Brake Life???
Discussion in 'Gen 2 Prius Main Forum' started by tomforst, Sep 23, 2006.
  1. tomforst
    tomforst New Member
    32
    One of the savings I expect to see with this car is little or no brake work needed because of the regenerative braking. After just spending $538 for brakes on my Explorer (for the second time in 3 years), I'm hoping I won't see this kind of expense with my 2005 Prius (currently at 50,000 miles). Has anyone made it to 100,000 miles or more on the original brakes?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    http://privatenrg.com/#100kBrakePads
    I believe he's over 125k miles now. I expect to never need to worry about brake work as I expect to have the next generation Prius well before that becomes a concern.
  3. jamarimutt
    jamarimutt New Member
    985
    <div class='quotetop'>QUOTE(efusco @ Sep 23 2006, 07:44 PM) [snapback]324055[/snapback]</div>
    I expected the same thing until the ABS system failed at 46,000 miles. :(
  4. BobZ
    BobZ New Member
    323
    Long Island, NY
    That's some great stuff Doc
  5. efusco
    19,891
    1,191
    Nixa, MO
    <div class='quotetop'>QUOTE(jamarimutt @ Sep 24 2006, 06:22 AM) [snapback]324194[/snapback]</div>
    That stinks, but hardly a break wear or use issue. Bet the pads were still good when you had the ABS fixed.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Remember that brakes rust away even when not being used. This varies by location and materials, but I live in the middle of a lot of water, so humidity is always an issue, plus all of the salt on the roads in the winter. My Honda brakes used to rust so much over a weekend of no use that they would grind and growl for the first few stops every Monday morning. I suspect that will be the biggest factor controlling the life of my Prius brakes, not the number of miles. Still, it's going to be much, much longer than an ordinary car. :D
    Tom
  7. Stilview
    Stilview New Member
    61
    Northern VA
    102,000 miles on my 2004 and no brake work so far. I asked how they looked when I had it in for the 90k service...they chuckled :lol:
  8. galaxee
    galaxee mostly benevolent
    9,810
    464
    MD
    DH has seen a classic with 140k that had about half the pads left.
    not many second gen's around here that are much over 100k, they look practically new.
  9. Tideland Prius
    16,016
    <div class='quotetop'>QUOTE(qbee42 @ Sep 24 2006, 06:33 AM) [snapback]324214[/snapback]</div>
    heh.. my rotors have rust spots in the summer :blink:
    Gotta clean them from time to time.
  10. Drift Motion
    Drift Motion RMS13
    178
    Pasadena/Riverside, CA
    holy smoke 120k?!
    my 15 year old chuki is only 105k
  11. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I only have 35K + and my mechanic asked if I ever use the breaks. This may be the first car where the breaks last the life of the car.
  12. c4
    c4 Active Member
    607
    51
    2001 Classic, original brake pads and rotors, 215000km on the clock, about 65% pad thickness, and the original Prius braking system uses much more friction braking than the HSD, which tries to do most of the braking completely using regeneration until a minimum speed is reached.. I fully expect that I'll retire the car still with original brakes on it... On the other hand, I did replace one front wheel bearing, which was somewhat costly...
  13. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    That is such an incredible savings!! I had just 26k on my Sport Trac when I sold it and it was sold needing the brakes done already. That is a ton of extra money in my pocket!
  14. tochatihu
    tochatihu Senior Member
    8,972
    3,501
    Kunming Yunnan China
    2001 Prius
    Most of the Prius friction brake work done so far seems to be linked to winter road salt. The Vancouver Prius taxi guys have had some brake replacements.
    I suppose that we should still be thinking about changing the fluid from time to time because it eventually absorbs water and can corrode internal brake lines.
    Jamarimut - any hint that such corrosion might have been related to your ABS problem?
  15. pardreamer
    pardreamer Member
    114
    San Diego
    I have a 2008 Prius with 46K miles and still have 70% of the brake pads left. And this estimate is done by the Auto Mechanic so it can't be too optimistic.
  16. CBarr31
    CBarr31 Active Member
    434
    225
    Charlotte, NC
    Ema justed rolled over 150,000 over the weekend and still has the original brake pads and rotors. <knocking on wood>
    I do A LOT of highway miles as you can see since she is just barely 3 years old. Winter in North Carolina helps since we don't see to much road salt buildup which would cause extra wear and tear on everything not just brakes.
    I'm hoping to make 200K with the original brakes next Spring or early Summer.
    Happy Driving,
    Chris
  17. jfr121
    jfr121 New Member
    Chicago, IL
    If the Prius had been designed by an American auto manufacturer they would have reduced the thickness of the brake pads to make them wear out sooner. Then they would have come up with a marketing slogan to tout the superior braking system they had created. :)
  18. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    This is quite true, it will keep the service department happy otherwise they will look like the Maytag service guys.
    This is the way American companies to make more money, similar to reduce the content of coffee from 15oz to 13oz and kept the same can size and price.
  19. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    Thought I'd bump this old thread. As I replace the brakes on my other cars I often will touch rotors after driving with fresh pads/rotors to make sure the heat is as expected, not disproportionate, not binding, etc.
    I can say that in any normal car at all even on just a short trip you'll start getting some heat and it's not more than a few stops before the rotors are too hot to touch for more than a second. I did this yesterday after some stops in my 2010 Prius and the rotors were cold. Not warm, but cold. It's like they had not even engaged. It doesn't really surprise me they would last well over 100k.
  20. spookyfudge
    spookyfudge Junior Member
    23
    philadelphia
    I have had my 2005 toyota serviced at toyota. The last time in with my 2005 at 113k miles, they said it needed breaks. I was didnt think it needed it ( no noise, or fade) so took car to my corner mechanic I use for my other cars. With parts in hand, he checked the breaks and were only down 1 mm from original specs. So I expect to get over 150k before I may need them.
