Buying a Prius - What do you think and is this noise normal?
Discussion in 'Gen 2 Prius Technical Discussion' started by Nate Byrne, Jun 21, 2014.
  1. Nate Byrne
    Nate Byrne New Member
    27
    Longmeadow, MA
    Hey all! I just put $500 down to hold a 2007 Prius with 82k miles. I am purchasing the car for $10,790 before fees/taxes. The Prius appears to be in great condition, though when I step out of the car I notice the engine or something toward the front of the car makes a fairly loud whining or ringing noise. Sort of the noise you hear from some electronics occasionally. My question is is this normal? I am having it looked at by a toyota mechanic this Tuesday but want to hear your tips/input on this and any other things to look for. Also, if the car is being sold 'as is' should it still be covered for battery warranty by CARB state law? I live in MA (a CARB state) Thanks!
  2. Nate Byrne
    27
    Longmeadow, MA
    Also, it makes this noise with the car on and with/without A/C. Also, the A/C wasn't that cold - idk if I was in ECO or not
  3. JC91006
    16,468
    8,383
    Yes this is normal. It's the coolant pump pumping coolant into the thermos. It does this when the car powers on and off
    Some pumps have been replaced due to noise but you are out of warranty for replacement. If Toyota is checking out the car, they can determine if it's too loud or functioning as it should
    SM-N900P ?
  4. Nate Byrne
    27
    Longmeadow, MA
    Thanks!! Do you have any idea as to how much it would cost to repair a pump if it needed replacement? Just a guess?
  5. JC91006
    16,468
    8,383
    ac shouldn't have any issues at that mileage, there may be a leak. Have the system checked
    SM-N900P ?
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Data Daedalus likes this.
  7. JC91006
    16,468
    8,383
    You are suppose to hear this pump, it's not silent. I wouldnt worry about this pump.
    The ac is a different story
    SM-N900P ?
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    AC should be super cold in LO. Why are you buying a car with ac issues and a bad thermos? AC repairs on an 07 can be very expensive.
    Join toyota.com/owners site its free and you can check the vin of the car on that site and any service performed on the car by a dealer will be listed there.
    Don't be surprised if the dealer quoted big b$$$ to fix the AC and the guy traded it in. Getting very common to see buyers buying a used Prius only to find out the car was at the dealer and needed repairs and was traded in on the spot. Car goes to auction and caveat emptor.
    And btw, the 07 has no ECO mode. Thats Gen 3.
    uart and Data Daedalus like this.
  9. usnavystgc
    3,159
    988
    Tucson, AZ
    I don't think the Thermos is bad nor do I think the thermos pump is bad.
  10. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Is that a steady noise whenever the Prius is in ready mode Nate? Or is it just something that happens for a few seconds after the Prius has just been started or shutdown. If it's a steady noise it may be the inverter. They all make some amount of whining noise when running, but for some reason some seem louder than others.
    Agreed. Make sure that the aircon is working 100% correctly before you buy it Nate. Aircon is important on the Prius as the cabin air cools the main battery, and it can be a very expensive repair.
  11. Asim Jahangir
    Asim Jahangir Junior Member
    34
    I have a 2007 prius, and it makes a similar noise (like someone has a dry cough). I also bought a as is Prius a couple of years ago, and I haven't had a problem with the noise. Its probably nothing.
