1. Offline
    findlj Junior Member
    Start a Conversation
    Aug 9, 2006
    42
    Hello,
    I've got an '06 Prius with 100K miles. I bought the car new in '06. The car runs great and is getting some of the best mileage it ever has. No worries there.:rockon:
    However, for the last several months, I now find my battery will show as drained when I first start it for the day. This did not use to be the case. It charges fine and runs great. I'm not aware of anything I've left on that could be draining the battery.:confused:
    Has anyone else experienced this and is there a fix, or is this normal with the mileage of the car and nothing to be concerned about?
    Thanks for your help in advance...
  2. Offline
    jdcollins5 Senior Member
    Aug 30, 2009
    3,272
    648
    Wilmington, NC
    Your Vehicle Year:
    You need to replace your 12V auxilary battery now. There are many, many threads on here about the life of a Prius battery.
  3. Offline
    andyprius New Member
    Feb 21, 2005
    2,181
    157
    Sacramento, California.
    Your Vehicle Year:
    It is unclear as to which batteryyou are talking about? The HV or the 12V?
  4. Offline
    Aug 9, 2006
    42
    The 12V battery has been replaced last year. The fact that there are many threads about the life does not answer the question. The car runs fine, it's just that the Hybrid battery shows low when it's first started.
    So I'll refer back to my original question...
  5. Offline
    Aug 9, 2006
    42
    It's the HV battery I'm asking about. The car starts and runs fine. I replaced the 12V last year.
  6. Offline
    uart Senior Member
    Sep 7, 2009
    2,771
    478
    Australia
    Your Vehicle Year:
    Hi findjl. Do you know if the battery SOC (state of charge) has already dropped immediately when you make it ready, or if it just drops rapidly in the first few seconds after starting or when you start driving. If you're not sure then try watching the SOC monitor very carefully from the moment you start up and let us know.
    BTW. What sort of drop in SOC are we looking at? One or two bars, or even more? Give us an indication of the typical before and after SOC levels.
  7. Offline
    • Moderator
    efusco Troll Slayer
    Nov 26, 2003
    19,828
    1,032
    Nixa, MO
    Your Vehicle Year:
    Yes, please define "drained" as in are you looking at the Energy Screen battery level and documenting what it is when you shut down and then the same in the morning?
  8. Offline
    Aug 9, 2006
    42
    You know, I'm not certain if it's immediately low or drops immediately. I'll look for that and get back with you. Thanks for the reply!:)
  9. Offline
    Aug 9, 2006
    42
    I know that the level can be much lower at first startup than when I shut the car off the evening before. But, I do need to check if the level does drop immediately upon startup as opposed to being very low (0-2 bars) at startup (see next previous post) . Thanks for your help!:)
  10. Offline
    Feb 21, 2005
    2,181
    157
    Your Vehicle Year:
    After 100,000 miles I am assuming you know how to drive the car, BUT, try putting your foot on the brake pedal early when slowing for a stop. Do not depress the brake, just slightlly press. Keep your city and suburbia speed to around 40. When starting out, go ahead and accelerate rapidly to warm the engine up. I use this procedure and have a green battery almost every day. Experiment with stealth after car is warmed up. On the freeway, use CC and let the car conserve gasoline. Should you like to drive 65-85 on a flat terrain, all my comments are out the window. When coming home I drive at the speed limits, with use of brake, as described, so in the morning, sometimes my battery is green upon starting! At that point I do everything I can to preserve that State Of Charge.
  11. Offline
    Dec 29, 2007
    4,111
    264
    Your Vehicle Year:
    maybe the colder conditions this time of year?
  12. Offline
    gwmort Active Member
    Mar 22, 2011
    969
    176
    Delaware
    Your Vehicle Year:
    This happened to me in my Gen I. It got to the point that it could not hold a charge overnight, then to the point it couldn't hold a charge longer than a few hours (battery drained when I came out of work).
    I was usually able to get it started without a problem, and after a few minutes the system would bring it to a normal operating band so everything worked fine while driving around, but if I parked for a significant amount of time it would be back to square one.
    I learned to live with it for a while then really felt a need to replace the car. Even with the warning lights and alarms it was a pretty reliable little car running that way for about 6 months.
  13. Offline
    uart Senior Member
    Sep 7, 2009
    2,771
    478
    Australia
    Your Vehicle Year:
    Thanks for the info gwmort. I think this is the worst case scenario for the OP, a fully cooked battery pack. High leakage current and self discharge is a characterize of a cooked NiMH battery. All of my rechargeable drills ultimately end up like this due to overly aggressive chargers. :( Fortunately the Prius is a lot kinder to batteries than is my drill charger. :)
    In the case of the OP, it might still be some high initial loads that are rapidly draining the traction battery after starting. We need more info to know for sure.
  14. Offline
    djasonw Active Member
    Jul 13, 2004
    821
    45
    Coconut Creek, FL
    Your Vehicle Year:
    This is an interesting thread as I've often wondered if there is a slow drain on the traction battery when the vehicle is not being used for a few days. I make it a habit to observe the SOC prior to turning the car off. I make a mental note and I have to say I'm quite impressed with the battery's ability to maintain a charge. Last week I had not used the car over the weekend and on Monday morning, it was still green (1 bar short of full). I wish there was some diagnostic tool to determine the health of the traction battery. It is very hard for me to tell, but after 160,000 miles and 8 years, the battery seems quite healthy. Heck, I still can't believe I've had this car for 8 years. This is the longest I've ever kept a car.
  15. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    There is no drain on the HV battery when the vehicle is powered down. A set of relays opens up and completely disconnects the HV battery from the outside world.
    NiMh batteries self-discharge, and it gets worse with older or cooked batteries.
    Tom
Share This Page
