Brake Assist
Discussion in 'Prius v Technical Discussion' started by almhath, Dec 6, 2012.
  1. almhath
    almhath Junior Member
    25
    It's the B on the panel. I'm told it's Brake Assist that uses the ICE to help slow you down, like as if you're coming down a hill or something, which raises a question for me:
    Over time (in reality, even if not noticed in a practial sense), will that revving that results cause additional wear on the engine/rings, which may exceed the wear on brakes if I just use a little brake?
    I'm thinking it should. Which may not mean much in the short run, and brakes are cheaper to replace.
    This is more of an intellectual interest than a practical consideration. It's curiosity in the realm of taking care of an engine.
    Jen
  2. Tideland Prius
    16,072
    Be careful with the terms used. Brake Assist is the electronic program that applies greater braking power in the event it detects an emergency braking scenario (i.e. it helps apply the brakes harder should you not be braking hard enough).
    "B" is engine braking (like shifting to a lower gear with a manual or shifting to "2" or "L" in an automatic). It pumps the cylinders to increase drag and slow you down.
    Considering that the engine is not used as often as a regular car, I would say "you're just matching the wear of a regular car with similar mileage" (this is an unscientific claim of course. What I'm trying to say is that your engine doesn't wear as fast as a regular car in normal operations so this shouldn't increase wear past what a regular vehicle sees)
  3. almhath
    25
    THank you all for all your good info on my multiple questins. :)
    Jen
  4. BZzap!
    BZzap! Senior Member
    1,607
    877
    I have question related to the brake assist:
    Can the engine be over-sped by using the brake assist in a down hill situation?
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Jen:
    Do you have a Prius v wagon?
  6. BZzap!
    1,607
    877
    Would that make a difference?
  7. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Not necessarily. I'm trying to figure out if this post is in the wrong area.
  8. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Assuming you are referring to B mode, no.
    Actual Brake Assist has nothing to do with the engine at all.
    Brake Assist – Vehicle Safety
  9. BZzap!
    1,607
    877
    I posted the question based on the subject matter. It's not like I posted it on a BMW forum.
  10. BZzap!
    1,607
    877
    My Mistake. I meant B-mode. Thanks for the link.
  11. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  12. n0na
    n0na Junior Member
    88
    WA
    Yes, B mode is hard on the engine. Given a choice, it's better to use the brakes to slow down. But, on a long downhill mountain road the traction battery will fill up with energy from the regenerative brakes and then friction brakes take over. On a long downhill, the brakes can then overheat and you can end up with no brakes at all. So, when you need B mode, use it, even if it's a bit hard on the engine. When I was doing some mountain driving, I usually had the car on cruise control and, on a downhill, the car automatically used the regenerative brakes to try to keep the car at the cruise control speed. When the tracktion battery filled up, the car automatically put itself in B mode. The engine was really screaming (couldn't be good for it) but at least it kept me at a safer speed. There's probably no reason to ever put the car in B mode yourself as the car will switch into and out of it on its own when it needs to.
  13. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    If you know the decent will fill the battery, put it in B mode from the top, your friction brakes will stay cooler longer.
  14. fuzzy1
    10,044
    Is the 'v' different from the regular Liftback in this regard? I'll respond from the Liftback perspective, on the understanding that the 'v' is not different.
    When descending in Cruise Control, the car will use engine braking when the battery is full, but I don't believe it is quite as strong as that provided by B mode.
    Without Cruise Control, it will still use a little engine braking when the battery is full. But this version is quite weak, not anywhere close to B mode. On most of the hills I travel, it is insufficient to hold speed down to a safe level.
    Without Cruise Control, this is quite false, as the provided braking is simply too weak. With CC, well, most long steep hills I descend are not safely negotiated in CC. Deliberate B mode becomes a necessity.
  15. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Those durned flatlanders are convinced the entire Earth is flat.:ROFLMAO:
  16. Tideland Prius
    16,072
    No. The engine speed is controlled. Even if you floor the pedal uphill, you're not redlining it (it's just holding out at max torque).
    I've come down the mountain in a Gen 2 in B-mode. It sounds like a twin prop coming in to land :p
  17. BZzap!
    1,607
    877
    I have to get use to using the term "B-mode". In any event, when I was going down hill in B-mode the drive train sounded as if it was going to start centrifuging parts out through the hood. Maybe the engine isn't over spinning but what about MG1 and MG2 and the planetary unit. I just don't quite understand where all the inertia is being bled off. Something is spinning... fast. I think!
  18. fuzzy1
    10,044
    Yes, the ICE (gas engine) is spinning fast, but the RPM on my ScanGauge has never hit redline. MG2 is locked to the wheels, so it should not overspeed as long as you don't exceed the ground speed where the engine would cut out on flat land (~112 ? MPH for the Gen3 Liftback, possibly less for the 'v').
    MG1 should not overspeed if the ICE is spinning. Just don't ever put the car into Neutral when the engine is not spinning, then roll downhill to high speed. That leaves MG1 unprotected.
  19. BZzap!
    1,607
    877
    Thanks for the clarification.
  20. blisspacket
    blisspacket Junior Member
    32
    StAugustine FL
    Just drove through the Tahoe hills/mountains. Used the bmode and the dmode. I must say that I prefer using the 4 disc brakes as opposed to tolerating the increased engine drone of the bmode. I could not distinguish any change in the charging state/rate of the battery in b vs. d mode. I'm in a 12 v; gotta change my id....
