block heater trips house GFI
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by briantompo, Dec 21, 2011.
  1. briantompo
    briantompo Junior Member
    Hello,
    I hope everyone enjoyed the holiday. I had a chance to pull the block heater out and bench test it. The culprit is the insulated, rubber boot at the heater-end of the power cord. It tests "open" between ground and one lead (using the 20M Ohm scale) but 85K Ohms between ground and the other. Resistance varies between 75K-100K Ohms when I squeeze and deform the boot. The heater insert itself tests OK.
    Many thanks to those that offered advice, I appreciate it.
    Brian
  2. briantompo
    New block heater installed and works fine. Clearly, I got lucky installing the first one years ago as this one took me all day and I invented some new words. I tried from the top with the cowl and wiper motor removed but ultimately installed from beneath the car using my right hand. Brian
  3. frodoz737
    frodoz737 Top Wrench
    4,297
    2,347
    33
    Felt good huh? Congratulations.
  4. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    I installed mine from the top and it was not easy. Later on I adjusted the cable to give it more slack. I looked and had no idea how I was able to install it.
