1. Offline
    dangray New Member
    Start a Conversation
    Apr 24, 2012
    Coralville, Iowa
    Your Vehicle Year:
    I was wondering if the long shifter bothered anyone else? I'm over 6' tall and my leg rests on the shifter. Can it be cheaply replaced with a short shifter like in other years models?
  2. Offline
    Logical Junior Member
    Dec 11, 2003
    82
    22
    St. Louis, Missouri
    Your Vehicle Year:
  3. Offline
    dangray New Member
    Apr 24, 2012
    Coralville, Iowa
    Your Vehicle Year:
    To bad that's not compatible. A bit pricy too. I was hoping to "just" unscrew the long one and screw in a smaller one.
  4. Offline
    overflow New Member
    Apr 25, 2012
    Portland OR
    Your Vehicle Year:
    I gave the shifter a twist the other day and it came off fairly easily. Unfortunately, the shaft itself goes really far into the shifter knob, so I don't think you could shorten it much just by replacing the knob. How easy it is to replace the shaft, I don't know.
    The threading looked like it was either 6mm (like the regular Prius) or 8mm (like most Toyotas) diameter though. I should probably measure it...
  5. Offline
    danielizzle Eco Swag
    Nov 6, 2011
    160
    Anaheim California
    Your Vehicle Year:
  6. Offline
    SquallLHeart The Techie Guy
    Mar 10, 2012
    747
    180
    San Jose, CA
    Your Vehicle Year:
  7. Offline
    dangray New Member
    Apr 24, 2012
    Coralville, Iowa
    Your Vehicle Year:
    Interesting. Sounds like the shaft would need to be replaced then.
    If it can't unscrew easily, I'm "just guessing" it could be cut and then fit whatever "custom" knob I want to replace it with. Might actually be kinda neat... is that a bad idea?
  8. Offline
    overflow New Member
    Apr 25, 2012
    Portland OR
    Your Vehicle Year:
    Quick update: I compared the width of the shaft's threads to a common bic pen, which happens to be 8mm in diameter, and they were the same, which means I am 95% sure that the threads are the standard 8 x 1.25mm for Toyota (automatics), which opens up a lot of possibilities for replacement.
    As I mentioned earlier, I don't think replacing the knob will do much for the overall height. I measured it, and the stock shift knob threads almost all the way in, only adding about half an inch to the overall height.
    I don't think just cutting the shaft would be a terribly good idea, since you'd have to re-thread it too. Or just use some very strong adhesives with a new shift knob... But that's up to you. I tend to like easily reversible changes :)
    I ordered a "Razo RA119A" ($30) shift knob, just because I don't really like the look of the original. Will post pics when installed.
  9. Offline
    dangray New Member
    Apr 24, 2012
    Coralville, Iowa
    Your Vehicle Year:
    I'll be interested to see how this looks. I want to talk with my brother-in-law who is a wealth of information on this kind of stuff. I'd like to cut that down to size, and if he can give a knob on it, that's what I'm going to do.
  10. Offline
    dangray New Member
    Apr 24, 2012
    Coralville, Iowa
    Your Vehicle Year:
    My brother in law gave me his opinion on replacing the shifter. If the shifter isn't hollow, it can be done easily. We'll need to check with a parts department and report back.
  11. Offline
    kingnba6 Junior Member
    Mar 17, 2013
    129
    Queens, NY
    Your Vehicle Year:
    i dont think cutting the rod would be all that bad. even if you mess you can easily buy the oem replacement or get the actual new shorter assembly
Share This Page
