1. Offline
    fstickel New Member
    May 21, 2007
    22
    Greensboro NC
    Your Vehicle Year:
    Just put on my new Barcelona Red side moldings last week on my 07.
    They look -- fair. - -Why you ask?
    Well, whoever put on the 3M trim tape onto the door side moldings must have touched the last 2 inches of the tape on ALL the tapered ends of the moldings. NONE of which stuck. 1 maybe, -- but 4 ?
    Had to go out and buy a $9 roll of tape to cut 4 small triangles to slip under the tip of all 4 tapers, leaving a gap between the molding strip and the door.
    Looks OK from the sides but I notice it everytime I get in on the drivers side and look down. Slight air gap.
    I should have been suspicious when I opened the package and saw that the was white masking tape taped to the 3m backing strip over each tapered nose, thought they were there to help you seperate the backing from the tape without touching?? Don't know why they were there.
    End of roll?
    I started 1 foot or so from the square end and peeled the tape off going forwards, being careful NOT to touch the tape, as I knew it would not stick with skin oil on it.
    The strip areas was cleaned with the prep pads and activator as instructed, and 99% of the moldings stuck great.
    Definite problem with these strips. I know the paint was cleaned OK as the rest of the tape stuck like it was meant to. Naturally, I chose to leave the strips in place since taking them off would have made damage.
    The door moldings look great and were finished perfectly, but not having ALL of the tapers not stick make me think the whoever makes these for Prius Shop needs to do some changes.
    Be warned folks.:confused:
    flintlock
  2. Offline
    Boo Boola Boola Member
    Feb 13, 2007
    5,086
    602
    Flushing, NY
    Your Vehicle Year:
    Sorry to hear that flintlock. I think yours is a rare case. It's the first time I've heard of it happening.
    I don't know what your remedy would be.
    I do know that a good body shop should be able to remove the moldings and reinstall them perfectly. I know of one PriusChatter who installed his moldings slightly crookedly, and his body shop was able to remove them and reinstall them correctly.
  3. Offline
    texdon New Member
    Jul 13, 2008
    26
    central Texas
    Your Vehicle Year:
    I ordered the side molding from Prius shop and installed them myself last weekend. I peeled from the non tapered end to the pointed end and did not realize till I was through with the first of 4 molding that I had not removed the last 2" of tape covering and the tapered end was not sticking. I pulled the tapered end back while my wife took off the paper with a tweezers. The other 3 I had no problem installing. They have been sticking well with wind and washings. I would suggest that the instructions add to take off both pieces of paper. I did not see the perforation and just took off the masking tape and thought I had taken all the paper off as I was concentrating getting the other end lined up where the doors connect.
    The masking tape method they recommend is not perfect, there was a slight sag in the middle (1/4 ") so I strung a tight string across the measuring points (tying the string to some steel post I pounded into the ground) and they are installed perfectly straight!
    I'm very satisfied with the side moldings and can now park next to that Large SUV comfortably!:D
  4. Offline
    fstickel New Member
    May 21, 2007
    22
    Greensboro NC
    Your Vehicle Year:
    texdon,
    Interesting that you noticed the same masking tape thing.
    Wonder why they do that ?. Thanks for letting me know I'm not
    the only one to see this problem from Prius Shop.
    I used the tape method and it worked very well.
    The strips look good from the side.
    flintlock
  5. Offline
    fstickel New Member
    May 21, 2007
    22
    Greensboro NC
    Your Vehicle Year:
    texron,
    Ok, -- read your reply and sat here thinking -- " Did I remove the end pieces of tape, or did I do a stupid on all 4 tapers ???? "
    Good news, I did not do a stupid. all pieces of 3M cover tape are off.
    The tape DID NOT stick. - Whew, -- thought it was me for a minute.
    I have enough senior moments as is.
    Still looks lousey though.
    flintlock
  6. Offline
    texdon New Member
    Jul 13, 2008
    26
    central Texas
    Your Vehicle Year:
    I think the masking tape is there to warn you that after you pull the paper backing off, the last two inches of paper backing also need to be taken off. A note in the instructions would have made me look for it and take off all the tape and not have to mess with tweezers.
    The instructions suggest taking off a foot of backing at a time and with the backing against the car you really can't see that the last 2" is still there until you notice the end does not stick.
  7. Offline
    texdon New Member
    Jul 13, 2008
    26
    central Texas
    Your Vehicle Year:
    Hmmm, those end pieces are hard to take off and hard to see once the tape and retape are on.
    I was thinking how hard those end pieces were to take off without touching the backing and you must have been having a senior moment (been there done that) today not remembeing taking them off. Might go back for a second look. :D
  8. Offline
    Prius77094 New Member
    Jun 5, 2008
    32
    Houston, Texas
    Your Vehicle Year:
    I did the exact same thing today. The instructions should have a warning. How hard is it to add "Don't forget to peel the small, individual tape backings at the billet ends!" The instructions actually do more harm because it tells you to peel the backing as you install the moldings, so your peeling without seeing the backing. If I had just peeled off the backing before starting the install, I would not have missed the little pieces of backing at the billet ends. Damn. It should have been a seamless operation. Now I'll try to dig back and peel the little individual tape backings off, trying not to touch anything.
    [IMG]
    [IMG]
    [IMG]
  9. Offline
    Jun 5, 2008
    32
    Houston, Texas
    Your Vehicle Year:
    Fixing it wasn't as hard as I thought it would be. I slid a piece of paper behind the molding where it wasn't sticking, to protect the paint from my tweezers and scissors. I used a small pair of nail scissors, which are very sharp, to poke at the adhesive and to get the backing lifted off the tape a little. Then I used tweezers to pull the backing off, being careful not to touch the adhesive tape. Took about 5 minutes to do all 4.
    I used "Oops" adhesive and tar remover (available at Ace Hardware) to remove the Pro-Bond Adhesive Promoter that accidentally dripped down the door and which dried instantly! (I squeezed the paper tube too hard). The adhesive remover is a toluene based product that removes anything from an automotive finish, without removing the finish or the clear coat.
    The door moldings look good, I'm happy:)
  10. Offline
    • Admin/Founder
    Danny Admin/Founder
    Nov 24, 2003
    6,083
    827
    Charlotte, NC
    Your Vehicle Year:
    I'll pass along all of your comments to the manufacturer to see if they can make the directions a bit more clear. I had the same "Doh!" moment when I installed my first molding and then realized I needed to be sure to remove the last 2 inches of tape before putting them on the car.
    If you are having problems with yours, please drop me a PM and I'll be more than happy to see if there's anything we can do to help or I'll put you in touch with the manufacturer.
Share This Page
