can't offer advice about installing an auxiliary audio jack or anything else that will accomplish the same thing, but FYI an auxiliary audio jack was not standard on the 2006 Prius. In fact, it was not standard on any model year of the Gen II Prius. What was standard were the two 12V auxiliary power outlets.
    I think whoever told you that "AUX" audio was standard was confusing the optional auxiliary audio jack with the standard 12V auxiliary power outlets.
    Anyways, good luck on your desired modification. I could be wrong, but I think there are a lot of threads here about it. So doing a search might be worthwhile.
  4. Offline
    Ophbalance New Member
    Sep 16, 2009
    205
    16
    North Carolina
    Your Vehicle Year:
    No, I believe the 07 is the lucky lottery winner for always having the AUX input. It was one reason why I was on the hunt for just 07's for a while.
  5. Offline
    Feb 13, 2007
    5,047
    442
    Flushing, NY
    Your Vehicle Year:
    No, not 07. I have an 07, and AUX audio jack was included in option package #1 and up. Again, AUX audio jack has never been standard equipment. I believe it was 2006 when it was first made available in option packages.
    EDIT: I believe this is the full history of the AUX audio jack's availability in the Gen II:
    2004 - Not Available
    2005 - Not Available
    2006 - In Option Package #2 and up
    2007 - In Option Package #1 and up (although it might have been difficult, if not impossible, to find a base Prius with no Option Package on it)
    2008 - In Option Package #2 and up
    2009 - In Option Package #2 and up
  6. Offline
    Sep 16, 2009
    205
    16
    North Carolina
    Your Vehicle Year:
    Well, that was kinda my point ;).
  7. Offline
    Oneaxepony New Member
    Feb 20, 2009
    60
    Northeast Ohio
    Your Vehicle Year:
    I have a base model '07 that does not have factory Aux. I added a GROM USB2 (gromaudio.com) which gives me aux, iPod, and USB (i.e. memory stick) integration. You can get one with just Aux if you want. Your radio should have an unused CD changer port on the back which is how the Grom unit connects. Other companies also have Aux units which work the same way. I tried searching this forum using the word Aux and incredibly it finds no matches. Using the word Grom (or DICE) it finds many matches. I suggest you try this as you will find user experience with many of these products. Its always a good idea to contact the vendor to verify their unit will work with you car. Good luck.
    1 people like this.
Share This Page
