Best Tires for Comfortable Ride?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CaptAjax, Apr 20, 2012.
  1. CaptAjax
    CaptAjax
    Expand Collapse
    New Member
    MO
    I wiil soon be needing new tires for my III. Which ones offer the softest ride? I'm not a MPG fanatic, anywhere in the high 40's is OK. Not a performance purist either. I just want as soft a ride as possible in this small car. Thanks.
  2. blane
    blane
    Expand Collapse
    Carmudgeon
    27
    Suburb NW of NYC
    Try tirerackdotcom
  3. stream
    stream
    Expand Collapse
    Senior Member
    2,977
    445
    Long Island, NY
    +1 on tirerack.com. In addition to great selection and low prices, they have great reviews.
  4. TruSound
    TruSound
    Expand Collapse
    Member
    246
    30
    The 818
    I just replaced my 16" wheels with 17" and bought the Michlin MXV4 LRR GreenX tires...fantastic tire, highly rated and smooooooth.
  5. F8L
    F8L
    Expand Collapse
    Protecting Habitat & AG Lands
    19,149
    4,027
    50
    Sacramento, CA.
    2013 Chevy Volt
    This is a really subjective trait I a tire and co founded by the problem of fuel efficiency. Most of the really comfy tires will either have a low tread wear or high rolling resistance or both!
    You may consider something n between and run a tire like the Ecopia EP100 or Energy Saver A/S. The Energy Saver A/S will provide the best mpg, great tread wear and good comfort. The MXV4 is an excellent tire but you'll take a 3+mpg hit with those vs. the Energy Saver A/S.
    You may want to read my tire threads and see if they help you narrow down your search.
    http://priuschat.com/forums/gen-iii...esistance-replacement-tires-current-list.html
    http://priuschat.com/forums/gen-ii-prius-fuel-economy/98592-new-tire-tests-tirerack-com.html
  6. hlunde
    hlunde
    Expand Collapse
    Member
    403
    68
    I believe that the Bridgestone Turanza Serenity(Grand Touring All-Season) is well known for its excellent ride. These are sold by Firestone dealers and you can get a firm quote on line, so the dealer cannot throw in a lot of extra charges at the point of sale after giving you a telephone quotation. You will have to make sure that any dealer jacks the Prius up correctly when replacing tires.
  7. jdcollins5
    jdcollins5
    Expand Collapse
    Senior Member
    4,899
    1,062
    Wilmington, NC
    I have the 15" MXV4's that F8L discusses above. This size is not GreenX but just outside of the LRR classification. I have lost about the 3 mpg average that he indicates above.
    But, if you are looking for a smooth, comfortable ride I would highly recommend these tires. The ride, handling, grip and low noise of these tires make them an excellent tire for someone that does not mind the loss of a few mpg's as you indicate.
