1. Offline
    johnnash New Member
    Jul 1, 2009
    Message Count:
    Your Vehicle Year:
    Curious about something to all the new '10 owners. Has your battery ever actually gotten a full charge? Mine hasn't as of yet and I have already taken it on more than one extended drive (have almost 500 miles on the car now) since I brought it home. Is this by design or defect?
    thanks in advance.
    John
  2. Offline
    Radon New Member
    Feb 9, 2009
    Message Count:
    120
    Vancouver
    Your Vehicle Year:
    They don't charge to full it helps with the battery having a longer life. There's posts around here explaining why if you want to search for it.
  3. Offline
    cardinalred New Member
    Feb 19, 2009
    Message Count:
    17
    Florence, Or
    Your Vehicle Year:
    Have 1600 miles on mine now and never shows more than about 80%.
  4. Offline
    Bob_Stan New Member
    Mar 31, 2009
    Message Count:
    70
    Central New York
    Your Vehicle Year:
    This is how it is designed to work to prolong battery life. The system keeps the charge between 40% to 80% I believe.
  5. Offline
    wvgasguy New Member
    May 6, 2009
    Message Count:
    1,256
    176
    a
    Your Vehicle Year:
    In my TCH (similar) if I went down an extreemly long grade the battery charge would increase and eventually the top bar would turn purple I believe. It would be at that time that the system would start to burn off the energy in other ways (see "B" mode thread for technical discussion on that)
  6. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,753
    2,804
    Northern Michigan
    Your Vehicle Year:
    The control system tries to save room for regenerative braking. If the battery state of charge (SOC) were kept at the top limit, only friction and engine braking could be used. Think of the Prius HV battery as a flywheel: it provides an extra boost when needed, such as for passing, and stores energy when braking. For this to work, its normal state is somewhere toward the top of middle.
    Tom
    1 people like this.
  7. Offline
    mosttoysrk New Member
    May 30, 2009
    Message Count:
    Bellevue, WA
    Your Vehicle Year:
    I have had mine go to the top once. I was on the freeway and exited off a long downhill ramp. The battery was at about 80% when I lifted and started regenerative charging. Halfway down the long ramp the battery was full. The only time I have seen this.
  8. Offline
    damack1 New Member
    Mar 29, 2009
    Message Count:
    123
    24
    Huntsville, Alabama
    Your Vehicle Year:
    This is all good information, because I was a little worried as well. The manual has several pictures showing a full charge.
  9. Offline
    Gadgetdad New Member
    Feb 10, 2007
    Message Count:
    462
    47
    Modesto, California
    Your Vehicle Year:
    I'm going to the Sierra's this weekend and will post what happens after extended uphills and downhills. My '07 routinely fully displays green bars by just regular driving. I sure do miss the full color display of this info that the '07 had. Now I've got to lean forward and squint to see the data :mad:
    Lee
Share This Page
