Best hid kit?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 4npower, Mar 15, 2012.
  1. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    It is! It is simply not as sharp as the cutoff on say an RX350 or even the FX-R projectors with clear lenses. A lot of people actually prefer the blurred cutoff. It is much less distracting. That is probably why most OE projectors don't use clear lenses. :)
  2. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Any problem with the ground wire shadow with your install? Looking at the bulb, the return ground wire is on the top and can most likely cause ground wire shadow.
  3. Tideland Prius
    16,070
    Oh yeah, for sure. I've seen some of those and it's a really sharp line. I wonder if it can be distracting but then again, it's not often you drive around with a wall in front of you to show you the cut off lol.
  4. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    No but that thick band of blue color at the cutoff is broadcast onto every other object in front of the car including people. lol It is very noticeable and can be distracting.
  5. Tideland Prius
    16,070
    Hmmmmmmmm.............
  6. movingforward
    movingforward Member
    169
    The Great White North
    I contemplated on doing this but the idea of removing and baking my headlamps is abit unnerving. I've heard of stories of moisture somehow getting in the headlamp housing after it is resealed. This level invasiveness on a few month old car does not sit well with me.
    1 mod a year is a good rule to not go broke. Otherwise I would need an intervention...Prius modder anonymous!
  7. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    I wonder if you would even have to bake them. Can the projector be removed from the back side? I've never even looked at the GenIII assembly. How sad.
  8. movingforward
    169
    I think it is absolutely necessary to bake it. Alot of these headlamp assembly are not closed sealed with a bolt and nut design with a rubber gasket. I wished it was designed that way, it's alot easier to service
  9. issai
    issai Junior Member
    Southern CA
    For those of you who've purchased the Morimoto kit + relays for their 3rd-generation Prius, where on the Prius did you connect the positive lead of the kit? My mechanic was reluctant to complete the installation because he wasn't sure whether to hook it up directly to the 12V battery (which would require threading wiring from the front to trunk of the car), or somewhere in the front (can't be into the positive jump terminal in the fuse box, right?) What's stopping him is the relay hookup into the Prius' fusible link, which he believes, if there's a short in the HID wiring, may blow all of the Prius' fuses.
    Any help would be appreciated . A close-up shot would be awesome. Thanks!
  10. Here you go.
    Just reference this thread for more pics and details.
  11. issai
    issai Junior Member
    Southern CA
    Gracias, Chief! Those pics, and that other thread, nail it.
  12. ajtozzi
    ajtozzi Junior Member
    94
    If your mechanic thinks that a short will "blow all the fuses" then you need a new mechanic.
    The feed should be fused between the source and the relay inputs. This fuse would protect the fusible link from blowing if there was a short in the HID system and/or relay wiring.
    On a Gen 3 car with a quality HID system you should NOT need a relay set up. The car can already handle 55W of inefficient incandescent lighting, so an HID system should be no problem. Where relays are required are generally in vehicles that either do a CAN system check at start up (Chrysler, BMW, MBZ) or when the ballast is crap and draws a crazy amount if current at start up.
    Buy a quality HID set and you'll have zero issues.
  13. EdyJun
    EdyJun Junior Member
    58
    Los Angeles
    Would you guys recommend 55w HID's in the stock headlight housing in the first place?
    I have heard that it will generate too much heat or it will cause the light to deflect improperly. (did some research but still not sure)
    Right now I have 35w HID kit from Retrofit Source thinking to upgrading to the 55w HID and bulb.
    TIA
  14. MPGMachine
    MPGMachine Junior Member
    30
    Los Angeles
    Can someone confirm that (Not sure if H11 name of kit or harness?)
    From the Retrofitsource (can't post URL since im a noob) as seen in Post #2 on this thread
    H11 Morimoto Elite HID System
    4300K (personal pref)
    H11 Wiring Harness
    Heavy Duty Relay
    is the correct item for a 2012 Prius Four? And since the 2012 have LED DRLs by the bumper I don't have to worry about flicker because of insufficient power to the ballast correct?
    Thanks in advance
    I don't even have the Prius yet but I want the kit to be here when I do have it!
  15. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I've been running Phillips 55 watt HIDs for about 90000kms now and hve no problems with my projectors or reflectors. I don't vouch for low quality HIDs that may buen hotter than the Phillips.
  16. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Yes, that is correct.
    Have you seen any test results for heat and UV for that kit? I am very skeptical they are anything even remotely as good as real Phillips OE stuff. It is more likely just a re-licensed product. Have you pulled the bowls apart for inspection?
  17. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    The best HID kit hands down is a retro!!!!!
    All OEM HID projectors & ballasts will always out perform the pnp kits. :D
  18. Feri
    Feri Active Member
    761
    144
    Have you seen any test results for heat and UV for that kit? I am very skeptical they are anything even remotely as good as real Phillips OE stuff. It is more likely just a re-licensed product. Have you pulled the bowls apart for inspection?[/QUOTE]
    I just pulled one of the bulbs and it has Phillips clearly and strongly printed on it. It may be licensed but, if it is, it is good quality. I've inspected the inside of the projector with a flexible viewer thingy with a light shining back through the lens and it appears pristine.
    Halogen lights burn pretty hot too!
  19. idesi1
    idesi1 Junior Member
    55
    Houston
    Has anyone tried their product..?
    xenonsupply dot com look for toyota-prius-hid-xenon-package - ( sorry cant post url untill i post few more messages :(
    I found it while searching for decent HID kit for 2012 prius. It seems they are well informed and product is not cheap. But before going for any of these just want to safe than sorry.
  20. jblackwell
    jblackwell Junior Member
    49
    Cave Creek, AZ
    I just received mine from xenon supply. I'll do a full review soon.
