Button on right side of the fob?
Discussion in 'Gen 4 Prius Technical Discussion' started by TheKhal, Jul 26, 2016.
  1. TheKhal
    TheKhal New Member
    San Francisco Bay Area
    I noticed that the bottom of the shiny (sensor) portion of the fob on the right side is a button of some sort. Anyone knows what it is used for?
    P.S. I have a 2016 Prius Two
  2. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Right by the small key ring? Slide that little button over, and you can pull out the door key.
  3. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    Does the button have a key icon on it, and it says "push"?
    That button unlocks the mechanical key that is inserted into the top of the fob. Press the button, pull the key out of the fob.
  4. Coast Cruiser
    2,267
    2,571
    Xlider, I guess they changed the new Fobs... my Gen4 Fob does not have a key icon, and doesn't say "push" anywhere. Did Toyota go cheap?:LOL: (And the key is on the bottom of the Fob.)
    xliderider and alanclarkeau like this.
  5. TheKhal
    TheKhal New Member
    I'm not referring to the slider button (bottom of the fob) for pulling out the key. The button I asked about is not very obvious. The shiny portion on top of the fob continues down to the left and right edges. End of the right edge depresses and pops back up like a button, but the left edge does not.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,041
    7,580
    near Brisbane, Australia
    Mine barely moves - I suspect it's a bit of free-play, otherwise it would be too tight when opening it up.
  7. Coast Cruiser
    2,267
    2,571
    Ok, sorry for the confusion. My fob is very solid on both sides. Nothing moves. (And I've dropped it 3 times on hard concrete.)
  8. eric1234
    eric1234 Active Member
    390
    198
    Hamden, CT
    Just checked. Mine is not as you describe...
    booke02 likes this.
  9. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    I feel deflection on the right side, glossy plastic "trim" if I press hard enough, but no indication that it is anything more than that.
  10. Kenny94945
    Kenny94945 Active Member
    765
    391
    Sausalito
    2016 Prius v wagon
    OP..sometimes a picture is worth one thousand words...can you post a pic?
  11. Tideland Prius
    16,065
    Followed the glossy part on both sides of the fob. It's solid on mine. Perhaps yours is a loose piece?
  12. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Mine deflects some, but it's not a button I'm almost certain.
  13. pjm877
    pjm877 Member
    340
    83
    austin, tx
    nothing there... move along
  14. pjm877
    pjm877 Member
    340
    83
    austin, tx
