Blew a fuse, twice
Discussion in 'Fred's House of Pancakes' started by bwilson4web, May 24, 2015.
  1. bwilson4web
    15,388
    Owning two Prius, I bought a 12V tire air pump many years ago to keep our Prius tires properly inflated. But our new beagle dog decided everything was a chew toy. She chewed open the canvas carry case and then started on the wires by the plug. It looked OK but the third tire, it blew the cigarette lighter fuse. No problem, 2003 Prius:
    • fuse easy to see and remove
    • heat-shrink, snip-snip, solder solved
    So two weeks ago, Firestone corrected a tire alignment problem but per usual, they less-flated the tires. No problem, hooked up the pump and it blew the fuse in our 2010 Prius:
    • fuses are nearly impossible to see - had to use cell phone photos
    • nearly impossible to remove by fingers
    This was the new short:
    • one rubber footer missing
    • beagle teeth marks
    • that little blue b*st*rd is the fuse (NOTE: the engine compartment has a fuse removal tool)
    I'm at work and not really in a position to disassemble and heat-shrink repair. Then I remembered, I had the solution at hand:
    Similar to JB Weld, I had some of these in my desk.
    I prepared the wire using a small flat screw-driver:
    I took care to make sure no wire whiskers shorts. Then mixing the epoxy, I fixed the power cable:
    I also moved one of the three remaining rubber feet to that end to minimize future mechanical stress.
    Lessons learned:
    • 2010 Prius cabin fuses - WHAT A TERRIBLE DESIGN
      • impossible to see without a mirror (or small child)
      • impossible to remove without claw-like nails
      • obscure fuse removal tool located in engine compartment fuse box
      • manual does not show which side is toward driver and side toward door or center (my manual does now!)
      • expensive fuses ($1 each) at local autoshop (not a common, cheap part)
    • Next to duct tape, epoxy holds the world together
    Now to figure out how to replace the wheel cover that was not seated by the Firestone tech. <GERRR>
    #1 bwilson4web, May 24, 2015
  2. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    You forgot to put this at the end of your post:
    /end rant
    ;) :D
  3. bwilson4web
    15,388
    Probably too late for the Gen 4.
  4. Mendel Leisk
    38,201
    Picture orientation can derail a diagram's message so easily: valve adjustment procedure on our previous Civic Hybrid had one.
    Nice innovative fix on your wire problem. I use two-part epoxy a lot; as long as parts aren't under too much tension, and/or you really buttress the bond area with periferal epoxy.
  5. Trollbait
    11,302
    The tiny fuses that need a fuse puller are now common, and the puller that is with the car might not work.
  6. ETC(SS)
    6,492
    1. Small needle nosed pliers.
    2. Inline fuse with a rating sufficient for the pump. Protect the protector.
    3. No-Kill(*) Shelter
    (*)Optional
    #6 ETC(SS), May 28, 2015
  7. Trollbait
    11,302
    There is probably a fuse already in the 12 volt plug of the pump. At least of my pumps have that.
