1. Offline
    dareniott New Member
    Start a Conversation
    Jul 19, 2007
    I was wondering if anyone has any schematics of the MFD boards or anything like that. I do not have the service manuals so I don't know if these even exist. The mod of cutting the violet (speed) wire or putting in a switch, or using a lockpick is well documented on here. I found an older post which provided a circuit to intercept the "on-hook" and "off-hook" switches on the steering wheel and essentially flip the switch(break the violet wire) for you (which seems to be the coolest solution I have found). BUT my thought is if we had some idea of what was going on in the MFD then maybe we could see where this speed wire goes. For example if the violet wire connects via the connector on the back of the MFD then branches to different circuits then perhaps you could simply cut the trace on the MFD that goes to the bluetooth circuit and not affect the "5 minutes bars"?!?
  2. Offline
    Jul 19, 2007
    Is it possible that this speed information is packeted digitally and then sent on the LAN to each component (the FE display components, radio to turn off the song scrolling, the bluetooth to disable... well, everything)? In absence of a better solution I may have to go for the cutting of the speed wire solution. But I can't help but think that there has got to be a way to interrupt this speed information to only the bluetooth. Given enough information there has to be a way.
  3. Offline
    • Moderator
    efusco Troll Slayer
    Nov 26, 2003
    19,828
    1,032
    Nixa, MO
    Your Vehicle Year:
    There probably is a better way, but not without mucking around with the circuit boards and such. If that's something that's within your skill set I'm confident that a lot of people would be thrilled to find out what and how to do it.
    But the speed sensor wire is very easy to access, very easy to install a switch on, and does the job just fine for those of us who couldn't wait for someone to discover a better solution...I've had my BT speed sensor wire mod for about 2 1/2 years now.
  4. Offline
    Jul 19, 2007
    I guess I'll put down on my list of wants "The Prius Service Manuals" and have a look. Not sure if there would be any schematics of the MFD circuit boards though.
  5. Offline
    Apr 23, 2005
    3,841
    Your Vehicle Year:
    Another thing about cutting the speed sensor wire. If you switch Off for the length of time you dial and switch On after that you probably won't notice anything happen with the 5-minute bars. After all, you've probably stopped at a traffic light longer.
  6. Offline
    David Beale Senior Member
    Jul 24, 2006
    3,765
    454
    Edmonton Alberta
    Your Vehicle Year:
    You can get the manuals for $10 per day from the Toyota tekinfo site. In one day you should be able to download just about everything you want.
    https://techinfo.toyota.com/
    I can't pay as I'm in Canada, so I haven't looked at the manuals (they are $400 or so from the dealer in hard copy). I'm pretty sure, based on what I've seen in other Toyota manuals, the drawings show a box with wire colours and pin numbers/connector names and numbers only for each of the electronic modules.
    Don't despair, however. The connections you want to break are usually -inside- an integrated circuit, in my experience. ;)
  7. Offline
    Jul 19, 2007
    O.k. so I got onto TIS to get the service manuals... Over 500 documents that must be downloaded manually, BS! Just give me one service manual in pdf form I can download, but no! The service manuals are totally useless anyway, they provide basic wiring diagrams but they are in module form. So they just say ECU and show you wires going in and out, MFD wires in and out. There are not schematics of any boards or anything technical about them whatsoever! Plus the repair manual chapters are in the moronic form or Microsoft help documents, did this work? then turn of radio, did that work? It's like the manuals were written for Pre-Schoolers.
    O.k. enough griping, I did NOT find the override to the bluetooth speed wire problem YET. I am thinking I will have to take apart the MFD and trace through the circuits. OH, and they do not even mention the bluetoooth circuit, nothing to do with any portion of it except to show you where the Microphone is mounted and do not even give you any schematics on the amp or anything. O.k. now that's enough griping. But if you want usefull information do not waste your time with the TIS site or it's info.
    Anywayz, the actual reason I posted this is to warn everyone. One thing I notice in tracing the wiring diagram is the VSC. Any of you that implemented the previous mod of simply cutting or switching the speed wire might want to think twice about using it. From what I could see in their horrible diagrams the VSC gets it's speed info from the MFD speed wire (that you cut). Using the previous mod might in fact disable the VSC since it doesn't know when your tires are spinning (or slipping). A toyota tech might want to chime in on this, but this is what I derived from their substandard information on the TIS site.
  8. Offline
    • Moderator
    efusco Troll Slayer
    Nov 26, 2003
    19,828
    1,032
    Nixa, MO
    Your Vehicle Year:
    No, you misread the wiring diagrams or it's not included in the one you were looking at. the speed sensor wires to the MFD are not related to the VSC, the braking and VSC have seperate speed sensors that go through the Brake ECU or some such.
Share This Page
