Can you go over the 5 watt limit for the trunk light?
Discussion in 'Prius c Accessories and Modifications' started by john1113, Jan 30, 2014.
  1. john1113
    john1113 New Member
    I've replaced the 5 watt incandescent wedge light with a LED bulb and is way better already. But I'm looking for something that will actually light the trunk up properly.
    This is rated at 7.5 watts. I know the trunk light has no fuse and worrying about blowing the HCU. Do you think this would work in the trunk?
  2. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    I don't think the extra 2.5 watts would be a problem but given the circular configuration, it might not
    help much in that application either. Does it have the right base ?
    What's the rating on the OEM bulb ??
    May I ask what one you have in there now ??
  3. c4
    c4 Active Member
    607
    51
    You won't blow the ECU or the circuit as the ECU does not drive the bulb directly but simply actuates a relay, which has high current contacts, but I'd worry instead about the extra heat affecting the plastics in the lamp assembly.. I wanted to put brighter bulbs in the front driver/passenger map lights, but the bulbs in there get so hot within seconds that you cannot touch the bulbs with your bare hands.. A brighter bulb will obviously be brighter (duh) but will also put out more heat, and I would worry about melting the plastic or the fixture.. Instead of putting a bigger bulb in, I've gone the way of putting extra lights in: stick on LED strips, panels or pucks strategically placed and then spliced in parallel with the trunk light circuit..
  4. Easy Rider
    982
    210
    N. Central Florida
    If they get THAT hot THAT quickly, then they probably are NOT LEDS and you likely could get a lot more lumens out of an LED that dissipates the same amount of power.......or less.
    Your point about being careful about the heat is a good one though.
    I'm not too concerned about the "trunk" light but there IS a bad dark spot in the cabin around the cup holders
    that might benefit from some stick-on low intensity LED strips.
  5. Runswithdog
    Runswithdog Junior Member
    30
    Adding additional lighting is the way to go. I have been very happy with my additions. Check out my post. Unfortunately, I can not link to it here but look under my profile.
