Brand new car, power window buttons don't work
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by JC91006, May 21, 2015.
  1. JC91006
    16,470
    8,383
    Just my luck, bought a brand new 2015 plug in and realized after 1 day the driver's windows doesn't roll down on auto, and the passenger side roll down doesn't work at all. Car only had 6 miles on it when I drove off the lot. I'm disappointed to say the least.
  2. Barbara R
    Barbara R Junior Member
    44
    2014 Prius Plug-in
    Have you accidentally pressed the Window Lock button by any chance? Also I think there is a setting you can change that controls this. Check the manual.
  3. JC91006
    16,470
    8,383
    Oh this is going back to the dealer and I'm getting some free Donuts!
  4. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    Check the window lock button first. If you made that boo-boo, shame on you given your Prius experience! After that, fully lower each window. while holding the button down for 3 extra seconds. Then fully raise each window while holding the up switch for 3 extra seconds. This will calibrate the auto up/down.
  5. JC91006
    16,470
    8,383
    I didn't lock the windows, they don't work. The passenger window doesn't roll down at all. Lemon.....
  6. ITgem679
    ITgem679 Junior Member
    73
    17
    I am sure there is a perfectly good explanation for this.
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    Could be worse.
    Could of bought a $127,000 Tesla and have the door lock not work.
    Disappointing, frustrating, but you're under warranty. And that IS the type of thing that should be easily fixed.
  8. JC91006
    16,470
    8,383
    This was the last one on the lot with CA carpool stickers, been sitting there since Sept/2014 as a 2015 model.
    I know they had to jump start the car since nobody knew this car even existed at their dealership until I asked about it.
  9. se-riously
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    That explains it. Have them replace the 12V battery first. If it's been sitting for 9 months with constant SKS drain, that battery is way dead.
    ITgem679 likes this.
  10. JC91006
    16,470
    8,383
    well it's measuring above 12.8 volts after they charged it up, they won't be changing that for me.
  11. ITgem679
    73
    17
    Are you noticing anything else, other than the windows having issues?
  12. The Electric Me
    9,083
    5,796
    I've read enough threads where people charge a dying battery and initially get good numbers but still end up needing a new battery.
    But bottom line?
    I'm keying in on the words "Brand New".
    Buying a brand new vehicle, you lose a lot of money the moment you sign the contract and drive it off the lot. BUT the big advantage is the New Car Warranty.
    Why stress about it? Let Toyota figure it out, and start documenting in case you do start having further problems.
  13. JC91006
    16,470
    8,383
    I'm not stressing over this, I already intend to bring the car back. I just wanted to express my disappointment at a brand new car with 6 miles and already having issues.
    I leased it for 3 years, it's not like I'm keeping it.
  14. JC91006
    16,470
    8,383
    haven't really driven it yet, so far just the windows
  15. The Electric Me
    9,083
    5,796
    Sure, I'd be disappointed, and perhaps frustrated. But worst case scenario, that problem seems rather mundane and very addressable. Nobody wants a problem with a new vehicle, but if you are going to discover a ghost in the machine? The window switch not working properly is about as friendly a ghost as you could want.
    I hate to mention it but given that this is a 6 miles and just cut the umbilical cord problem, did you try the advice in Post #2?
  16. JC91006
    16,470
    8,383
    No I plan on taking the car to the dealer. There should be something wrong with the button as it doesn't roll up or down, technology should not control that. I also want a free donut!
    I blame the dealer for not properly doing the predelivery inspection.
  17. ITgem679
    73
    17
    The Electric Me has a very good point. If there was a choice of a problem, I would imagine the windows would be an ok choice, leaning towards an easy fix.
  18. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    You might want to try this and save yourself a trip to the dealer:
    thegreenenergy: How to get your Prius power windows working again
    Granted, that may apply to Gen2.. BUT I do know for a fact that after you replace the 12V (or in your case after charging it back up), you do need to reset the Auto window up and down thing (something to do with pinch protection and the window knowing where top is)
    For those who dont want to click through, basically, just hold the window switch in the up position (with window all the way up) for 10 seconds to reset the system
  19. The Electric Me
    9,083
    5,796
    LOL!
    Enjoy the donuts.
    I do believe Toyota builds good products. So even though "Lemons" are possible with any automaker, I hope this can be easily resolved, and you can restore your faith in the machine enough to enjoy it.
    Good Luck, let us know what the ultimate resolution turns out to be.
    UPDATE:
    Hopefully it's as easy as post 18.
  20. JC91006
    16,470
    8,383
    The passenger window doesn't roll down at all using the controls on the driver's side.
    Yes I understand the driver's window needs to reset.
