Best source for fuses (and other parts) for Prius v (lowercase v)?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SoCal_Priusv, Apr 28, 2015.
  1. SoCal_Priusv
    SoCal_Priusv New Member
    Hello! I am new to PriusChat and I would like to learn where to buy fuses for my 2012 Prius v (lowercas v for the Prius v wagon) and how to change them myself.
    I bought a used 2012 Prius v last year. I use the front console 12V outlet to charge my phones, but when I have used a 12V air pump or a vacuum, the fuse has blown.
    The dealer told me the outlet is not made for anything but small devices, but could not/would not tell me what is the max specified amp/rating the 12V outlet on the left in the front console can handle.
    Where is the best place online to buy fuses and will it be easy enough for someone with little or no experience working on cars to change a fuse? A fuse seems like something I should be able to do on my own. (I Hope.)
    I found diagrams for Prius fuse locations, but have not tried to change one yet.
    Thank you in advance!
  2. LostViet408
    LostViet408 Junior Member
    You can buy the fuse at any auto store, there should also be a fuse puller in the engine compartment fuse box for you to use to pull out the fuses with ease. The fuse you blown is probably on the driver kick panel as its where all your accessorie fuses are located. I hope that helps.
    SoCal_Priusv likes this.
  3. qdllc
    qdllc Senior Member
    1,358
    396
    As far as "max" goes, I'm not sure there is one beyond the max any one standard circuit has.
    For example, if you have "mini blade" 15A fuses in the fuse block, any one circuit COULD take a 15A fuse with no damage to the wiring.
    HOWEVER, the overall power system is designed with caps on what each circuit is supposed to have. So, if a circuit has a 5A fuse and you put a 10A fuse in, anything on that circuit that should be protected from draw exceeding 5A is now compromised.
    This may be more so with the Prius. Ordinary cars just have a 12V circuit and you can draw as many amps as the fuse/wiring will support. The Prius may "manage" power in a way that exceeding the OEM limit (set by the size fuse they put in) could cause problems.
    There can be other limits as well. I have an auxiliary fuse block on my motorcycle, and even though there are 6 circuits I COULD use, the instructions say the total amp output should not exceed 30A. So, I have to do math when I put in accessories. Everything on can't draw more than 30A or I could damage something.
    FWIW, many 12v air pumps draw too much to work with fuses or if they hit any "strain" jump over the normal amperage draw. My motorcycle 12V accessory plug will power an air pump, but it's one for bicycles, so it's low draw. Slow, but it works for what I need. A more beefy air pump might do the same to me.
    Indeed, many 12V air pumps come with alligator clips to attach directly to the battery rather than rely on the output limit of your 12V plug in the car.
    #3 qdllc, Apr 28, 2015
  4. SoCal_Priusv
    Thank you. I am buying a 12V plug-to-clip adapter so I can attach my current air pump directly to the Prius' battery. Then I won't need to worry about the fuse blowing.
    Thank you for the help. I will buy replacement fuse(s) today so I have one handy in case one blows.
    #4 SoCal_Priusv, Apr 28, 2015
  5. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    You are looking for low profile mini ATM type automotive fuses. ;)
    The low profile part is important. The mini ATM fuses will fit, but they will stick out and prevent the reinstallation of the fuse cover.
  6. ChapmanF
    15,106
    All the fuse type, location, amp rating, circuits served, and check and change instructions are in your owner's manual, pages 410 to 420. (If the owner's manual was missing when you bought the used car, you can pull it up for free at techinfo.toyota.com. Check under General -> Maintenance and Care -> DIY Maintenance to see the section that includes the fuse information.)
    -Chap
    CR94 likes this.
  7. qdllc
    qdllc Senior Member
    1,358
    396
    Be warned, the output of the Prius 12V is akin to a motorcycle battery. Normally, you'd start a motorcycle and let it run while powering an air pump to not draw down the capacity of the battery.
    IF SOMEONE HERE KNOWS BETTER, PLEASE ADVISE, but with the Prius being the way it is, I don't know if there is any real risk to hooking a 12V accessory directly to the 12V battery and running it with the Prius off or on. If it was a normal car, I'd be comfortable saying this is a good idea.
    They also make 12V/110V converters so you can power it off a wall outlet.
