(B) braking.
Discussion in 'Gen 3 Prius Technical Discussion' started by Caug1, Jun 12, 2011.
  1. Caug1
    Caug1 Member
    119
    BOSTON
    I ve been using B for braking. it works fine for me, but should i use it all the time?
    Would it heart the car in any way?
    Please let me know.
    Thanks,
    C
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    It won't hurt your car, but it will hurt your MPGs. Use the 'B' only when going down long hills. Otherwise, use your regenerative braking to slow the car. The friction brakes don't come into play until about 7 mph.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    The B-mode (engine braking) runs the ICE without fuel to act as an air pump to slow the car. It will never hurt the engine to do this.
    As stated above, the main purpose for this is for going down long downgrades. After the battery gets fully charged in regen, it will stop taking a charge and kick out regen. You will have to use either the friction brakes or B-mode. This is when B-mode is most effective.
    Having said that, I like to use B-mode every now and then when going around corners. It reminds me of downshifting in a manual.
    48,862
    i have never used B in 8 years. what would posess you to do that?
  5. JGC61
    JGC61 Active Member
    214
    101
    Long Island
    I have been using the B mode to slow down at highway speeds.
    Most times I can slow down without using the brakes and charge the battery at the same time.
    Just remember to shift back to Drive or your economy will be suffer.
    Have been getting at least 50 MPG and many times more.:D
  6. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    Well, just maybe, when one is following a long downgrade, it makes sense, just like down-shifting.:attention:
    Huh? Maybe? Ya think?:eek:
    Sheesh!:eek:hwell:
  7. bisco
    48,862
    not in this part o the country. never downshifted in any automatic i've owned around here. havn't been out to the rockies.
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    If you want to slow down and charge the battery, press the brake pedal. Using B mode throws away energy that would otherwise go into the battery.
    Tom
  9. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    And again, B mode is less fuel efficient than normal braking, it is poor at recharging the HV Battery. Just think what your mileage could have been if you did not use B mode.
  10. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    More flat-lander jibberish.
    In the mountains, "B" recharges the battery just fine.
  11. bisco
    48,862
    maybe, but caug is from boston.
  12. Caug1
    Caug1 Member
    119
    BOSTON
    I thought, by using ( B ) it will charge the big battery more, which i use for pulse & glide, more juice it gets more gliding i can get out of it, right?
    why my mpg will go down by using it?
    The last tank of gas @51.50 corculated vs. 52.50 on display. once drove with 6 people all night from bar to bar. Also had a couple of 100mph runs. Basically drove it like i stole it. didn't in really baby the car on last fill up.
    Thanks,
    C
  13. bisco
    48,862
    i am speechless.
  14. Prius-it
    Prius-it Junior Member
    39
    Baltimore
    One thing I found useful is using ( B ) braking when I need to brake hard. Engine braking like characteristic helps the car stop much faster/shorter distance.
    Caug, just think of B braking as engine braking. If you put a Prius on a B mode and drive, the car will put RESISTANCE against the car going forward.
    Another example would be....Prius's drag coefficient being lower, allowing less wind RESISTANCE against the car, thus assisting in the car's fuel efficiency (the car doesn't have to work harder to move).
    I don't have any technical background/document to back this up. This is solely based on my assumption using my common sense. So...I could be wrong. :)
  15. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    He lives on Long Island. You point out the mountains on Long Island and I will retract everything I said.
    I have consistently praised B mode on hills with more than a 600 foot drop.
    http://www.oregon.gov/ODOT/MCT/docs/EmigrantHill.pdf?ga=t
  16. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    B mode substitutes engine braking for a portion of regen braking. Better to use the brake pedal for greater regen EXCEPT where the slope is long enough to fill the battery before reaching bottom.
  17. Caug1
    Caug1 Member
    119
    BOSTON
    Cool thanks to all, but still dont understand ,why it should hurt mpg.
  18. ksstathead
    1,244
    243
    Kansas
    It hurts mpg when you spin the engine instead of putting more of that energy back in the pack. Spinning the engine requires energy. Recharging the pack requires energy. The kinetic energy of the moving car is fixed at a point in time, so it is a zero sum game. That which goes to spinning the engine cannot go to the pack. The brake pedal does not spin the engine unless the pack is full.
    B on long descent is not a problem since the pack gets full by the bottom anyway.
  19. Caug1
    Caug1 Member
    119
    BOSTON
    So to get better mpg i should not use it at all, right?
    Then why bother with long down hills in B mode, if i could use brakes and it will not hurt the mpg?
    I think we should use it Only in the snow storm going down hill, right?
    The only useful/safety place to use b mode.
    c
  20. qbee42
    18,058
    3,073
    Northern Michigan
    Think of it like this: If you tie an anchor onto the bumper of your Prius and drag it around, will it help or hurt mileage? B mode is like tying an anchor to your car. It deliberately wastes energy. That is its one and only use, to toss away excess energy.
    Your Prius recaptures energy during standard braking, which is why it is called regenerative braking. In B mode it recaptures *less* energy.
    Tom
