1. Offline
    So Grateful New Member
    Apr 2, 2009
    Message Count:
    Kirkland, Wa. USA
    Your Vehicle Year:
    I picked up my 2010 on Friday. I had no problem syncing my Iphone to the car. When a call comes in everything works great, the person calling sounds great. The problem is I sound terrible to them they say it sounds like I am in a cave, and this is when the car is standing still. I have tried talking softer more direct up at microphone I have the audio turned down, When the car is in motion they can hardly understand me at all. Is there anything I can do about this? Or is it just a horrible microphone. Maybe some aftermarket microphone might be available? Anyone else having this problem? :mad:
  2. Offline
    DeanFL 2010 owner - 1st Prius
    Apr 13, 2009
    Message Count:
    986
    321
    Leesburg Florida USA
    Your Vehicle Year:
    Same!!! Only made 3 calls to the same person, but they said to speak up. So I have to raise my voice quite a bit. I looked thru the manual quick to see if there was a function to increase mic volume, but can't spot it. We'd appreciate guidance here...
    Also is there a way to upload contact info / numbers from a bluetooth to the JBL? I don't have Nav. Any way other than manual voice-entering?
  3. Offline
    LRKingII New Member
    May 31, 2009
    Message Count:
    680
    130
    Idaho
    Your Vehicle Year:
    Might wanna try this http://priuschat.com/forums/gen-ii-...mands-bluetooth-info-2009-a-2.html#post876934
  4. Offline
    ggood ggood
    Jan 17, 2004
    Message Count:
    1,917
    276
    Houston, Texas
    Your Vehicle Year:
    You can turn up the bluetooth receive volume (i.e., the volume of what the other person hears), using a hack. See this thread:
    http://priuschat.com/forums/gen-iii...34-bluetooth-phone-hard-hear-suggestions.html
  5. Offline
    accordingly New Member
    May 5, 2009
    Message Count:
    266
    62
    Madison, WI
    Your Vehicle Year:
    You might be able to make it a bit louder, but you're just putting a band-aid on the real problem- microphones don't do so well far from the source. No matter what you do you'll never hear the end of "Take me off speaker you idiot!" or "Call me back on a real phone!"
  6. Offline
    Apr 13, 2009
    Message Count:
    986
    321
    Your Vehicle Year:
    Thanks for this info - but do you know where the 'Info' button is on non-Nav '10 to try this mod???
    I held down the info button (on the MFD) and turned the headlights on and off three times and got the diagnostic screen to do the adjustments. after I adjusted the volume for sendiong to "5" I just turned the car off and back on and everything was back to normal and my sending volume was much better! Hope that helps. P.S. you must hold the info button by the MFD the one on the steering wheel will not do it.
  7. Offline
    web1b New Member
    Jun 10, 2007
    Message Count:
    771
    45
    I have only seen anyone post this with Nav.
    Sounds like you have to pay $1800 to adjust the microphone volume.
  8. Offline
    Apr 13, 2009
    Message Count:
    986
    321
    Your Vehicle Year:
    well that really............stinks. had to clean that up.
Share This Page
