1. Offline
    PriusRos A Fairly Senior Member
    Jun 22, 2006
    Message Count:
    1,666
    69
    Rockville, MD
    Your Vehicle Year:
    I was listening to a CD and suddenly the screen changes to the phone screen and I get a "call waiting" and "talking" message. I didn't hear the phone ring. The CD audio was still running. No matter what button I pressed -- off-hook, on-hook, transfer, whatever -- the message would not go away. I checked my phone and there was no call. When I switched to map display it went away. But as soon as I hit the "phone/info" button, the call waiting message, with a counter, was still being displayed.
    Anybody have any idea what's going on?
    I don't know if this is related, but sometimes when I try to make a call through voice activation, I get a message saying the phone is busy and the command cannot be completed.
  2. Offline
    LoraJ New Member
    Jul 4, 2009
    Message Count:
    482
    55
    Your Vehicle Year:
    My only thought would be signals mixed with a nearby car, but I think that would be pretty impossible?
  3. Offline
    Jun 22, 2006
    Message Count:
    1,666
    69
    Rockville, MD
    Your Vehicle Year:
    I don't know -- but it happened again today. I tried to make a voice-activated call and got all the way through the prompts but when I said "dial" it told me it was unable to connect because the phone was busy. The phone screen showed call waiting and talking in progress -- when I was definitely not on a call. I had to disconnect on the MFD manually and then make the call manually through the phone -- although BT was still connected and the voice came through the speakers.
    I think all I can do is delete the connection and start from scratch -- see if that solves it.
  4. Offline
    LoraJ New Member
    Jul 4, 2009
    Message Count:
    482
    55
    Your Vehicle Year:
    Yup, I think that's a good idea. Something seems buggy!
  5. Offline
    LRKingII New Member
    May 31, 2009
    Message Count:
    680
    130
    Idaho
    Your Vehicle Year:
    This might sound strange but try this...go into the audio setup and set the BT there to manual connect. Not the phone setup but audio setup.
  6. Offline
    Jun 22, 2006
    Message Count:
    1,666
    69
    Rockville, MD
    Your Vehicle Year:
    I also have an iPod Touch connected through bluetooth. Would this be a problem to manually connect the phone? The busy-phone syndrome existed before I ever connected the iPod.
  7. Offline
    LRKingII New Member
    May 31, 2009
    Message Count:
    680
    130
    Idaho
    Your Vehicle Year:
    No idea on the iPod but does your phone stream music...like from the little removable mem chip/card if it has one?
  8. Offline
    Jun 22, 2006
    Message Count:
    1,666
    69
    Rockville, MD
    Your Vehicle Year:
    It does have music playing capabilities but I don't have any music on the phone or memory card -- it's not playing or displaying anything when I get this call waiting/talking/phone busy message.
    I think it might be trying to connect to the same phone twice...something like that.
  9. Offline
    jay_man2 jay_man_also
    Jun 11, 2009
    Message Count:
    1,246
    138
    Manassas, VA
    Your Vehicle Year:
    Just for grins I'd delete the phone from the car, reboot the phone, then re-link the phone to the car.
  10. Offline
    Jun 22, 2006
    Message Count:
    1,666
    69
    Rockville, MD
    Your Vehicle Year:
    I will probably do that.
    The first time I was unable to complete a call and it was telling me that the phone was busy, I thought it might have been because the phone battery was low. There's something in the manual about it not working if the battery is low. I charged the phone and it worked fine the next time I tried. When the error happened again yesterday, I thought I had plenty of charge on my phone (because I had just charged it the day before and had hardly used it) and it didn't occur to me to look. Apparently my battery was low again because it was completely discharged this morning. I'm charging it now and will see if it works this evening.
  11. Offline
    LRKingII New Member
    May 31, 2009
    Message Count:
    680
    130
    Idaho
    Your Vehicle Year:
    Remember BT drains your battery MUCH faster.
  12. Offline
    Spartane New Member
    Jun 4, 2009
    Message Count:
    149
    39
    Mississauga, Canada
    Your Vehicle Year:
    I don't know what's going on with your phone, but I have a Sony Ericsson W810i phone that seems to connect more consistently now that I've updated its firmware to the latest version.
  13. Offline
    wsrussell New Member
    Jul 2, 2009
    Message Count:
    34
    Denver
    Your Vehicle Year:
    Are you getting text messages when it does that? or maybe some other that transfer (checking for mail, connecting via WiFi, changing service areas, etc).
  14. Offline
    jayvee New Member
    Aug 11, 2009
    Message Count:
    341
    83
    WA
    Your Vehicle Year:
    This hasn't happened to me in my Prius, but I have a Garmin nuvi 660 in another car, that picks up a false "incoming call" signal at exactly the same spot on a major freeway. It's repeatable, and always within the same 0.1-0.2 miles of the freeway (and on both directions of the freeway!) The fact that Bluetooth is only good for about 30 feet or so means that this needs to be a pretty strong and consistent interference signal to cause this every time I travel that freeway.
    It has happened at other spots, too, but less consistently. It's certainly possible that another signal is causing that response, and then it disappears, and the system doesn't know what to do until it times out. I can't answer the "call" on my nuvi, either (because there isn't one!).
    J
  15. Offline
    Jun 22, 2006
    Message Count:
    1,666
    69
    Rockville, MD
    Your Vehicle Year:
    Nope -- nothing.
  16. Offline
    Jun 22, 2006
    Message Count:
    1,666
    69
    Rockville, MD
    Your Vehicle Year:
    Well, in my case, it happened in completely different locations.
    I think it could be because my phone battery was low. After I recharge, it seems to work okay.
    But if nobody else is having this problem... I dunno what it could be.
Share This Page
