1. Offline
    www.lus.com New Member
    Sep 2, 2009
    Message Count:
    chicago
    Your Vehicle Year:
    who I depressed the brake pedal, I feel it accelerate a little bit at first, then the brake start to working. is this normal?
    this cause some confuse when i depressed the brake pedal, since I am worrying about having depressed the accelerator.
  2. Offline
    32kcolors New Member
    Jul 14, 2009
    Message Count:
    4,515
    536
    Redondo Beach, CA
    Your Vehicle Year:
    Haven't experienced this.
  3. Online
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    Are you saying that when you press the brake pedal, the car momentarily accelerates? Does it do this always, or only going over bumps?
    Tom
  4. Offline
    neilz New Member
    Aug 30, 2009
    Message Count:
    126
    Staten Island, NY
    Your Vehicle Year:
    It only happens to me when I have the cruise control set. It feels like it's accelerating but I watched the speedometer and I did not gain any speed.
  5. Online
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    It's probably just a slight sensation as the car comes out of cruise control.
    Tom
  6. Offline
    Mt View New Member
    May 7, 2005
    Message Count:
    170
    22
    Pine, CO
    Your Vehicle Year:
    I've experienced this also. I think it is just the perception you get when you are pressing on the brake but the car is still under power (the CC doesn't seem to cancle until you hit the brake kind of hard). Now I just cancel the CC with the stalk or tap the brake harder.
  7. Offline
    Sep 2, 2009
    Message Count:
    chicago
    Your Vehicle Year:
    yes. it accelerates when i press the brake pedal and then the car start to slow down. it happened several times. the road is flat, and i didn't use cruise control.
  8. Offline
    Mt View New Member
    May 7, 2005
    Message Count:
    170
    22
    Pine, CO
    Your Vehicle Year:
    If mine did that w/o me hitting the accelerator I would have it at the dealer immediately. Don't know what kind of safety systems the car has for this, but I would think that if the accelerator sensor is faulty it could be very dangerous.
  9. Offline
    Sep 2, 2009
    Message Count:
    chicago
    Your Vehicle Year:
    you are right. it scared me, when it accelerates while pressing the brake. if it happen again. i will contact the dealer.
  10. Offline
    CharlesJ New Member
    Dec 13, 2008
    Message Count:
    433
    Monterey
    Your Vehicle Year:
    Not knowing exactly at what pedal position the cruise disengages, this would make sense that it would want to accelerate briefly as it feels a slight slowdown but disengages as you continue to further press on the pedal beyond the point where it disengages.
    Next time you may want to experiment with a quicker rate of brake application and see if you still notice that acceleration.
  11. Offline
    chefHawk New Member
    Aug 29, 2009
    Message Count:
    New Jersey
    Your Vehicle Year:
    Over a bump I felt this; didn't have the cruise control engaged. Also get a very strange rumble and the sound of gears not meshing well when backing up on electric and motor starts up.
Share This Page
