1. Offline
    Mike Dimmick New Member
    Start a Conversation
    Aug 8, 2008
    960
    229
    Reading, UK
    Your Vehicle Year:
    Yes, absolutely normal. The regular Prius targets six out of eight bars. If you have more than this, it will try to use more than normal to get rid of the excess - it's so it has somewhere to store energy produced by braking. If the battery ever does get up to 8 bars it (reportedly) starts running the engine as an air pump to waste energy! The lower the charge level gets, the more determined the car becomes to recharge back up to 6 bars.
    Even then the battery meter is a false reading - there's still about 40% charge remaining when the meter shows no bars at all, and eight bars really indicates about 80% charge. Restricting battery usage to this range extends the battery's life substantially.
    I've now owned my car for over four years and I've never seen 8 bars, nor had the forced-discharge behaviour, but then I've never done a long mountain descent. On my car, with the colour Multi-Function Display, the battery meter is pinkish-red for one or two bars, blue for three to six, and green for 7 or 8.
  2. Offline
    Apr 14, 2009
    5,761
    1,587
    Greenwood MS USA
    Your Vehicle Year:
    So that it will have room to regeneratively brake going downhill, the battery never fills up on the level. (gradually braking 80 to 0 all at once may fill it) In, say, the Great Smokies, it can fill all the bars. Like me, you live near the edge of the Delta, so not many large descents.
  3. Offline
    PriusDude11 Junior Member
    Sep 19, 2011
    Vicksburg, MS
    Your Vehicle Year:
    Great!!! Thanks so much for the information. I suppose this is one of those concepts that I cannot believe I did not already think about. It makes complete sense that it never shows a full charge. Also, I can definitely understand what you are talking about with the speed in which the battery is depleted. At least for my vehicle, it seems that it takes just a bit longer to use the battery levels of around 3-5 than the upper levels, which go rather quickly. Regardless, I am glad to finally make sense out of the battery issue.
  4. Offline
    Sep 19, 2011
    Vicksburg, MS
    Your Vehicle Year:
    I am glad to know this now. I didn't even think about it having to have room to store the energy stored through the regeneration process. True enough, just as soon as I go down a long hill, the expected ascent does its damage enough that it is difficult to keep a relatively charged battery.
  5. Offline
    usbseawolf2000 HSD PhD
    Sep 22, 2004
    11,325
    1,766
    Queens, NY
    Your Vehicle Year:
    You are driving your Prius very easily. It is great your commute route allows this. Your HV battery should last way beyond the warranty period.
  6. Offline
    lenjack Member
    Dec 1, 2006
    622
    16
    Pennsylvania USA
    Your Vehicle Year:
    Normal...the car tries to keep the battery at 40 to 80%.
  7. Offline
    Sep 19, 2011
    Vicksburg, MS
    Your Vehicle Year:
    Thanks usbseawolf2000! I definitely hope it lasts for a while, but then again I may just have to purchase the plug-in. I'm obsessed with the vehicle, but I digress. I am curious as to what exactly you mean that I'm driving it easy. Don't get me wrong, I appreciate the comment, as I hope to drive this vehicle for many years, so I'll stick with what seems to be working perfectly.
  8. Offline
    Sep 22, 2004
    11,325
    1,766
    Queens, NY
    Your Vehicle Year:
    If you don't drain the HV battery too low or regen charge it too high, you are in the ideal state of charge. That'll extend the battery life.
    When I say too low or too high, that's already in the Toyota conservative safe zone (40% to 80%). The ideal target SOC is 60%. It sounds like your driving is gentle on the battery since you have not seen it full nor low(?).
  9. Offline
    telmo744 HSD fanatic
    Apr 8, 2010
    773
    65
    Portugal
    Your Vehicle Year:
    Does anyone know the testing conditions/duty cycles performed? How can Toyota make this commercial statement without publishing more data?
  10. Offline
    GrumpyCabbie Senior Member
    Dec 14, 2009
    4,265
    921
    North Yorkshire, UK
    Your Vehicle Year:
    I'd be curious as to the life of the gen3 2009 onwards HV batteries. The gen2 was way over engineered and have run to massive miles 400k+. But there are early reports of the gen3 HV battery failing below 100,000 miles in harsh use taxi environments. Wasn't there a post some months ago about Greek taxi drivers avoiding the gen3 and using the older gen2 because of this?
    I'm only at 65,000 hard miles and I'm sure the HV battery isn't what it was. It seems to cycle more and drop quicker than it used to do.
    Time will tell, but just because the gen2 was bomb proof doesn't mean the later gen3 will be. Making parts smaller, lighter and cheaper but increasing the performance and limits doesn't bode well for a longer life in my book.
  11. Offline
    alekska Member
    Feb 14, 2010
    135
    25
    Atl
    Your Vehicle Year:
    This is normal. Computer has to leave some space in battery available so you can go downhill and regen with "relatively full" battery :)
    PS sorry I did not see all the similar replies - they were on the next page....
    - Alex
  12. Offline
    Sep 19, 2011
    Vicksburg, MS
    Your Vehicle Year:
    I appreciate it Alex...I'm always willing to learn
    alekska likes this.
  13. Offline
    Sep 19, 2011
    Vicksburg, MS
    Your Vehicle Year:
    I see. Who knew that my HV Battery would provide such an insight. You are highly accurate as to how I drive. Kudos! Thanks again for the information!
  14. Offline
    Re-builder priusrebuilder
    Jun 4, 2012
    Monsey NY
    Your Vehicle Year:
    Yes That is normal.
    You would only see full green if you drove down a long hill without pushing the gas
    Last edited by Paradox, Jul 9, 2012. Reason: removed advertising info such as phone numbers, website etc.
Share This Page
