1. Offline
    jefem24 New Member
    Apr 8, 2009
    Message Count:
    Blandon, Pa
    Your Vehicle Year:
    This article about the brake failures has me bugging out. Can anyone speak to the percentage of cars that this may be a problem with or if it has been solved. I have a newborn so this worries me a lot. I e-mailed Toyota to see what they have to say too but would like to hear stories and or reassurance from people who deal with these cars daily.
    Prius brake problems at bogleheads
    I'd post the link but i cant yet. need 5 posts.
  2. Offline
    Frayadjacent Resident Conservative
    Mar 22, 2009
    Message Count:
    373
    Austin, TX
    Your Vehicle Year:
    I haven't seen much about brake failures. I picked up a 2009 two weeks ago.
    I'm kicking myself now.. the dealer is now offering an additional $2k off their 09 Prius that are in stock.
    Go buy one but talk them down if they have stock. They'll want to move the 09s, and lots of people are waiting for the '10 models to hit the dealers soon.
  3. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,755
    2,805
    Northern Michigan
    Your Vehicle Year:
    The site you mention does not exist.
    Tom
  4. Offline
    jefem24 New Member
    Apr 8, 2009
    Message Count:
    Blandon, Pa
    Your Vehicle Year:
    the site is and org not a com
  5. Offline
    usbseawolf2000 HSD PhD
    Sep 22, 2004
    Message Count:
    9,659
    1,270
    Queens, NY
    Your Vehicle Year:
    My brakes are fine and working like the first day I got it. I have 92k miles on it now and still no need to change the pads yet.
    The link to the discussion OP mentioned is below. I have yet to read it.
    Bogleheads :: View topic - Prius brake problems
  6. Offline
    Sep 22, 2004
    Message Count:
    9,659
    1,270
    Queens, NY
    Your Vehicle Year:
    It looks like people are experiencing ABS/Traction Control in action. The issue is compounded with the crappy Integrity wet surface performance and extra PSI in the tire.
  7. Offline
    yardman 49 New Member
    Mar 26, 2009
    Message Count:
    606
    68
    Northern Kentucky
    Your Vehicle Year:
    It's also not "blogleheads" as the OP wrote. It's actually "bogleheads.org". Here's the link that I found:
    What a difference one little letter can make......:)
  8. Offline
    jefem24 New Member
    Apr 8, 2009
    Message Count:
    Blandon, Pa
    Your Vehicle Year:
    thats the link i wanted to post 2 more and i can lol
    post #1 corrected sorry.
  9. Online
    Zythryn New Member
    Apr 28, 2008
    Message Count:
    947
    146
    Your Vehicle Year:
    My wife and I have had zero issues with brake failure with either one of our Prii.
    I read a number of the complaints the person speaks of. I found three links to the total brake failure mentioned. All three appear to be from the same poster??
    I have never heard of anyone that owns a Prius (I know a few in the area and have met lots here) that have experienced this issue.
    The ABS brake system CAN kick in if you hit a large pothole or such. This can take some getting used to, but never caused me any danger of not being able to stop.
  10. Offline
    jayman New Member
    Oct 21, 2004
    Message Count:
    13,430
    581
    Winnipeg Manitoba
    Your Vehicle Year:
    Guess what? My FJ will experience the same "brake failure" if one wheel happens to hit a manhole cover while braking. Press on the brake pedal harder, the ABS keeps working
    The "widespread" reports of Prius brake "failure" are not even worthy of a nasty response from me. Especially if those "reports" involve a rather well known ambulance chasing lawyer website, which I will not even spell out
  11. Offline
    jefem24 New Member
    Apr 8, 2009
    Message Count:
    Blandon, Pa
    Your Vehicle Year:
    ok less worried now that no one here has experienced this. Feeling better about the upcoming purchase. If anybody else has comments would still love to hear them. Thanks!
  12. Offline
    Mike Dimmick New Member
    Aug 8, 2008
    Message Count:
    959
    226
    Reading, UK
    Your Vehicle Year:
    The only thing I'd add is that the car's braking system is quite complex and it cannot be serviced by anyone without the correct diagnostic tester. Basically there are two hydraulic circuits that in normal use are not connected, but are fed from one fluid reservoir. The tester has to be used to tell the brake computer (Skid Control ECU) to flush fluid through from one system to the other.
    If it's not done correctly, you could well have a failure of the friction braking system under the conditions where it's used - sharp braking, hard braking, braking to a stop when regen cannot provide enough force any more/the car switches to creeping, and on bumps where regen cuts out.
    The Prius is not unique in this respect - other cars are equipped with dual-circuit brake systems - but on any other car with dual-circuit brakes, it will fail in all braking conditions, not just the limited scenarios.
  13. Offline
    Mar 27, 2004
    Message Count:
    7,384
    760
    United States
    Your Vehicle Year:
    Anecdotes are nearly worthless as evidence. In contrast Consumer Reports data show the Prius to be highly reliable.
  14. Offline
    jayman New Member
    Oct 21, 2004
    Message Count:
    13,430
    581
    Winnipeg Manitoba
    Your Vehicle Year:
    Yes, if an independent garage offers to "bleed" the brakes on a Prius, run like hell
  15. Offline
    jefem24 New Member
    Apr 8, 2009
    Message Count:
    Blandon, Pa
    Your Vehicle Year:
    ok so I guess my next question is would a lazy make the same mistake? is this possibly what happened or a lazy assembly line person? and how can you be certain it's been done right.
  16. Offline
    Apr 13, 2004
    Message Count:
    14,718
    519
    South Puget Sound, WA
    Your Vehicle Year:
    inspection, inspection, inspection... i would guess, based on the level of failure for the Pri... there is a lot of that going on
  17. Offline
    jefem24 New Member
    Apr 8, 2009
    Message Count:
    Blandon, Pa
    Your Vehicle Year:
    I assume you mean low level of failure? if not please explain as that would go against the rest of the posts?
  18. Offline
    Apr 13, 2004
    Message Count:
    14,718
    519
    Your Vehicle Year:
    yes i implied a high level of inspection based on the reports of very high owner satisfaction and a very insignificant level of reported manufactured defects.
  19. Offline
    Mar 27, 2004
    Message Count:
    7,384
    760
    United States
    Your Vehicle Year:
    At the risk of getting off topic, I'd say that high quality of the Prius is a result of good design of the car and good design of the manufacturing and assembly processes. "Inspecting-in" quality is a very expensive way to achieve it.
  20. Offline
    JimN P719 of ???
    Nov 26, 2006
    Message Count:
    4,487
    229
    South Jersey
    Your Vehicle Year:
    The referenced site appears to be pure BS as it is filled with vague generalities and sweeping statements. I had an ABS brake failure early under warranty. Although the dash lit up like a Christmas tree I had normal braking and drove the car probably some 20 miles to the selling dealer. I suspect any reported "braking problems" are category 1d10t.
Share This Page
