1. Offline
    Gaprofitt New Member
    Start a Conversation
    Mar 27, 2008
    28
    Atlanta, GA
    Your Vehicle Year:
    Hi All,
    When I first turn on my 2007 Prius there is a bad smell from the a/c, it goes away after about 5 secs. I checked the cabin filter and it looks and smells fine, anyone else experience this?
    Thanks,
    Greg
  2. Offline
    seasalsa Active Member
    Feb 29, 2004
    1,278
    Kent, WA
    Your Vehicle Year:
  3. Offline
    edthefox5 Senior Member
    Jul 25, 2007
    2,457
    399
    Clearwater, Florida
    Your Vehicle Year:
    I got excited when I saw your header. I thought that maybe Toy finally put out a TSB for this problem. Your in the wrong forum. Post this in the "Care-Maintenance" forum. If you want to see alot about your problem search my old posts.
  4. Offline
    kazots LifesaBeach
    Apr 10, 2008
    262
    CALIFORNIA
    Your Vehicle Year:
    You could always go to the "search" box to ask your questions.
  5. Offline
    javadanno New Member
    Mar 28, 2009
    Leesburg VA
    Your Vehicle Year:
    I had this problem and it is caused by moisture (condensation) in the AC system. Set your AC to 72 degrees or higher and the problem should go away. It has for me.
  6. Offline
    fayeweezer New Member
    Jan 17, 2010
    sacramento
    Your Vehicle Year:
    You may also want to change your cabin air filter and have the air conditioner system serviced. It may be a large problem if not taken care of right away.
  7. Offline
    Apr 9, 2007
    1,531
    70
    Virginia
    Your Vehicle Year:
    There is also a [low] possibility that some critter died inside your car vent system.
    edit: oh wtf this thread is old.
  8. Offline
    Bear68 Member
    Mar 9, 2007
    373
    66
    West Palm Beach, FLA
    There is now a TSB applying to 2007 – 2010 Camry, Camry HV
    2004 – 2008 Prius which involves replacing the evaporator core. T-SB-0261-09 August 6, 2009
    HVAC Odor.
    1 people like this.
  9. Offline
    deeno New Member
    Mar 9, 2010
    17
    Your Vehicle Year:
    Wow thank you! Found more info about it here:
    T-SB-0261-09 August 6, 2009 HVAC Odor - Toyota Forums :: Toyota Nation
    Looks like it's covered under the 3yr/36k warranty and I barely qualify still. Hope to get this fixed ASAP!
    1 people like this.
  10. Offline
    2009Prius A Wimpy DIYer
    Mar 25, 2009
    2,468
    382
    Your Vehicle Year:
    Might as well quote the content here: :)
    from
    http://www.toyotanation.com/forum/showthread.php?p=2909862
  11. Offline
    Supreme Hypebeast
    Apr 27, 2010
    174
    Philly
    Your Vehicle Year:
    Had my evaporator replaced under this TSB. Smell is starting to come back again. I might just get rid of the car at this point.
  12. Offline
    Mar 25, 2009
    2,468
    382
    Your Vehicle Year:
  13. Offline
    ryogajyc Active Member
    Aug 30, 2004
    956
    153
    Reseda, CA
    Your Vehicle Year:
    My A/C had a sour smell too b/c I use to force it to recirculate the air even when Auto mode chose fresh air. Toyota service explained to me that fresh air needs to be used every so often keep the system from retaining moisture, leading to mildew.
    When the smell occurred, switching to fresh air for a minute would clear up the problem for a little while. I changed my habits to allow Auto mode switch to fresh air as it wishes and eventually the problem went away for good.
    mfa-prius likes this.
  14. Offline
    mfa-prius Old member
    Jun 4, 2005
    184
    17
    Polk City, FL
    Your Vehicle Year:
    I do the same, thinking that in my humid climate it's silly to keep sucking in fresh humid air. I also have the smell, but all the dealer ever did was recommend changing the cabin air filter every few months. Thanks for the tip.
Share This Page
