Can you identify this strange noise coming from engine bay?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by stonerider, Nov 23, 2014.
  1. stonerider
    stonerider Member
    107
    Lompoc, CA
    It seems to be coming from near the inverter's under side, maybe below and to the left of the inverter if you are standing in front of the car. It happens when starting the car first in the morning and when it gets cold during day. Please, can you help me identify the source of the sound?
    My Prius is a 2007 with about 104k, all recalls taken care of, dealer maintained, 12V battery was replaced less than 2 years ago. Thank you!
    #1 stonerider, Nov 23, 2014
    48,946
    can't play the video, it says it's private?
    Peter Lipovský likes this.
  3. stonerider
    stonerider Member
    107
    Lompoc, CA
    didn't know I had to go back and publish it (after editing it to shorten the clip). it should be viewable now! Thank you!
  4. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    It’s still private video.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    That's the sound of a 1000 mute kittens sleeping.
  6. stonerider
    stonerider Member
    107
    Lompoc, CA
    So sorry!
    Google youtube video manager doesn't make it easy to make the change from private to public, finally got it done! It should be viewable now, thank you everyone!
  7. bisco
    48,946
    kinda sounds like a pump. inverter pump?
  8. Patrick Wong
    18,198
    6,464
    That sound comes from the coolant heat recovery system pump. The purpose of that pump is to move hot coolant into the coolant heat recovery system canister upon engine shutdown, when you make the car IG-OFF. Then when the car is restarted, the pump moves hot coolant into the engine, to help warm-up time. This is supposed to reduce exhaust emissions.
  9. stonerider
    stonerider Member
    107
    Lompoc, CA
    Thank you for your replies!
    I thought it sounded like an electric pump.
    Now, do I need to replace the pump? Is DIY possible for someone like me, I know enough to do basic maintenance? However, I have no way to lift up the vehicle myself. I can work from the engine bay standing up.
  10. Patrick Wong
    18,198
    6,464
    No
  11. stonerider
    stonerider Member
    107
    Lompoc, CA
    Ok, thank you!
    How many pumps are there in a 2nd Gen Prius?
  12. stonerider
    stonerider Member
    107
    Lompoc, CA
    BTW, I have run Techstream on the car and there was no DTC.
  13. Patrick Wong
    18,198
    6,464
    There are four coolant pumps in a North American 2G Prius:
    1. Engine coolant pump
    2. Heater core coolant pump
    3. Engine coolant heat recovery system pump
    4. Inverter/transaxle coolant pump
    PriusDadNoob and stonerider like this.
  14. stonerider
    stonerider Member
    107
    Lompoc, CA
    Thank you, Patrick!
