1. Offline
    Redcap32 Junior Member
    Start a Conversation
    Mar 19, 2012
    45
    Kansas City
    Your Vehicle Year:
    How do you remove to steering wheel to change the stalk out? how easy is it what tools do I need?
  2. Offline
    Mar 19, 2012
    45
    Kansas City
    Your Vehicle Year:
    I picked up my stalk today from the dealer and installed it tonight after work and it works great, was realy very simple to replace. I would suggest making sure the steering wheel is dead center and is straight. I used white out to mark a line to make sure it when back in the right position. But they work great the fogs can turn on when the low beams are on and they also turn off automaticly when the high beams come on. also the symbol shows up on the dash that they are on.
  3. Offline
    kwhubby New Member
    May 23, 2012
    17
    San Jose
    Your Vehicle Year:
    I'm interested in adding fog lights to my C 2. I called the dealership I purchased from to find that they want $760 for parts. Anybody have any reasonable suggestions to get them near San Jose? I am contemplating fabricating my own fog light out of the current plastic cover and some yellow LED's+PCB.
  4. Offline
    kd9jb Junior Member
    Mar 31, 2012
    SW Indiana
    Your Vehicle Year:
    I too am adding fogs to my C2 and discovered that the wiring from the light switch to the computer is not there. The wiring from the fogs to the computer is. Bought the stalk, bezels, and aftermarket fogs to install and am stalled at this point. Will probably go with an external relay. Hope this info helps.
  5. Offline
    ROLOPR Member
    May 22, 2012
    251
    Puerto Rico
    Your Vehicle Year:
    Does this happen to a C3 also???
    I just received all the parts today, to be installed wednesday, I hope not getting any surprises of missing wires, relay etc.
  6. Offline
    kd9jb Junior Member
    Mar 31, 2012
    SW Indiana
    Your Vehicle Year:
    From other posts in this thread the 3&4 are both wired for the stalk and lights. Should be pretty simple if you follow the advice of the folks that have already done it. I am still looking into adding the wiring to make the stalk work in my 2. Good luck!
  7. Offline
    ROLOPR Member
    May 22, 2012
    251
    Puerto Rico
    Your Vehicle Year:
    ok thanks for the aclaration
  8. Offline
    ROLOPR Member
    May 22, 2012
    251
    Puerto Rico
    Your Vehicle Year:
    Installed everything in my C3 but no turning on, apparently or a relay is needed or the wiring from light switch to computer not there.
    Review everything again. No response from computer so that means a external relay mod is the only way :(
    Don't have any idea of how to do it.
  9. Offline
    ROLOPR Member
    May 22, 2012
    251
    Puerto Rico
    Your Vehicle Year:
    Here are some photos.
  10. Offline
    ROLOPR Member
    May 22, 2012
    251
    Puerto Rico
    Your Vehicle Year:
    What else do you do to turning on the fog light, a external relay?
  11. Offline
    WD0AFQ Active Member
    Jul 6, 2012
    511
    109
    Dexter, Mo.
    Your Vehicle Year:
    I would like to see a picture of the new fog light housing before the light goes in.
    Dan
  12. Offline
    ROLOPR Member
    May 22, 2012
    251
    Puerto Rico
    Your Vehicle Year:
    Where's everybody when someone need help :(
  13. Offline
    Jul 6, 2012
    511
    109
    Dexter, Mo.
    Your Vehicle Year:
    Wish I could help you but I don't plan to buy the stalk. A seperate switch or just wire them into the existing harness as noted on page one of this thread. Someone will see your need for help and respond.
    Dan
  14. Offline
    kd9jb Junior Member
    Mar 31, 2012
    SW Indiana
    Your Vehicle Year:
    I can tell you what little I know based on a C2. To tell if u have the wiring from the stalk to the computer look at the connector at the stalk end. It should have 2 rows of connectors. A pretty full one and one with 2-3 in it. One of the wires in the short row is used for the fogs. That is where I am stuck at this point. Not much, but u can at least see if that is your problem.
    John
  15. Offline
    ROLOPR Member
    May 22, 2012
    251
    Puerto Rico
    Your Vehicle Year:
  16. Offline
    kd9jb Junior Member
    Mar 31, 2012
    SW Indiana
    Your Vehicle Year:
    One last report. My PC2 is not wired for fogs from the ECU to the Headlight Dimmer Switch or to the dash indicator. The wiring is not there. It appears that the ECU is not programmed for it either. Today I grounded the pin on the ECU to check for this and the relay did not pick up. The wiring from the ECU to the fog lights appears to be there. I already purchased and installed the stalk so now I am going to the relay control using the stalk. It is possible to add the wiring to the stalk connector by using repair pins from Toyota. They are way overpriced but fit the connector. Just have to track down the best location for the relay.
    John
  17. Offline
    ROLOPR Member
    May 22, 2012
    251
    Puerto Rico
    Your Vehicle Year:
    Same here, even go to the dealer and the tech indicate the same as you did, it's probably to change the computer because there is no relay for the fog lamps. Keep updating
  18. Offline
    TxTkd New Member
    Nov 16, 2012
    16
    Your Vehicle Year:
    kkim and FRENZIED like this.
  19. Offline
    FRENZIED New Member
    May 24, 2012
    NEBRASKA
    Your Vehicle Year:
    Hallelujah! That is awesome information! Finally, someone trying to actually help those who want a simple mod without the astronomical stealership pricing. I'm gonna get that kit. Thanks TxTkd!!!
  20. Offline
    Jul 6, 2012
    511
    109
    Dexter, Mo.
    Your Vehicle Year:
    I am getting me a set of these. Best price I have seen.
    Dan
Share This Page
