Brake and ABS Dash Lights Randomly Come On
Discussion in 'Generation 1 Prius Discussion' started by squallor, Mar 30, 2012.
  1. squallor
    squallor New Member
    Worcester MA
    2002 Prius
    I
    The Problem:
    The short version of the problem is that, as the description says, the ABS and Brake dash lights will come on for awhile, but then shut off, either why driving or the next time I start my car. The brake fluid level and color seems fine, and I checked the hidden service menu from the control screen, and the computer is not reporting any error codes (though I have not hooked it up to any formal error code reading device).
    Problem History:
    The first I saw this problem was about 4 weeks ago just after I got an oil change at a local Toyota Service Center. They warned me that the lights were on and I should get them looked at (though I had never had an issue with them before). when I started my car after, they were on, but then shut off after about 30 seconds. I did not see them again for a few days, so I assumed it was just something got bumped or whatnot, and was not worried. Later I randomly started my car one morning and they were back on, this time they stayed on for a few minutes before shutting off. It continued to do this randomly, but I never felt any issue with brakes, nor noticed any other problems with the operation.
    The first time I saw it come on why driving, was when I was pulling over to the side of the road, and hit a puddle that was deeper than I thought and jerked the shocks a lot. After this the problem started to be more frequent, most noticeably if I park on a hill with the e-brake on.
    My Thoughts:
    I called my Service center, and they wanted 100 bucks for the inspection, and then most likely another couple hundred for the repair. I am not inclined to just dump my money into this without looking it up first, and what I have seen online is that similar cases on other cars have been a faulty abs sensor or some kind of particle in the fluid line. Since I am not seeing any error messages from the computer, nor are the lights consistently on, I am thinking of getting my brakes flushed.
    Does this sound like the right idea? Is there anything I should know about flushing the brake fluid, or should I really take it to a service center. They are asking 130 (plus mostly likely an extra 20 bucks b/c this place always finds little things to tack on) to change the fluid. I figured I could do it myself for under 50, but wanted to check in here to see if anyone had any other advice. I am not what anyone would consider a car guy, and this is my first hybrid, so I wanted to check with some experts first.
    Thanks in advance,
    Mike
  2. Patrick Wong
    18,199
    6,464
    Hi Mike,
    Especially since you do not consider yourself a "car guy" I would strongly suggest that you not attempt to flush the brake fluid. If you introduce air into the system upstream from the brake wheel cylinders, it will be very difficult to get rid of that and you will end up without brakes and having to tow your car to your local Toyota dealer.
    The "hidden service menu" that you can find on the MFD has nothing to do with powertrain or skid control system status, so please don't waste your time looking at that.
    Since the BRAKE and ABS warning lights are warning you that an important safety system is impaired, you really need to have that checked out by a competent servicer who is familiar with Prius. Normally that would be your local Toyota dealer. Good luck.
  3. squallor
    squallor New Member
    Worcester MA
    2002 Prius
    I
    Thanks for your reply.
    I wasn't actually planning on flushing my brakes entirely myself, I know someone who always does his own work on his cars, so I would actually go do it with him on the weekend (he's never had a hybrid so didn't want to say anything for sure, nor has he looked at my car himself yet). I do appreciate the concern and understand the risks with changing your brake flood.
    I am just looking to see someone had idea for other things to look for before potentially dropping a couple hundred dollars on something I could have done myself. With the service menu, I figured there wasn't going to be much there since it is never showed a warning on the digital display, but figured I would check anyway since it was a 2 minute thing for me. I heard that autozone does free OBD scans, so I was going to try and do that tonight to see if I can at least know as much as possible before hand if I do have to take it to do the dealer. I know I said I wasn't a car guy, but I have done small work on my car before, but I always like to consult with people first. I just want to see if it is anything like that before I commit a lot of money to it.
    Thanks again.
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
  5. ChapmanF
    15,105
    The diagnostic screens on the MFD are cool, but they are only for diagnosing the MFD itself and other items on the AVC-LAN (radio, CD, navigation if you have it). It is separate from the information you need to get via the OBD-II DLC connector under the dash at the left.
    If you don't have a scanner, you can still read brake system codes by jumpering the TC signal (pin 13) to chassis ground (CG, pin 4) at the DLC connector (key on, engine off). Various lights on the dash will start blinking codes from the computers that control them. Also the MFD will switch into its diagnostic screen that you've already seen, except in Japanese. Count the blinks of the ABS light; you'll get two digit codes, e.g. blink blink ... blink blink blink would be 23. You may get more than one two-digit code, with longer pauses between the codes.
    It goes without saying, be careful to get the pin numbers right, don't go shorting random DLC pins together by mistake.
    -Chap
  6. squallor
    squallor New Member
    Worcester MA
    2002 Prius
    I
    I just had my OBD-II scan done at Autozone which they did for free. It did not report any error codes. I don't know if that can rule out certain problems or not.
    I will try and jumper the pin 13 and pin 4 terminals to see what if I get anything. I will report back here with what I find.
  7. squallor
    squallor New Member
    Worcester MA
    2002 Prius
    I
    Just got the abs codes: 31, 32, 34, 59.
    I tried googling for a list of abs blink codes, but I could not find any. Does anyone here have a translation?
    Thanks again.
  8. ChapmanF
    15,105
    I believe the ABS DTCs as you would see them on a scantool are all C12nn codes, and the two digits you get with the blink method are the nn.
    If I remember right, C1259 is a pretty generic code that you get if there's ever been any condition that interfered with proper coordination of the braking between the ABS and HV ECUs. Because that could be a lot of things and can likely be cleared after the underlying problem's been fixed, it makes sense to look up the other codes first.
    If it were me I wouldn't want to waste much time looking anywhere but in the service manual. A very cheap fee gives you one or two days of access at techinfo.toyota.com, if you're not planning to have the car long enough to be worth just buying a copy (the back of your owner's manual has ordering info). You don't just want translations of the codes, you want the procedures on what you need to rule out in what order before you know what's causing those codes to come up, and all that's in the manual. Not that you haven't also got google, and this forum, or 3rd-party publisher service manuals, but if you've ever played that telephone game where you try to pass information along from person to person, you'll understand why it's good to get your own eyes on the original manual. And no, I don't work for Toyota. :)
    For general background, autoshop101.com has a technical article under hybrid diagnosis for the brake system. It doesn't list all your codes or much in the way of troubleshooting procedures, but it's a nice overview of how the systems work.
    -Chap
    edit: somehow I thought the word 'game' without really typing it
    #8 ChapmanF, Apr 2, 2012
  9. squallor
    squallor New Member
    Worcester MA
    2002 Prius
    I
    After some serious google-fuing last night, I found a lookup for the abs blink codes. I found 31-34, which reports a signal error coming from the speed sensors for each of the respective tires. 31, 32, and 34 correspond to front left, front right, and rear right respectively. I could not find an error for 59 in that document though. Also to note, the ABS blink codes were not directly correlated to the C12xx codes, though I believe they did have some other related C12xx code.
    It suggested that I check that the sensors aren't shorted or open with a multimeter. Next would be follow the cabling to make sure its all plugged into the ecu correctly. Finally would be check to see if the ECU is not broken.
    Where I am stuck now is 1) finding where these sensors are in the car, and how to unplug them to check their impedance. 2) how to get to the brake ecu and check if everything is plugged in (i also what to check the impedance at the input terminal to see if it varies from the sensor itself.)
    As for the greater question of checking the ECU functionality, I have no idea how to do this. I would imagine that if that was broken itself, we would see more errors. Also, I would be curious to see what happens if I reset the ECU to factory settings in case some logic in there became corrupted.
    Since I am seeing intermittent issues with the brake/abs light, i am thinking that either something is grounding and it shouldn't, or something that is supposed to be grounded and isn't. From my understanding of electronics, this could cause the signal error on multiple sensors simultaneously.
    Also, I never had this issue until after I got an oil change, so my thought was that something might of got hit when they were replacing the filter, which might of messed with the wiring.
    Does any of this sound reasonable? Does anyone have advice on how to get at the speed sensors and ECU?
    And thanks again, you guys have been great for helping me step through this myself, and I don't think I would have made it this far without you.
  10. ChapmanF
    15,105
    You're asking all the right questions. Did I mention $15 gets you access to all the right answers at techinfo.toyota.com?
    I'm not trying to be mysterious or difficult, it's just that you've reached the point now where you mostly know what you need to find out, and it's clear what the best source is to find it out. There's not much I could add beyond hauling out my own manual and retyping stuff straight off the page (and somehow copying the pictures?). On the other hand, questions like "I found such-and-such in the manual, can you help me make sense of it" are where forum members can really feel useful helping you out.
    Did that make sense?
    -Chap
  11. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    I suspect a bad ground somewhere. Speed sensors will die in isolation, rather than en masse. At least usually, but I suppose anything is possible.
    However, it wouldn't hurt for you to put your car up on jackstands and remove the wheels (loosen by half a turn each lug nut before lifting). On the front, the sensor (Hall effect) picks up the movement from the tone ring on the axle half-shafts. I suggest you remove them (probably a 10mm bolt) and inspect the magnet tip for iron filings. If it looks clear, and resistance is between 1 and 2 kOhm, then 99.9% likelihood that your problem is not the sensors themselves but rather it is a wiring problem. The sensors are wired directly to the brake ECU but it may be that one of those grounds is loose. You'll need to download the wiring diagram from somewhere to figure it out in that case.
  12. squallor
    squallor New Member
    Worcester MA
    2002 Prius
    I
    That is my plan Saturday morning. I'll be going to my friend's house and we're going to take a look at all the sensors, make sure their resistance is good, clean them out, and see if that reports the same errors. If not, hopefully we can trace all the wires and find out if some shielding got scrapped through and is connecting to ground.
    Does anyone think that it could be an ECU error? I would think that if there is a problem there, then I would see a whole load of other problems, and most likely that all the sensors are broken. What other things would the brake ECU control?
    Also, for my general knowledge, I know I have been told the prius has 5 separate computers. Does this count as one of them, or is the brake ECU actually contained in the general ECU? I know at least one of the others is the dash/navigation system.
  13. axleung
    axleung New Member
    2002 Prius
    I
    I may be having the same problem as yours. Did you figure out what caused it? Thanks in advance.
  14. aammbb69
    aammbb69 New Member
    plainfield, vt
    I have a similar problem after having wheel bearings replaced. The ABS and power recovery systems are not working or intermittent. I had it checked out and was told that the tone ring was probably damaged during assembly causing false readings.
  15. aammbb69
    aammbb69 New Member
    plainfield, vt
    On another thread someone mentioned that the splines of axle and bearing have a specific alignment. If they were reconnected randomly would that leave the tone ring in the wrong position and cause the false reading?
  16. bwilson4web
    15,402
    Check the brake fluid level after pushing the brake several times. Then add to the fill line.
    Your brake pads and shoes are probably about half-done. You might change your will to leave them for your kids instead of grandkids.
  17. ChapmanF
    15,105
    @bwilson4web: is it possible you meant this reply for another thread? I didn't see in the latest post anything specific about lining thickness or fluid ... unless maybe you're speculating that the latest poster is seeing a fluid level warning.
    @Random-visitors-from-the-future: "check the fluid level after pushing the brake several times" is shorthand for "with the ignition OFF, step on the brake until you notice it suddenly hard (could be 20, 30, up to 40 times), then check the fluid level and fill it to max." The brake pumping returns the fluid that's in the accumulator back to the reservoir so you get a valid level check.
    @aammbb69: It might be better to start a new thread just about the issue you are having, and whatever information you have about it. The trouble with tacking on to an old thread with "I have a similar problem" is that you've really given hardly any information about the problem you're having, and in the original thread there are a lot of specifics to the original poster's problem, and those specifics could all be different for all we know.
    The BRAKE and ABS dash lights don't represent any specific problem by themselves. There are on the rough order of a hundred different things that can go wrong (just counting the ones the ABS computer checks for that will make it turn one or both of those lights on. For a few of them it also sounds a buzzer). So just by seeing those lights on, there's nothing yet saying whether your problem is similar or not to somebody else's just because their lights came on too. Sort of the minimum specific information to give about your problem for anybody to be able to help you would be the actual codes pulled from the computer showing what problem(s) it detected and turned on the lights for. A lot of people are using the Mini VCI now, which can definitely pull all of the brake codes. If you don't have one, you can use a piece of wire between a couple pins of the diagnostic connector (see above in this very thread for how) and get two-digit codes by counting light blinks. This will be not quite as specific because there aren't as many of those two-digit blink codes as there are actual trouble codes, so in some cases several trouble codes get the same blink code.
    Once you post the codes, we other PriusChatters can be a lot more help. At the same time, once you have the codes, you might find all your questions very well answered by looking them up in the manuals at techinfo.toyota.com and find that you don't even need us! :)
    -Chap
  18. SFtroll
    SFtroll Junior Member
    Cedar Creek, Texas
    I just got a used 2010 Prius and I’m having the same problem you describe. I have a a scanner and it’s showing no error codes. Ignoring the manual that says pull over, don’t drive any further and take it directly to the dealership for repair I continue to drive the car without problem. Did you ever get to the bottom of your issue? A great deal of time has passed so you may not even have the car anymore. But answer if you can send me a tip.
  19. ChapmanF
    15,105
    A lot of people will say that in posts on PriusChat, but it says more about the scanner you are using than it says about the car. Those dash lights come on because of the trouble codes, so if you're using a scanner that won't show you what those codes are, you're wasting time with that particular scanner.
    You don't need any scanner at all to pull the brake trouble codes. See post #5 in this very thread for how to do it. If you try that and still get nothing, then perhaps you can take the prize as the first person to actually have "lights but no codes".
    The only time it really makes sense to post on the end of someone else's thread and say "having the same problem" is if: ☑ the original thread includes the trouble codes, ☑ you have pulled your trouble codes, and ☑ the codes are the same, along with any other observable symptoms and the generation of the car. Because there are on the order of a hundred trouble codes that can make those lights come on, if you add to an old post saying "same problem" just because you have the lights and without comparing the codes, it just muddles up the old thread, and you'd get better answers by starting a new one just describing your car and your problem.
    In this case, the thread is about a Gen 1 Prius with codes 31, 32, 34, and 59, and you are posting about a Gen 3 Prius without retrieving or comparing the codes yet, so starting a new thread for your issue, in the Gen 3 forum, would be better.
    That isn't surprising, when you keep in mind that the point of self-diagnostics in modern cars is to warn you about developing problems before you would otherwise notice, so you have time to fix them before your safety is compromised. (How much time may vary, depending on what the codes are.) So, if you can drive without noticing a problem while you're ignoring the warning about it, that just goes to show the warning is doing its job, and you're ignoring it.
    The best next move at this point would be to go ahead and retrieve the trouble codes, and look them up in the manual, post them here, or both.
    -Chap
  20. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    It seems to me that posting in the correct section of the forum (for 3rd gen) and not posting on an almost 5 year old thread (in the wrong forum for a '10) would more likely yield more correct answers. Chap probably posts in the 3rd Gen. forum (he has a 2010 Prius, too.) So you would still have the benefit of his considerable knowledge & expertise. (And his sunny personality!)
