Best way to raise seat an inch or so?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by tweldon2, Oct 30, 2014.
  1. tweldon2
    tweldon2 Junior Member
    Stockton
    Just traded my 2006 Prius for a 2015 Pip. I've noticed that the seat in the Pip sits lower. In my old Prius, my arm rested comfortably on the door sill of the open window, and my eyes were at the center of the windshield. With the Pip, I am noticely lower. Not as comfortable resting arm on door will, and eyes not at center of windshield.
    I'd like to raise my seat up. There are no controls on my basic pip to do this. Has anyone else discovered is issue and posted solutions? I've searched a bit and have seen some lowering, but not specifically to raise.
    Any help/suggestions?
  2. mrbigh
    3,686
    699
    Long Island, NY
    My 2012 PiP base model has a lever to adjust the driver's seat high.....doesn't yours? o_O
  3. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    Your seat should be 6-way adjustable. Forward/back/raise seatback/recline seatback/height up/height down. Height adjustment is the lever on the left closest to the front of the car.
    If you're saying that the seat in its highest position is too low for you, then add a pillow or eat a lot of fast food to grow a bigger butt. :D
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    telephone book?:whistle:
  5. GregP507
    GregP507 Senior Member
    3,002
    480
    Dashboard-lowering kit.
    priuskitty likes this.
  6. KV1955
    KV1955 Member
    49
    36
    Manassas, VA
    2014 Prius Plug-in
    The '14 has a height adjustment lever
  7. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    i wish i could lower my seat... feels like minivan...
  8. tweldon2
    Stockton
    That's why I like this forum - folks have a sense of humor. Figured it out. never imagined you could "pump" the seat up with the handle!
    Cheers,
    Tweldon
    nzpixie likes this.
