C unhappy about Leaving sunroof open :(
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by C4me, Mar 26, 2013.
  1. C4me
    C4me Junior Member
    Went to the garage tonight and heard a buzzing noise coming from the rear of the cars left side. After investgating the cause seemed to stem from the sunroof nkt being completely closed. seems i accidently left it open 1/2". if i did not notice this would my battery have been discharged by morning?
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    The sunroof "shouldn't" have caused what you were hearing. If it's stationary it won't matter...
  3. C4me
    C4me Junior Member
    The reason I believe that was the cause is because once I started the car and closed the sunroof and shut down the car the noise stopped. The sunroof button would not close until I started the car so that is why I know the car was not turned on. I can not imagine what else it may have been. If the back hatch was not closed all the way would the car make that noise? I did open it to peek into the rear of the car trying to locate the sourse of the humming, however the noise only stopped after closing the sunroof. I do notice that if the sunroof is opened all the way when I exit the car, the dash displays the exclaimation sign in the yellow triangle until I close the sunroof
  4. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Not sure about the hatch, but I don't think so, unless the keys were in it or the lights were on... but not sure about the sunroof. If it has a warning to let you know it's open, then maybe it was the sunroof.
  5. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    Are you sure it was any sort of warning, and not just one of the many normal noises the Prius makes while sitting parked? I can never remember the details, no matter how many times I read about it, but the car has certain things it does, even when off, and it makes noises. I doubt it had anything to do with your sunroof. Whatever it was in the middle of doing likely either coincidentally ended at the same time, or you interrupted the process by turning on the car (not something to worry about either).
  6. RocMills
    RocMills Active Member
    789
    276
    Las Vegas, Nevada
    Yesterday, for the first time since I got the car, I sat in for about 10-15 minutes after I shut it off. I, too, had read references to odd sounds... and was stunned, minute by minute, listening to the car talk to itself. If I hadn't already known it would do that, I might have been a bit freaked out.
  7. firstrival
    firstrival Member
    102
    Did the noise happen exactly 5 hours since you last turned off the car?
  8. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Here's a quote from my Prius' owner's manual:
    Approximately five hours after the hybrid system is turned off, you may hear
    sound coming from under the vehicle for several minutes. This is the sound
    of a fuel evaporation leakage check and, it does not indicate a malfunction.
    I bet that by turning the car on to close the sunroof you simply interrupted this (natural, proper) function.
    Not a sunroof thing at all, I suspect.
    RocMills likes this.
  9. C4me
    C4me Junior Member
  10. gbouten
    gbouten Junior Member
    48
    Alamogordo NM
    The book says 20 minutes after the car is turned off all power is shut down to anything running.
  11. Fauxknight
    Fauxknight Active Member
    210
    116
    I heard the humming once when I took some trash out late at night. Good to know that it's just a normal process of the car.
  12. RocMills
    789
    276
    Las Vegas, Nevada
    I think all C owners should, at least once, drive the car around for a bit until it is well and truly warmed up... then shut the car down and just sit with it for 30 minutes to get familiar with all the odd sounds that the car makes when we aren't normally around to hear them. :)
    ftl likes this.
