1. Offline
    Keiichi Active Member
    Start a Conversation
    Feb 1, 2012
    802
    72
    Goleta
    Your Vehicle Year:
    Since someone else asked on another thread, might as well make a topic directly related to said question.
    This is going to be a 'live' topic on Bluetooth MAP Phones, more specifically, Bluetooth MAP Smartphones (Although if your phone is not a smartphone but does have Bluetooth and specifically states it supports MAP (Message Access Profile), it will be added. The plan is to make a more definitive listing of phones since lots of people are asking and not knowing.
    Phones that work:
    Phone|SMS|MMS|E-Mail|Entune Version|Notes
    Motorola Droid Bionic|Y|Y|N|1.5.17|Confirmed by Keiichi
    Motorola Droid Razr|Y|Y|N|?|
    Motorola Droid 4|Y|?|?|1.7.4?|calebu2
    HTC Evo 3D|?|?|?|1.7.4?|Believed unstable - calebu2
    HTC Sensation|?|?|?|?|HTC website says it supports MAP
    Phones that do NOT work:
    Phone
    iPhone - 1st gen to 4S (iOS5 does not support Bluetooth MAP)
    Samsung Galaxy Nexus (Specs show no support for Bluetooth MAP)
    Again, will update this with more information when people chime in with information.
    Since I have the Droid Bionic, I looked it up and Motorola states clearly it supports Bluetooth MAP, however, it will only do SMS/MMS, not e-mail. So most people SHOULD be able to look up their phones on the manufacturer's website and it should state what kind of Bluetooth technology and what it will support. Some carriers will also provide that information as well, but right now, there is no 'definitive' Bluetooth MAP listing for phones. Also, this listing is going purely off STOCK phones, not 'Rooted' phones, where there is a possibility that rooted phones will have the Bluetooth MAP ability.
    Also, Toyota has a site for people to check their phone compatibility, however, this does not give much more information other than some of the Entune stuff, not necessarily the SMS/MMS/E-mail support.
    http://www.toyota.com/connect/
  2. Offline
    Feb 1, 2012
    802
    72
    Goleta
    Your Vehicle Year:
    Ok.... I have yet to find a convenient way to put the listing in an easy to read format... Once I do, it will be fixed.
  3. Offline
    Wanderer Hybrid neophyte
    Feb 15, 2012
    375
    Cold country
    Your Vehicle Year:
    Keiichi there is a lot of discussion around ford sync and this topic that may have more phones listed. I started to look but got called away.
    As for easy to read I don't know if linking a public google doc spreadsheet would work but it's an idea. W
  4. Online
    calebu2 Junior Member
    Mar 10, 2010
    Southeastern MA
    Your Vehicle Year:
    Might be worth having people post their entune version because that might affect the ability of a phone to work with map.
    All on 1.7.4:
    Samsung Epic 4G: no map
    HTC Evo 3D: unstable (generally doesnt work)
    Motorola Droid 4: sms (havent tested mms or email)
    I'll edit once ive tested mms and email
    Sent from my DROID4 using Tapatalk
  5. Offline
    Feb 1, 2012
    802
    72
    Goleta
    Your Vehicle Year:
    I looked on the Mysync.com site and I think it is a bit questionable to use it as a good link for our situation with the Prius v or the 3rd gen cars that might use our particular nav system. I also found a site that explains how to do tables correctly, although it took a bit of work.
  6. Offline
    Ihave2fundogs New Member
    Mar 30, 2012
    SC
    Your Vehicle Year:
    I have a Samsung Galaxy Nexus and I cannot get the text/sms/email function to work. :(
  7. Offline
    Feb 1, 2012
    802
    72
    Goleta
    Your Vehicle Year:
  8. Offline
    darkleafar Member
    Jun 21, 2009
    178
    Houston TX
    Your Vehicle Year:
    My Htc Evo 3D does not work. I've tried several times. So I've always assumed my phone does not have MAP at all. I'm hoping HTC Evo 4g LTE does
  9. Offline
    bielinsk Gremlin
    May 4, 2012
    466
    98
    Anaheim
    Your Vehicle Year:
    I have a Samsung Galaxy S2 and that does have MAP support but I rarely ever get an SMS notification.
    I rarely can rely on the Entune Apps to connect.
    I seem to constantly get Pairing popups on my phone when trying to access the Apps to run Pandora.
    I have the Advanced PiP with the 7" HDD display unit.
  10. Offline
    MBRGuru Member
    Oct 28, 2011
    239
    23
    Your Vehicle Year:
    If you keep getting pairing notifications on the phone (with the 6 digit PIN) then there was a problem on the phone when it paired the first time. Delete the pairing from the car and the phone. Restart the phone and make sure the pairing was removed. Sometimes when this happens on Android OS the phone looks like it removes the connection but it'll still be there in the Bluetooth list after a restart. Then repair your phone.
  11. Offline
    blakemster Member
    Mar 29, 2012
    130
    huntington beach, ca
    Your Vehicle Year:
    Can anyone tell me a specific phone model where EVRYTHING works flawlessly (preferably on T Mobile) ???
  12. Online
    cwerdna Senior Member
    Sep 4, 2005
    11,801
    1,718
    SF Bay Area, CA
    Your Vehicle Year:
    Good luck w/that! :D
    There are a lot of possible test cases. Try picking a random phone at Toyota.com - Connect and seeing what I mean. I picked an iPhone 4S on AT&T and there are 139 test cases listed.
  13. Offline
    t_rob New Member
    Dec 21, 2011
    Los Angeles
    Your Vehicle Year:
    For Those brave enough, the Galaxy S III has MAP support, but didn't work, however the CyanogenMod versions seem to work (specifically Slim-Bean 2.5 and later on Verizon was my test bed) SMS yes, MMS not sure(no pictures, not sure what else to test), email sender and subject only body comes up null. Entune version 1.7.203.44986
  14. Offline
    bielinsk Gremlin
    May 4, 2012
    466
    98
    Anaheim
    Your Vehicle Year:
    The Jellybean leak for the Sprint Galaxy S3 has support for everything. Texts, email, etc. Works perfectly.
  15. Offline
    blakemster Member
    Mar 29, 2012
    130
    Your Vehicle Year:
    Wow, would have never pegged you for a sprint guy ... thanks for update - waiting for jb update before i buy my t mobile version - thanks again for your input -
    blake master
  16. Offline
    bielinsk Gremlin
    May 4, 2012
    466
    98
    Anaheim
    Your Vehicle Year:
    Yea, can't beat 3 unlimited everything phones for $160 a month. Not the fastest, but call quality is fine.
Share This Page
